Question about Samsung SF-5100 Plain Paper Laser Fax
Have a dialing tone but will not send a fax,it says" job waiting" and will not clear by turning off power
    Champion:
  • Samsung Expert
  • 214 Answers
Take the power out. hold the red button in and put the power back. this will reset the unit
Posted on Oct 21, 2011
Cant send fax out. getting a message exceeded job memory. How do I clear this
Dear
As the model is not mentioned its difficult to right solution. But in general when a document sent from memory some times this happen. This is frequent if memory recieved is more and not printed.
Its cleared on printing all memory recieved or memory cleared(all received fax will deleted).
Also sending fax manually may be done.I.e.Dial the fax no.get the fax tone load the document press start or send. Also in setting the scanning resolution may be minimised up to150/200dpi for less memory.
Thanks.
Feb 04, 2015 | Office Equipment & Supplies
Outgoing memory is full
press
Function
7
monitor key slowly 4 times
* star key
6
scroll down to ALL JOB CLEAR
set
wait for a reboot, about 2 mins.
Your fax machine most likely is not finding a dial- tone, so faxes are piling up in memory and are never being transmitted.
After the reboot, press the monitor key once and listen for the dial-tone.
Jan 20, 2010 | Panasonic Panafax UF-595 Plain Paper Laser...
Why is my fax machine not working? it reads no dial tone when i try sending a fax and i cant recieve either
make sure it is plugged in right in the back.try using a different phone jack in the house
Jul 12, 2009 | Epson Stylus NX300 All-In-One InkJet...
Hi i cant send a fax
First thing is to ensure that you have dial tone by picking up the handset on the fax machine and listening for dial tone.If there is no handset take a standard house phone and plug it into the jack where the fax machine was inserted. If there is dial tone on the phone then I would advise you to turn the power off the fax for two minutes then power back on. If there is no dial tone on the phone line contact your vendor or local phone carrier and report NO DIAL TONE
May 30, 2009 | Lexmark F4270 Plain Paper Inkjet Fax
Can't receive or send fax on my lexmark X4270
In this case first we need to chk whether there is any dial tone on ur fax machine for that u need to Hit the Options button till u find an option saying On Hook Dial now hit select and it should give u a dial tone if it doesnt check the Phone Line Connections........... If it gives u a dial tone........... Unplug the Power Supply from the Printer........ Press and hold the Stop/Clear button and while holding the Stop/Clear button insert the Power Supply back to the Printer........ It will say clearing and then display a page where u need to Selct ur Country and the other details........ and as soon as this is done u can send and recieve faxes....... Thanku
Jan 12, 2009 | Lexmark X4270 All-In-One InkJet Printer
PANAFAX UF-585
Bad fax stuck in memory. Press:
Fuction
7
6
set
Nov 02, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Faxing problem
1) Plug a single line wired (not cordless) phone in to the exact same phone jack as the fax machine and dial one of the fax numbers you are trying to dial out to using the exact same digits. Does the call complete Y/N? do you hear a fax tone Y/N?
>>>>If either answer is "No" you have an invalid phone number. If both answers are "Yes" proceed to step 2.
2) When you off hook do you hear a "stutter" dial tone? Y/N?
>>>>>"Yes" This is your phone company telling you that you have unlistened voicemail messages in your mailbox. Dial in to your voice mail and clear your messages. "No" go to step 3.
3) 2 part question: Do you have call waiting and is your fax machine trying to disable call waiting when dialing out?
>>>>>In many areas *70 (star-seven-zero) will disable call waiting for a single phone call. If you try to disable call waiting when call waiting is not on the line, the call will not complete. This may come in to play in a speed dial situation.
+++Other things to consider+++
*Is outgoing long distance blocked on the line?
*Is outgoing regional intralata (same area code) long distance blocked?
*Is local calling blocked?
*Is a speed dial misprogrammed? Forgot to dial "1" Dialed "1" in error?
*Is there a wiring problem? >>>Try moving fax machine to a different phone jack.
There may be no magic answer for your problem, I hope one of these suggestions helps.
Nov 16, 2007 | Brother MFC 240C All-In-One InkJet Printer
Problem with fax
I'm no expert but, did you try touching the online or hook button on the fax to hear the dial tone? Or connect a basic home phone into the phone jack at the wall the fax was plugged into. Do you get a dial tone. If no dial tone, call the phone company. If there is a dial tone, its the fax.
Nov 27, 2006 | Lexmark F4270 Plain Paper Inkjet Fax
Takes too long to send a fax, errors out
please tell whether you get to hear the ring tone and further to that fax tone on the other side or not?? then i can suggest ... happy faxing omnipresent
Aug 10, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Samsung SF-5100 Plain Paper Laser Fax Logo
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
