Question about Samsung RF267AB (25.5 cu. ft.) Refrigerator
Ice maker om Model #RF267ABRS not working - Samsung RF267AB (25.5 cu. ft.) Refrigerator
3 Suggested Answers
kvhappliance
  • 218 Answers
SOURCE: rf267abrs only 14 cubes of ice in 1 day
I would give it a few more days most icemakers will not cycle if the temp around the icemaker are above 15 degrees F.Leave the door closed.Open door for even one minute can take a while for freezer to cool off to temps around 10 or colder. Also if you do not have much in there it may be a problem as well it is harder for freezer to cool open space. If I can help with anything else please let me know.
Posted on Apr 08, 2010
  • 122 Answers
SOURCE: I have a Samsung RF267ABRS
If you hear a clicking sound sometimes, it is your ice maker. Replace ice maker, all you need is a short phillips screwdriver. Remove ice bucket, to the left you will see a philllips screw holding a long plastic panel going all the way to the back, remove the screw and the panel, it has clips that slilde in, unplug ice maker and push down on tab on top of ice maker and pull out
Posted on Sep 03, 2010
My icemaker stopped working but the water on the door still works what can the problem be model number 106.51552104
02fd7a9b-9a65-43a6-ae76-6bf68d211304.jpgThanks for the model number. If the ice slots inside the ice maker are empty try pouring tap water in and allow the water to freeze. If after the water freezes the ice drops into the ice bucket and the ice maker does not refill this would indicate that the side of the=> W10408179 Water Inlet Valve is defective on the side that controls ice maker water supply. If the ice maker just sits there and does nothing this would point to a defective ice maker. Depending what is wrong with the ice maker will determine what parts are replaced. Here is a list of those parts here=> Kenmore Refrigerator Model 106.51552104 Ice Maker Parts and if need you may be able to find a complete ice maker replacement by asking. Most people don't like replacing ice maker parts. I am here should you have questions or comments, Sea Breeze
Aug 30, 2013 | Kenmore Refrigerators
GE Profile Model PSS26LGSC Ice maker not working
Did the ice buildup appear to resemble the water overfilling the top of the ice maker? The only thing that I believe that may work is removing the ice maker, clean the excess ice buildup.dry and reinstall the ice maker and see it works. If the ice is above the normal level the ice can cause the motor that pushes the ice out of its slots to strain more than the gears or motor can handle stripping the gear or damaging the motor beyond repair, When harvest takes place the first thing that happens is a heater below the ice maker warms the cubes a little just enough to allow them to slide out of their slots and fall into the ice bin. The ice make for your model does not have replaceable parts and if bad or damaged it is less expensive and time consuming to by a new ice maker. If the water fills above the top of the ice maker it is usually the fault of the water control valve not closing all the way once it fills the ice maker after each harvest. Did water refill the ice maker when you cleaned it? Did the water overfill after you cleaned out the ice maker? What I am asking is water over filling ice maker again after you cleaned out the excess ice? If the water continues to flow from the WR57X10032 Water Inlet Valve
Apr 07, 2013 | GE Refrigerators
Replace water inlet valve for ice dispenser with new. When icemaker cycles it dispenses through the water dispenser instead of tube going to ice maker. I have switch lines around but can only get water...
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Dec 17, 2010 | Whirlpool Refrigerators
I have a Samsung RF267ABRS french door refrigerator. It is two years old and it quit making ice. I have replaced the filter and the water dispenser works fine. I have also reset the ice maker. What can...
Sep 03, 2010 | Samsung Refrigerators
Rf267abrs only 14 cubes of ice in 1 day
Apr 08, 2010 | Samsung Refrigerators
ICE MAKER NOT WORKING ,MODEL #gss25lgma ww
The problem is most likely the water control valve on the rear of your refrigerator. You can test the ice maker by filling with water and let freeze. If ice dumps then the water valve must be replaced. Your model has 3 different choices of water control valves. If the ice maker does nothing but freeze the water and not cycle or dump the ice then I would say the thermostat inside the ice maker is defective. Thanks, Sea Breeze
Aug 18, 2009 | GE Refrigerators
Ice Maker Not Making Ice
pls check the thermostat
Jul 23, 2009 | Refrigerators
Samsung RF267AB (25.5 cu. ft.) Refrigerator Logo
394 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
