Question about Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower
I just aquired a used Yard man self propelled lawn mower. It has not been used in 4 years or so. There was no gas in the tank-so I filled it. It won't start. I don't even get a sputter....what do I do? I am a woman with not a lot of mechanical expertise...thanks for your help!
  • Mtd Master
  • 7,482 Answers
Hi newnew972
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on May 25, 2011
What do i do i put gas in oil tank self propelled snapper?
If you did not try to mow the lawn, but shet the motor off before there was a loud KA BOOM.
If not, it is time to consider a new motor.
Otherwise just drain the crankcase like you would to change the oil.
If you have a friend that could help tilt the mower so almost all the gas is drained.
Now, put oil in the motor, 40 wt because there will still be a little gas left in the motor and when you mix gas and oil the gas is absorbed by the oil and the oil will thin out.
DO NOT! start it up and rev up the motor. You want to let any remaining gas to be taken up by the oil. Run around your lawn a few times at a moderate speed WITHOUT the blades engaged.
After this you can mow the lawn, at a moderate throttle setting, then drain the oil and fill it with the oil your owner's manual says to use.
Or just put around your yard for 30 - 40 minutes, then change the oil.
The above will only apply if you didn't mow until you had flames coming out of the exhaust and banging, knock ing noises were coming from the motor.
Jun 04, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
MTD Chipper 242-641-000 will crank and run for a short period of time, then cut off. I can spray engine start and it will run for a few seconds.
sounds like the carburetor needs cleaning OR your gas tank Vent is clogged. Try the easy thing first. loosen the gas cap and see if the mower will keep on running.
Sep 11, 2013 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Where is fuel filter on yardman lawn mower
they only have a screen inside the tank and don't use a regular filter
May 19, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Yard Man Gas Tank Leaking
replace the tank if you patch it and it fails when the engine is hot a fire is not worth what your trying to save try sears parts online to price it out
Mar 27, 2012 | Mtd Yard - Man 160cc, 21" Self - Propelled...
How much oil should i put in my kawasaki yard-man 6.5 hp 21"cut lawnmower?
Fill it to the line on the dipstick no more.They usually do not take more than a quart. Good Luck..
Mar 31, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mower cord is hard to pull and it makes a crying
starter clutch under recoil is seizing on shaft...need to polish shaft and lubricate....recoil housing will probably be damaged as well
Aug 01, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Won't start. Mower was in storage and unused for 2 yrs. Replaced spark plug. Still won't start.
IF you are turning it over and getting spark then your not getting fuel
2 year old gas can turn to sludge plugging the filter in the gas tank clean the tank out - blow the fuel line from the carb. back to the tank- use fresh gas she should run
Mar 11, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
GOT GASOLINE IN OIL TANK OF MY LAWN MOWER BY ACCIDENT. sTARTED THE MOWER ONCE .IT STARTED BUT GAVE A GREY SMOKE AND DIED.I HAVE A MACHINE YARD MOWER FROM MTD.IT IS 22'' SIDE DISCHARGER.PLEASE...
Empty the tank of the tainted gasoline (Maybe add the right amount of oil and use it for a trimmer, etc), fill tank with fresh gas and clean the spark plug, since it is probably fouled out. You may have to clean the carb with some carb cleaner, and clean your plug a few extra times, but it should be fine. Hope this helps. Good luck.
Jul 15, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Self propelled Yardman won't engage - cable problem I think???
are you in vero beach if so you can email me and i can fix it tj_gunter@comcast.net
May 21, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
SELF PROPEL FAILURE ON YARD MAN MOWER
hello
check the drive cable as not come adrift or broken
you can usually adjust the tension on top of the drive cable
also check drive belt is on the two pulleys
hope this helps
Mar 13, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Mtd Yard - Man 160cc, 21" Self - Propelled Lawn Mower Logo
93 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
