Question about Dell 1320c Laser Printer
Black toner is gray after installing new toner cartridge
  • 53 Answers
If the black has been noticeably "lighter" or gray, than it is time to replace the drum unit on the machine. (usually replaces every 5-8 toners)
Posted on May 24, 2011
Paper comes out black when printing and copying.
A. The drum is not being charged. The charger corona wire is probably broken or not making good electrical contact. The charger corona wire may be part of the toner cartridge. Try uninstalling and reinstalling the toner cartridge. If that doesn’t work, try another toner cartridge.
Please rate my help++++Thanks for using FIXYA
Jun 05, 2010 | HP LaserJet 3050 All-In-One Printer
How to install toner cartridge in a Canon 920
On your Canon PC 920, there is a recessed gray latch located on the left side of the machine towards the top front...press upwards on this latch to release the top part of copier (same as removing a misfeed or clearing a paper jam). The copier opens up.....now, located in the top unit, about center, is the drum / toner unit. It has a black plastic handle on it. Grasp this handle and pull towards you...slowly...until it is free of machine (support the rear of the unit with your other hand) Open new cartridge (unit) and install in reverse order (there should be instructions with the new cartridge) The copier has rails that the cartridge mounts on. Another note, before installing....gently shift the cartridge from side to side.....this distributes the toner evenly (again, covered in the installation instructions packed with the cartridge) There is a tab that needs to be removed to allow the toner to get where it needs to go for copying....attatched to this tab is a strip of plastic, pull all the way out. I have a PC 940...it uses the same cartridge.
Mar 24, 2010 | Canon Office Equipment & Supplies
We are getting black faxes and dark grey copies
I recommend to clean out an optics. Take apart a cartridge and well blow through, clean the rollers and contacts.
Jan 14, 2010 | Brother IntelliFAX 4100 Laser Fax
Printed sheets come out with blackish/greyish lines on the right side
Use follow these cleaning steps for your printer:
1. Open the front cover of the printer and remove the drum/toner unit.
2. Gently wipe the scanner window with a soft dry cloth. The scanner
window is located on the roof of the inside of the printer.
3. On the top of the drum unit, locate the blue tab on the left side.
Slide it back and forth across the drum about 30 times.
4. Remove the toner cartridge (TN430 or TN460) from the drum unit
(DR400). To remove the toner from the drum: hold down the blue lever on the right side of the drum (DR400) and lift the toner (TN430 or TN460) off of the drum unit.
5. Inside the drum unit (DR400) there is a green roller. Wipe the green
drum roller with a dry tissue (i.e. Kleenex). You may turn this roller
by moving the gears on the far left side.
6. If the pages area gray pages or have gray vertical lines, install a
brand new toner cartridge. If pages have dots, spots, smudges or
horizontal lines, install a brand new drum unit.
OR
If you are still experiencing gray pages or gray vertical lines,
please install a brand new toner cartridge (TN430 or TN460).
Brother strongly recommends that customers do not use generic drum unitsand/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability.
The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
If I have helped please rate my post...I will always do my best to help
Sep 11, 2009 | Brother HL 1230 Laser Printer
New toner prints very light. No setting changes on printer.
I had a similar problem, it turned out to be a cheap toner cartridge. Replaced it with an HP cartridge and have had any problem since.
Mar 23, 2009 | HP LaserJet 4p Printer
Need to change the toner/ink cartridge for our cannon 7130 copier
Yes. Open the copier up (push the gray button on the left side) then grab the installed cartridge and turn it clockwise til it meets a mark (they are triangles i believe) then you should be able to pull it towards you.Careful thou, you might get little dirty! for installing the new one just do the same thing but on reverse gear :P (or read the instructions on the cartridge box, ok i needed to say it; my bad)
Jan 15, 2009 | Canon NP 7130 Black and White Copier
Still using color toner when printing in black
Check the black toner cartridge. Most printers that use multiple cartridges will use the black cartridge as long as it has toner in it but will then start using the color toner to do the black/grayscale when the black cartridge is empty.
-Graye-
Nov 21, 2008 | HP LaserJet 2550L Printer
Won't print dark black; prints in gray
There are a few possible causes for the light print.
The first is the easiest to try and least expensive.
If you actually had a bad toner cartridge, and the toner was not making its way down the toner tube to the developer, then you may be able to fix the issue by simply doing a developer cleaning on the black developer. What this actually does is force aggitator to move toner down the tube into the developer. You can activate this from the maintenance menu.
If this does not fix the issue, then more then likely the black developer unit itself is defective and needs to be replaced.
Nov 07, 2008 | Dell 5100cn Laser Printer
Re-installing yellow cartridge in HP 2840
There is a gray button right of the LCD display that has a black arrow circling clockwise and four color dots (magenta/black/cyan/yellow). Push it until you see the "Rotating to Yellow" in the LCD display, then open up the top of the printer by pushing the big gray latch next to the picture card reader at the right front of the printer. You now have access to the cartridge. pull it out and examine it. If it is a new cartridge, check to see if you pulled the plastic dam strip out (which keeps the toner in place in shipment etc).
Sep 07, 2008 | HP LaserJet 2840 Printer
Dell 1320c Laser Printer Logo
201 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
