Question about Dometic Rooftop RV Air Conditioner
My father hooked up a 30 amp to my camper thinking it was a 240 an it is a 120 and my roof top a/c made a numming noise, now that we have put it on 120 everything in the camper works but the a/c. Do you think the whole ting is burnt or maybe just the fan motor.
  • Dometic Master
  • 3,287 Answers
The only real way to determine what has failed and how much it will cost to repair is to have it checked professionally.
With that said; I suspect that the compressor and fan motors are both toast - assuming that the thermostat was set to turn the unit on to cool the space. But, the damage doesn't end there - any transformers, electronics, etc. that have been exposed to the higher voltage have probably also failed as well. Those components that haven't failed - will likely have a significantly shorter life due to the exposure to the stress of the higher voltage. The only real variable is the amount of time that the components were exposed to the higher voltage. If it were only brief; there is a much better chance of things working. Applying twice the amount of voltage however, allows for only the briefest exposure time.
Posted on May 24, 2011
Coleman Mach 48000 series roof top A/C in my camper & recently it's been dripping heavily inside the camper. We looked at the top & inside for a clogged line & can't find anything, suggestions?
I had the same problem but it wasn't a clogged drain line, it was the gasket between the roof of the camper and the AC unit. The gasket had shrunk and pulled apart allowing rain water in. To make sure you don't have a clogged drain line when using the AC do you notice water dripping off the camper anywhere besides inside? You should have some drips somewhere on the outside.
Jul 18, 2017 | RVs
Can I walk on top of a 2003 wilderness youkon camper?
I would no advise it as most campers have very little strength in the roof section. If you really have to get on the roof then use a plank that rests on both edges and walk on that
Jul 09, 2013 | Electronics - Others
I have a jayco pop up camper with a Duo-Therm BriskAir roof top a/c. im having problem with it leaking water inside of the camper? Is there a drain hose? Or wat do u think is wrong?Thanks
Yes there are drain holes in base of upper unit (on roof), which may be plugged. Couple of questions though to see if we can better troubleshoot this for you.
-Do you remember seeing water (condensation) running off roof before when AC was used?
-Have you cleaned filter inside at ceiling lately?
May 17, 2011 | Dometic Rooftop RV Air Conditioner
Was given a roof top ac for a popup camper need help
Make and model of unit should be on base of roof assy, please reply with that so we can be sure we have right wiring info for you. Although they are pretty common, let's be sure.
Jul 30, 2010 | Dometic Rooftop RV Air Conditioner
Roof Top air conditioner makes too much noise
Hello; Those roof tops can be noisy. Are you able to determine what is causing it? The fan? The A/C pump? Over tume, the vibration isolators that are rubber cushions the pump is mounted on, get weathered and hard and they no longer absorb the vibrations of the running pump. Those are easily chked and changed. The next point of excessive noise is the unit as a whole is tranmitting the combination of all the vibrating parts including its own housing. Here too we have a remedy. The roof unit has a seal between it and the camper roof around the hole it is fitted in. The seal is foam rubber and reasonably thick enougth to serve a purpose more than to seal out water and air. After and over time this seal ends up crushed from the weight of the a/c unit. Then the A/c unit comes in contact and is actually resting on yhe roof with what is now a very flat hard gaske. The roof unit is now vibrating the roof. This is as destructive as it is annoying. Ok? Now let's get rid of 80-90% of the noise. Check and replace compressor vibration isolator mounts. There are 4 bolts holding down the A/C unit. Sccess them from the inside by removing the ceiling trim and cover.There should be one on each corner. Bolts removed, one person push up on the unit and another on top lifting the unit. There are wires going to the unit and those may need to be disconnected. Clean the roof and the a/c where yhe seal goes.You can get a new seal from camping world or rv supply. Have your measurements, Unit make and model when you go.Assembly is just backtracking. On assembly, thinhs to pay attention to are:
Put the new seal on the A/C unit, not on the roof. It takes two people to ligft and set the unit back into the hole and center it in the hole. Don't slide it on the seal. lift it if it hs to be moved or the seal may roll over..
The wiring disconnected earlier must be dealt with and put in place for reconnecting.
Now start the bolts that hold the unit down.
Make sure-- Unit is centered
Wires can be reconnected
The four hold down bolts have their washers.
Someone go topside and verify the seal is properly in place. Measureing the for corners fo even height is one way to ck and looking under the unit is another. Now tighten the four bolts evenly. corner to cross corner. measuring again will help confirn its pulled down evenly. Pull it down no more than 1/4 to 5/16 of the seal thickness. Wire it up and put the trim and plastics back on and light it off. (run it and ck for noise and vibration. NOTE!!! The A/C unit cannot touch any solid part of the roof. Reason it was centered. Always ck the unit before each trip as you would any other psrts on the exterior of the camper. Good Luck Angie.
Sep 15, 2009 | Dometic Rooftop RV Air Conditioner
Have roof top air conditioner that blows air but soon trips breaker. any suggestions? Henry
check the condensor fan in the rooof unit. It's the fan blowing on the cpil on the roof.. If it failed, the head preasures can becme excessive andwork the compressor hard causing the breaker to trip. Let me know and good luck, Ned_
Sep 13, 2009 | Dometic Rooftop RV Air Conditioner
Pop up camper-leaking from ac unit when it rains.
Personally I would undo the 4 bolts that hold the upper unit (outside) to lower unit (inside) , then with circuit breaker off & confirmed that no power to it, take cover off for hydro connection, and unhook those wires, and unclip harness from connector to upper unit, to allow for removal of the lower & upper unit, then remove both upper & lower and cover the hole for now until you decide on whether or not your going to fix the roof supports in that area. I'd cut a 16" square piece of painted plywood or fairly stiff aluminum, add a good thick bead of sealant (not silicone, it doesn't last long) to the area where you see the gasket was seated & screw the cover right to the roof for a temporary fix. Make sure you attach screws close to where gasket would be under your cover, (about 1"-1-1/2" in from edge of 16" cover) so that the holes will be covered later when AC unit put back on, by the gasket of the AC unit. Make sure you put maretts back on hydro wires & add some electrical tape over them as well to keep maretts on while traveling for now. Don't know how handy you are, but fixing that over the winter may not be as bad as you think. If you need advice later, get back to me/us.
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
Cracks in the top
nice solution should work, and yes bad design by coleman. you can also paint roof with camper roof paint silver with fiber
Jul 07, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Replacing the ''wood'' in the top(ceiling) of a pop up camper. Cant seem to find a correct listing for this in the menu.-----------but this is for a Tracker pop-up camper. It started leaking around the...
i would suggest getting a price on the entire roof assembly from a dealer depending on age these roofs can be lminated togehter ang removing the skin car cause strustural damage to the camper roof it is common practice to stop the leak remove most of the wet wood and overlay what is left standing sounds bad but only way to fix cosmetcally if you need to soarce parts do a search for all right manufacuring they supply celing and metal for most camper manufacures
Jun 22, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
2000 roof-top Brisk-Air
I think you have a high pressure cutoff cycling the compressor on and off. Clean the filter inside the unit. Then with a hose clean out the foil condenser filter on top of the camper. Also you may need to buy a coil comb and comb out bent or damaged areas of the condenser coil on the unit that is above the roof of the camper.
Jun 09, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
63 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
