Question about Car Audio & Video
The volume dial on my onkyo a-9115 doesn't respond with the remote control and there is no sound-how can I fix this?
SOURCE: No Sound - LCD Volume says 99
Found a solution that works. Power down the receiver. Unplug it from the wall. Wait 10 minutes. Plug it back in and power it back up. Worked like a champ to fix this exact problem with my TX-SR601.
Posted on Nov 01, 2008
SOURCE: Remote no longer works for volume control
Guys, I might have accidentally found the problem because the fix worked for me :). I have the RX-V995 and for the last 2+years or so, I had resorted to getting up and using the knob manually for volume control. System will show 'voluem up/down' in the display, but the knob didn't rotate. Same problem as yours.
I was getting ready to buy the service manual, find the knob motor which I thought was the main culprict and replace with a new one.
So I took out the top cover (just a few screws), the front face-plate (again just a few screws. The inner details were all visible. The volume knob circuit board was vertically placed. They were all covered in a good layer of dust. I got my Dyson vacuum cleaner and gently and carefully tried to **** up all the dust that had settled down. With soft front brushes, I agitated the dust I couldn't reach with dyson wand direclty, once dust were loose, dyson did a great job even with picking up those last dust pieces.
I couldn't succeed in taking apart the volume knob circuit board, as I was still awaiting for the service manual. I put all the covers back on and guess what? I used my remote and the knob was moving again. Responding very well, the knob made the full turn, when I was on the remote. It has been working perfectly for the last few days now.
I think I know what was happening. Teh top of the RX-V (and I am sure many Yamaha receivers) are very porous to allow for good heat dissipation. Over time, this allows a large amount of dust to collect on top of the parts. Most parts are electronic (not mechanical) and hence don't get affected by the dust. But the few mechanical parts might have adverse affect if dust settles down in between the rotating mechanisms.
My volume knob had stopped responding to remote command, very slowly. Initially it worked a little, missed a little, then it missed a lot and eventually it didn't rotate. That proves the theory to some extent that if the motor had completely failed, it would stop working from the get-go, not intermittently. Dust build-up provided intermittent contact between the parts and hence the response was intermittent.
The dyson vacuum did a great job in pulling out those fine dust from such parts and amazingly, things are looking very good at present. Honestly, I hadn't the slightest hope that vacuuming would fix the problem. I had vacuumed to make it easy for me to work on the parts :).
So, it doesn't hurt at all to just give it a try. Do open the covers so that you can reach closer to the real boards and parts.
Good luck and let us know!!!
cheers
PN from San Jose, CA
Posted on Jan 28, 2009
  • 239 Answers
SOURCE: remote code for sony playstation 3
you cannot control a ps3 with that remote because the playstation 3 only works with bluetooth. I'm sorry to have to tell you. you can purchase a remote that works with your system at any that sells your system.
hope this helped
please rate well.
Posted on Mar 06, 2009
SOURCE: Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
time warner does not supply the codes. the equipment manufacturer supplies the code to the remote makers
Posted on Jun 04, 2009
SOURCE: TV doesn't respond to the remote control.
surface mount capacitors on ir receiver board are shorting
Posted on Mar 15, 2010
Testimonial: "Thanks I'll be checking them."
The volume control only goes up to +18 on my onkyo t sv919thx. can't hear it
Sounds like the volume controller is faulty. Did you use the master volume knob on the front to increase the power rather than the remote?
Here is your manual. It sure is a complicated piece of kit. They have three service centres on the last page.
https://www.de.onkyo.com/downloads/2/6/5/5/3/Manual_TX-SV919THX_En.pdf
Dec 30, 2016 | Onkyo Audio Players & Recorders
Connect Sharp LCD tv to Onkyo TX8011 Receiver
The Onkyo TX8011 is a Stereo Receiver. Two ways to connect:
1) The HD Cable box should have an audio out (typically red and white). Connect this to the Obnkyo CD input (red and white). The volume may be controlled with the Cable box remote or Onkyo remote. The TV volume may be muted or ON.
2) Connect LCD TV's audio out to Onkyo TX8011's CD input.
This is not a great way to set up, as the TV volume, when moved high, will attenuate (over load) the amplifier, leading to a jarring sound on the speakers. To avoid this, the TV volume should be ALWAYS FIXED low.. say about 30%. Only the Onkyo's volume should be adjusted while watching.
Hope this helps.
Nov 20, 2013 | Onkyo Audio Players & Recorders
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
Bravia kdl52ex700 volume control doesn't work
Look for any jammed buttons on remote, any obstruction like a sticker or gum on the sensor on the TV. If you have such obstructions, the TV will respond only partially.
Aug 15, 2012 | Sony Televison & Video
HOW DO YUHH TURN UP THE VOLUME
You didn't specify the make and model of your player, so I'm assuming it has a control dial on the front. "Turn" the dial clockwise to increase or counterclockwise to decrease the volume.
If your player doesn't have a control dial, please reply to this post and specify the make and model of your player.
Feb 27, 2012 | Audio Players & Recorders
Yamaha RX-V1000 volume control erratic, remote doesn't work. All was well then the volume control knob became erratic (volume would change erratically as knob was turned in either direction, remain...
sounds like you need to take it in to have it looked at. no simple fix unless you are an appliance technician. hard to walk a beginner through. i suggest calling an stereo repair guy.
Fix Ya
FixYa Support
Please accept solution and rate 4 thumbs up! Thanks for your feedback!
Aug 21, 2011 | Yamaha RX-V1000 Receiver
My volume control on my Aiwa surround sound system no longer responds to my remote controller. Everything else works fine using the controller
Assuming the physical volume control on the receiver still works I would say the remote's volume control is faulty.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Jul 20, 2011 | Aiwa AV-D58 Receiver
RCA Home Theater RT2906 doesn't respond to Remote
Have you tried new batteries?
May 16, 2011 | RCA Audio Players & Recorders
Volume control on remote does not always work. Is there something under the button that wears out? How to get inside remote to repair.
Hi, it's easy to fix. Most time when a remote volume control buttons does not work, it's usually caused by dirt inside or water spilt on the remote control, And when the button inside has moist, it responds slowly and does not respond at all.
What to do is this, Open the remote control, you will see a panel inside that controls the button functions. Use a cloth to wipe the all panel inside and close it back. Your done!!!.
But if it still those the same way,that means the damage is beyond repairs, You willneedto get another remote...
Hope it helps.
Thanks for using fixya....
Dec 04, 2010 | Onkyo Audio Players & Recorders
While wathching TV, the typical volume level
Cleared all AV settings and reprogrammed.
Jan 30, 2010 | Onkyo TX-SR703 Receiver
Car Audio & Video Logo
47 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
