Question about E-Machines etower 466is PC Desktop
When I goto shut down the computer it goes through the motions but then it restarts and goes back into windows. In order to shut it down I have to go through and when it starts to boot I have press the power button. Is there a problem with the BIOS or does Emachines need a special to do the shut down properly?
  • Timothy Gore May 24, 2011
    Sorry but there isn't a power options selection in the control panel just power management which didn't do anything. The bios can only be on/off or suspend it's set to suspend. When I just tried it I noticed that it beeps 3 or 4 timer before it restarts.
    Sergeant:
    Champion:
  • 357 Answers
Try this, go to control panel, select Power Options, make sure the section that says "When I press the power button" it says shut down the computer.
You may also want to check in the BIOS where it says what do you want to do when you press the power button, you want both to say to shut off the PC.
I hope this helps.
Good Luck and have a pleasent day.
Posted on May 24, 2011
My computer says its restarting but it hasn't and it wont shut off
Hello, if the Windows operating system, then wait as the operating system upgrades.
Nov 11, 2016 | Computers & Internet
Tip
Tips & Tricks of Windows Operating System.
1) To check whether your window os is activated or not goto Run -> type slui & the window of activation status will appear.
2) To verify the drivers software is sign up by a valid signature certificate or not just type sigverif in run and follow the wizad (ie press start)
3) Various log windows options functions (Goto run and type the following) :->
i.) shutdown -s (for shutting down of computer)
ii.) shutdown -h (for hibernating computer)
iii.) shutdown -l (for logging off computer)
iv.) shutdown -r (for restarting computer)
v.) shutdown -i (gives graphical interfaces)
vi.) shutdown -p (shutdown without any interfaces of messages to administrator account)
vii.) shutdown -f (shutdown forcefully)
viii.) shutdown -s -m\\computername -t 30 f
on Apr 27, 2010 | Computers & Internet
Windows does not start automaticly it gives options like safe modeboot with the last knows config and start windows automaticly. When I click on any option the machine goes off and when I try to repair...
It may caused by the curreption(deletion) of important system files,
You can format and reinstall xp .
Restart computer when booting goes on press F5 Or DEL key to goto bios setup menu change boot order to first cd drive then hdd
PressF10 and press Y and enter.
computer will restart
Insert Xp cd.
Press enter to boot from cd
Follow the instructions
Then your problem will solve.
Jul 18, 2010 | Computers & Internet
Startup fails to complete properly
When on the screen, and you have no icons hold control(ctrl) down and shift key and press escape(esc) your windows task manager should appear, goto the applications tab, at the bottom goto the tab New Task and left click, another window should appear with a text bar, type in the text bar explorer.exe and click ok, all the icons and your normal screen should reapear.
If your screen goes back to normal goto the start bar and goto run or search and type "regedit".
When the regedit window appears left click the " + " sign next to Hkey_local_mechine the the plus sign on software, scroll down to Microsoft folder and click the plus sign, scroll down to Windows nt folder and click the plus sign, the plus sign on Current version folder, then scroll down to winlogon folder and left click on the folder icon, on the right hand side of the screen look for "shell" double click on the icon and delete everything in the text bar and type explorer.exe and click ok and exit out of the window, restart the pc and everything should be back to normal.
pls post back and tell me what happens.cheers.
Jan 30, 2010 | Computers & Internet
My laptop wont boot completley it gets to a certain spot to where io can see the mouse but a black screen, then it shuts down and some how it turns back on again and does the same thing all over again.
>Restart your system
>Goto Safe mode by clciking F8 when your system restart
>Login using admin account
>Goto Msconfig from run
>Goto startup and uncheck the unwanted process and click apply and restart your computer
Aug 14, 2009 | Computers & Internet
My laptop after starting goes to the window xp intro screen then restarts again and again. it wont even recognize the boot disc that came with it
All right, first you gotta check your BIOS settings goto to bbot tab and check the order of your drives at the top must be the CD-rom drive, then check that "boot to optical devices" and "boot to removable devices" are enabled then restart your computer with  a bootable cd and goto repair mode, and perform check disk to the drive in your windows is installed. The command is "chkdisk C: /F /R" hope that helps, please rate the answer
Jan 21, 2009 | Toshiba Satellite P35-S609: Pentium 4-3.2...
Computer won't shut down or restart
chak the ram or fan of prossor
Nov 12, 2008 | Computers & Internet
Shuts Down
Start your computer and goto safemode and enter intot the windows and right click the my computer icon and goto properties and Hardware tab and device manager in that see the usb driver is correctly installed and if not installed correctly .reinstall the usb driver and before that dont connect the any pendive and usb hard drive in the usb port and reboot it. try it and inform to fixya.com if it porb continues bye.
May 14, 2008 | HP Compaq Presario V2000 Notebook
E-Machines etower 466is PC Desktop Logo
91 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
