Yamaha RX-V730 Receiver Logo
Posted on May 24, 2011
My yamaha rx-v730 receiver won't turn on. when i pressed the power/standby button, i can only hear clicking sound and the unit remains off. before, my unit started to automatically turn-off and when i tried to switch it back on, "check sp wires" appeared on the display and then it remained on. but now, it can't be switched on at all. what seems to be the problem and how will i fix it?
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Jun 05, 2007
SOURCE: Yamaha Receiver RX-V630 not working (resets itself immediately)
This maybe an easy one. Have you unhooked all the wires going in to the stereo. "SP wires" means you have wires to the speakers are touching and the stereo is shutting down to avoid overloading. Hope this helps...
Anonymous
  • 3130 Answers
  • Posted on Jun 06, 2007
SOURCE: Immediate shut
Unplug all the speaker wires first, then unplug the unit from the wall for at least 24 hours, The plug back in without the speaker wires or anything else plugged in. Then see if it goes to the protection mode. If it does not, plug in each speaker at a time, and see if any speaker, when hooked up, makes the receiver shut down. If it does shut down, My friend, I'm afraid you will need to take this unit into a repair shop, OR get a new unit. Good Luck
Anonymous
  • 56 Answers
  • Posted on Jun 07, 2007
SOURCE: Yahama receiver Rx-630 not working
The problem might be caused by two major circumstances. 1)Touching wires 2)Overheating. I suggest you unplug all wires connected to the amp then turn on the amp. If it gets turned on then we know that the problem is that you have touching wires. If there is a short circuit somewhere, get rid of it. The ventilation is another important issue that you have to pay attention. It simply causes overheating.
Anonymous
  • Posted on Jun 24, 2008
SOURCE: Yamaha RX-V1 Power
Got the same problem and did some searching.
Strange thing is that next day the amp works fine.
This is what I found on http://www.forums.hcsd.com.au/Blah.pl?m-1210733289/s-8/
SYMPTOM: The power cannot be turned on, or the protection circuit is activated to turn off the power.
CAUSE: Fluid leakage occurs from the backup capacitor C633 0.047F 5.5V (C662 in the case of RX-V3000/DSP-AX2) on the Function PCB and causes a short with the adjacent components and between patterns, resulting in operation of the protection circuit. Fluid leakage tends to occur with this capacitor particularly with high internal cabinet temperatures, with or without the power on. Often, the leakage is only visible with very careful inspection.
SOLUTION: Two types of backup capacitors are now available with a longer expected service life. When servicing, thoroughly clean the leaked fluid from the PCB and from under any nearby components before replacing the capacitor. There are models other than those mentioned above that use the subject backup capacitor. Check them for fluid leakage and replace the capacitor as needed.
PART(S): Old
Ref. No. Part No. Description Remarks
C633 or
C662
VT740700
V3860300 ELECTROLYTIC CAP 0.047F/5.5V Vertical type
* VU545000 ELECTROLYTIC CAP 0.047F/5.5V
Horizontal type
New
C633 or
C662 WD294400 ELECTROLYTIC CAP 0.047F/5.5V Vertical type
* WD292000 ELECTROLYTIC CAP 0.047F/5.5V Horizontal type
Marek Podmaka
  • 127 Answers
  • Posted on Mar 02, 2010
SOURCE: how can I reset all settings on my yamaha rx-v730
Use Advanced Setup mode - see the manual. From standby press both STANDBY + STRAIGHT buttons, then choose INIT / ALL.
How do I reset my Yamaha Rx-a730
How do I reset my Yamaha RX-V730 A/V Receiver? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 31, 2013 - I'm stumped on how to reset this receiver. I have no remote and just purchased a Powered sub woofer and it doesn't work that loud through the ...
RX-A730 - Yamaha Downloads United States
download.yamaha.com > Support > Downloads
13 items - ... About Yamaha. My Account ... Downloads for RX-A730. Find Your Model .... RX-A730 Owner's Manual, 14.07 MB, 4/17/2013. French, Manual, pdf ...
How do I reset my RX-V1800 parameters to the factory ...
faq.yamaha.com > Support > FAQs > Search Result: RX-V
Nov 13, 2010 - YAMAHA ... Power the RX-V1800 back on using the [Master On/Off] button and the receiver is now set back to the original factory settings.
Resetting/Initializing the receiver to factory settings - RX ...
Yamaha RXV-730 6.1 Channel A/V Receiver
the clicking may have been coming from the relay itself, but it doesn't simply mean that the relay is faulty. clicking may also be caused by transformers, indicating that some electronic components have developed SHORT CIRCUIT. try measuring resistance of transistors and diodes near the power unit (unplug/turn the unit OFF of course) check also for the impedance of the output power transformers.
check the amplifier IC for short also.
Can I download the speaker wiring instructions for surround sound, lost mine
try here : https://www.manualowl.com/p/Yamaha/RX-V730/Manual/87206
How can I reset all settings on my yamaha rx-v730 to factory default?
1helpful
Yamaha Rx-v730 - only hear "click" when try to turn it on
That may due to a bad power transistor, huge current flows when it's powered up, protection circuit kicks in and switch off the unit. Get to repair shop for check up and replacement.
1helpful
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
How do I turn On/Off my RX 596 reciever with my Yamaha remote ?
Press the Standby/On button on the remote or on the receiver (right below the Yamaha logo) to stop the audio output and display. The RX-596 goes into a low power standby mode when not in use; this allows it to respond to the remote when you press the buttons. If you want the receiver's power use to go to zero, you need to unplug it from the outlet. (You could also use a switched surge protector and push the switch to off.)
See page 9 (page 11 in the PDF) in the manual for the details on the On/Standby switch. The manual is available here: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000057561.pdf . The page is also available here: https://www.manualslib.com/manual/197512/Yamaha-Rx-596.html?page=11#manual .
I hope this helps.
2answers
Yamaha av receiver rx-359
go to best buy and buy a new recever
6helpful
2answers
Yamaha RX-V850 receiver
how can i hook a subwoofer into yamaha RX-V850
Unit powers up for about two seconds and then dies.
Are all the speakers connected?
Most A/V amps will go into standby if the speakers arent detected
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
