Question about Konica Minolta DiALTA Di200 Copier
Can I get the procedure to replace a fuser lamp in a Minolta Di351 fuser.
  • 1 more comment
  • Tim Thies May 24, 2011
    I didn't ask you how to remove the fuser I asked how to replace the Heat Lamp. I have the fuser removed.
  • Tim Thies May 25, 2011
    I first asked to get the procedure to replace the Heating lamp on a Minolta Di351 fuser. I recieved the procedure to remove the fuser, I obviously have the fuser removed I need to replace the heater lamp. Please help!!!
    My e-mail is
    a1officesolutions@hotmail.com
    Thank you so much
  • 910 Answers
The Fuser Unit or Eraser Lamp should come with Instructions on how to replace it.
Below is a link to the service manual which details where these are located.
http://www.akitainfo.net/knowledgebase/Manuals/Di%20Series/Di251_351/Documentation/Service/GeneralSVC.pdf
Posted on May 25, 2011
  • 2,098 Answers
The procedure is in the service manual of your model no.
May I know your email add, I will send to you the copy.
Jdvillanueva
    President:
  • 1,216 Answers
You remove the back cover, I believe it is 4 phillips screws.
Then you will see the fuser unit. There are 4 more phillips screws to remove and a couple of connectors to unplug. Then pull the fuser back and out and replace.
Posted on May 24, 2011
Lamp error
How do you know its a lamp error?. if it is the scanner lamp its located under the glass. And you replace the whole module not just the lamp, or is it the fuser lamp, you just replace the whole fuser section which is the Hot part.
Jan 19, 2014 | Konica Minolta PagePro 1390MF All-In-One...
Konica Minolta di351 error m4
Utility button, meter count, stop 00 stop01 now in service mode, now "stop 9" touch copy kit touch set, press clear, 10 key pad enter value ? touch current.
Sep 17, 2013 | Minolta Di351 All-In-One Laser Printer
Co510 code
One of the parts in the list below are causing "Low fuser teperature"
C0500: Warming-up failure
C0510: Abnormally low fusing temperature
C0520: Abnormally high fusing temperature
Relevant Electrical Parts
Fusing Roller Heater Lamp H1
Fusing Roller Thermistor TH1
Fusing Roller Thermostat TS1
Fusing Roller Heater Lamp Fuse TF1
Side Cover Interlock Switch 2 S3
Power Supply Unit PU1
Master Board PWB-A
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 03, 2011 | Minolta Di351 All-In-One Laser Printer
Hi have an error call service 6000:0085594 My printer is Kyocera Fs-2000D If you can help me pls
Code: 6000
Contents: Broken fuser heater lamp wire
30 ppm model:
The temperature does not rise 1×C after
the fuser heater lamp has been turned
on continuously 5 s.
35/45 ppm models:
The temperature does not rise 1°C after
on continuously 10 s during waming-up
or at standby.
Causes:
- Poor contact in the fuser thermistor M connector terminals.
Check procedures/corrective measures:
- Reinsert the connector
Causes:
- Fuser thermistor M installed incorrectly.
- Check and reinstall if necessary
Causes:
- Thermal cutout triggered.
- Check for continuity. If none, replace the thermal cutout
Causes:
- Fuser heater lamp installed incorrectly
Causes:
- Broken fuser heater lamp wire.
Check procedures/corrective measures::
- Check for continuity. If none, replace the fuser heater lamp
Jan 31, 2011 | Kyocera FS-2000D Laser Printer
At startup the Minolta 1031F as a flashing C 50 on the screen
Verify the continuity of the fuser heater lamp.90% the lamp is open.You need change the fuser lamp and the fuser roller(the heater lamp is in the roller and is not detachable).
Nov 03, 2009 | Minolta EP1031/1031F CS/PRO Copier
Get message of fuser low therm 1F
One of the two small thermostats, that are called "snap-action disc thermostats" and control the electricity flow to the fuser lamps, has likely gone bad. If you are feeling generous to the money pit governed by Konica-Minolta, you'll need to replace the fuser unit. Otherwise, you'll probably need to locate and replace the bad thermostat. If you are not electronics saavy, I recommend taking the fuser unit to an electronics shop and asking them to check for and replace any bad thermostats.
As an explanation, these thermostats work just like the thermostat for a typical home central heating system. While in use, they keep the fuser temperature between 130 and 150 degrees by turning the fuser lamps (the parts that heat up the fuser) on and off. They do this by allowing electricity to flow to the fuser lamps until the temperature of either thermostat reaches 150 degrees. Once that happens, the thermostat will turn off electricity to the fuser lamps, allowing the temperature to cool back down to about 130 degrees. Once the temperature returns to 130 degrees, it allows the electricity to flow again to repeat the process.
Jun 08, 2009 | Minolta magicolor 2200 DeskLaser Printer
Error code c0500
open back coever then press reset switch from mainboard
Sep 26, 2008 | Minolta Di2510 All-In-One Laser Printer
Have a Minolta Di351 with error code C0510. How can I fix it?
C0510 Low fuser temperature after warm-up
replace thermistor in fuser unit
Aug 12, 2008 | Minolta Office Equipment & Supplies
Minolta Di351 Dialta
Try shutting the copier down and then unplugging it from the wall for 15 minutes.
If this does not reset the device, a technician is required.
Jun 10, 2008 | Konica Minolta DiALTA Di200 Copier
Konica Minolta DiALTA Di200 Copier Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
