Question about Garden
Husqvarna RB150 - blades don't turn when I switch them on.Belt is on the wheels and have checked the electric connections ?
  • andrew153 May 24, 2011
    The blades were working and then started to work intermintently .The seat switch has been removed long time ago ?
  • 5,687 Answers
Hello, Try listening for a click from the electric pulley clutch when you activate the blades. There should be a fuse holder close to the battery with an Automotive style colored fuse. If that is not blown, then unplug the connector for the electric clutch and use an Ohmmeter to check the wires from the clutch side of the connection. There should be continuity in the clutch.
If there is no continuity the clutch is bad. There are a few safety switches like your seat switch which will kill the Ignition and/or the blades if you get off the machine while it is running. If your model does not kill the engine when you leave the seat, then it is wired to stop the blades from rotating when you leave the seat.
There is another switch on the clutch pedal which sometimes gets grass clippings packed around it. Some models are made so they will not let you ride the clutch pedal and cut at the same time. The clutch return can not get to its normal height because the grass clippings are packed around the safety switch. You just need to clean away the debris jamming the switch.
In conclusion, when you check the electrical parts, the safety switches may be cutting power or a ground to a Relay. You would need weight on the drivers seat to defeat the safety switch. That is why an ohmmeter is useful and unplugging each component and checking for continuity in the component is your best bet.
Posted on May 25, 2011
  • 2,418 Answers
Two things will keep the blades from engaging. One is the mower is not charging the battery at the proper voltage. You will have to check the voltage output to the battery with a volt meter. Next to check, is the switch under the seat. This switch if not working proper or not making contact will think no one is sitting in the seat and will not allow the blades to come on. Hope this helps Fix Ya up.
Posted on May 24, 2011
  • John Fourteen Six May 25, 2011
    If your seat switch is by passed. You can look for voltage to the clutch, some models have a 2 wire harness to the clutch, one wire is hot from the dash switch to the clutch one wire is a ground back to the battery Negative post, or a junction at the frame. Another has one wire that runs to the clutch and the clutch has an internal wire to ground. If you have a one wire harness you can run a straight Hot wire from the battery to this wire and see if the clutch will engage. I would tell you to check this wire to the clutch for a break or bad connection at a plug or along the routing. Check this and get back to me with anything you find.
I have a 52" Husqvarna LGT 2654 riding lawn mower and when I engage the blades, the belt does not turn the pulley system. What could be causing this, the pulley idlers, or the belt?
depending on the age of the machine, there could be several possibilities
1-- belts are not tight enough--- belt tension system is not correct, wrong length belts
2--bearings for the shafts for the blades are rusted up and seized - preventing the blades from moving--- switch the machine off , disengage the belt drive and see if you can turn the blades by hand
3--- if you have an electric pto system to drive the belts to the blades then that system is not getting full power to engage the PTO or the clutch is not working--worn facings
take it to a service dealer and have a proper diagnosis done
May 09, 2016 | Husqvarna Garden
My Husqvarna LGT 2554 deck hung up on high spot mowing. Turned off deck & mower pushed by hand. Engaged deck,started to mow, wound to stop. Belts fine. Pull up on knob to engage, you get nothing.
The engine runs but the blades do not engage? Make sure the wire connecting the electric clutch is still plugged in. If all is connected and the belt is really fine, there is a problem with either the electric clutch or PTO switch.
May 21, 2015 | Husqvarna Garden
Blades will not engage on a 48/24 zro turn husqvarna lawn mower
Check under the unit and make sure the 2 wires going to the electric clutch are connected. If they are and are getting 12.5 volts, check the PTO switch to see if it is good or bad, this can be done with an ohm meter.
Sep 21, 2014 | Husqvarna Garden
Mahindra tractor diagnostics
You are going to have to disconnect belt and try to turn pulleys on drive system to locate the excact location. It sounds like a belt tension or bearing problem to me.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Jul 19, 2013 | Husqvarna Garden
Looking for the blade pulley belt routing diagram on a 23 hp 48" in. husqvarna
See pages 18, 19 and 21 of this manual. This model has 2 blades. I don't know your model number so could not download EXACT model manual. These diagrams and pics are very clear. Hope it helps.
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_USen/HUSO2010_USen__532436505.pdf
Sep 04, 2011 | Husqvarna Garden
I started the mower but the blades will not turn. I shut it off and was able to manually turn the blades by hand. I also was able to turn the belt wheel under the engine and have it turn the blades. ...
Most all riders have a safety seat switch now and they do malfuction alot. They are under the seat and are ez to replace most of the time. First look for a wire that is grounding due to rubbing a sharp object. That can be fixed with black tape
Good luck!!!
Jul 10, 2011 | Husqvarna 23 Hp 48" Deck Yard Tractor
My bottom blades on my Falcon X Helicopter don't turn. I've looked and it seems the spinning bit connected to the engine (green coloured) is sitting right below the wheel connected to the blades....
I think the problem is the green pinion drive gear, either it has already crack on the sides that's why it moves to another position.
You could adjust the green gear by pushing it where the big gear( wheel ) turns. There is a screw at the side of the propeller where you could tighten it to the point it can have a contact with the green gear.
You could buy that green gear in the internet.You don't have to disassemble the whole thing.
Hope that helps you out.
Thanks for using FixYa!
Jul 07, 2011 | Falcon Radio Rc Helicopter
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Husqvarna 17530 stalls when engaging the blade. Seems to run fine else wise/
Does engaging the pedal for the PTO lug the engine down, or does it just die like turning off the key?
If it lugs the engine down, then you need to make sure you can spin the spindle and idler pulleys by pulling the belt by hand. You should be able to slip it around the engine pulley enough with the blade pedal disengaged. Pull the belt up tight so the slack is around the engine pulley and try to spin the blade spindle and idler pulleys.
If it dies like turning off the key, then its likely a safety switch and may require a meter to test which.
The seat switch is has a shunt in the circuit that must be satisfied in order for the rest of the circuit to be happy. Make sure the connections are good, the pins inside the amp connectors will sometimes spread, push out of the lock etc. and if connection is lost will not work. Otherwise a new seat switch will be needed. You might check the PTO switch for continuity, without a diagram or schematic I am not sure how your circuit is wired. you have to have the parking brake engaged to get off the mower while the engine is running and the PTO is Dis-engaged?
I don't know if your "go" pedal eliminated this switch or not. But if with the parking brake engaged and the PTO disengaged, you lift off the seat and it dies, then its the seat switch.
Hope this helped Tim
May 21, 2011 | Husqvarna 24HP 54" Yard Tractor ()
Garden Logo
250 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
