Question about Sony DNF420PS Walkman Personal MP3/CD Player
I have a Sony Psyc CD Walkman D-NF420. It had a problem reading discs. The disc spins and the laser moves along the rail. The screen showed "no disc." The radio works fine. I opened the unit and found the gold ribbon to be disconnected. I was excited and plugged it back in. When I tried to play it, nothing worked, no CD, no radio. If I go in and unplug the ribbon it goes back to the way it was. I would like to fix it if possible. Thanks.
SOURCE: Need Manual for Sony Walkman DNE320 (Brand) PSYC Atrac3plus Mp3
download it here
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=a258f7b4563a4e08e235f565ee8d7231&q=Sony+D-NE320&e=1
Posted on Jun 12, 2008
SOURCE: Moved CD changer with discs inside - won't "reset" / work
CD PLAYER WILL RESET BY ITS SELF WHEN MAINS SWITCH IS PUT ON, SOUNDS LIKE YOUR MECH IS JAMMED TRY TO FIGURE OUT WHICH GEAR UNLOADS THE PLAYER DRIVE AND ALSO UNLOAD MANUALLY
Posted on May 18, 2007
SparkGap
  • 363 Answers
SOURCE: Cd player cant read disc
Check that the disk is still spinning. If not then suspect the spindle motor
Posted on Oct 01, 2007
welcomejee
  • 10594 Answers
SOURCE: Sony CDP-C235 CD Changer Dirty Laser Problem
Please replace optical block (laser) of CDP-C235.
It is available in Part Store.
Posted on Jan 15, 2009
SOURCE: no sound from cd but stereo works no problem
there are 2 blue wires........dont hook the blue to blue!!!!!!!!!!!!!!!!!!!!!! hook blue to the blue/white wire!!!!!!!!!!! problem solved. so e-z huh? lol i did the same thing.
Posted on Feb 28, 2009
PS2 Modchip and Laser Fix installation Failure ...
I bough ps2 with cracked after 3-4 days not working dvds are not read.
sometime it's working some dvds..
so plz solve my problem...
May 28, 2012 | Sony PlayStation 2 Slimline Console
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
Apr 16, 2012 | Sony 5-Disc CD Changer with SA-CD Playback
Hi. I have a Sony MZ-N710 Mini-Disc Walkman which wont read discs and also does not charge. If power is connected via the charging station or directly, or via external battery adapter the spinning disc...
Possible that the optical head unit has failed in your walkman and might need a replacement. It will be adviceable to seek the cost factor of a replacement unit of Sony that might turn out expensive ... to the entire cost of the set.
So unless the optical head reads there is no data transfer or processing.
Nov 03, 2010 | Sony MZ-DH710 Personal MiniDisc Player
CD player stopped working on Sony ICF-CD831 PSYC Clock Radio/CD P
I've been able to prolong the life on mine by doing this:
Insert the disc, then spin it by hand and quickly close the door and hit play.
It's always worth using a laser cleaner first, as it may just be dirty and stops spinning because it cannot read the disc.
Apr 26, 2009 | Sony PSYC ICF-CD831 Clock Radio
Sony PlayStation 2 - Does not read CD
IT IS THE EYE. the eye th the little shiny piece that you can bairly see once the tray comes out.you might have put a disk in at a wrong position and scratched the eye. replacing it might be what to do, but i would check first.
Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
Sony cd walkman reads but won't play
If you have a small enough screwdriver and some time it's not too hard. I just fixed one of my kids' walkman (same make & model) yesterday. The motor that spins the gears that makes the laser assembly move back & forth came loose. There is a single screw that holds this motor in place. They should use some lok-tite or similar when they assemble these things.
Jun 03, 2008 | Audio Players & Recorders
PS2 not reading disks
Your lazer lense has bit the dust. Depending on your model type the first gen systems lazers are very easy to replace. The later versions sony made it harder to replace. You can find out what model you have by looking at the back of your PS2 then you can either call sony or go to there website and find out what generation PS2 you have. Then go from there. Hope this helps
May 08, 2008 | Sony PlayStation 2 (PS2) Console
Blinking "disc" error
Hi Lambo, 1) Your disc may be bad: scratches on surface, the surface maybe dirty, the disc is maybe bended,... Try with other discs, if the error occurs see next steps. If not, the initial disc was bad, but don't throw away, you may be able to clean it. 2) The Laser-optics in your Walkman can also suffer: - open your Walkman as if you would load a disk; look inside and you will see a little lens inside: clean it by using a ear-cleaner ( little stick with cotton on one or both ends). First dip the cotton end in some pure natural alcohol ( ethyl) and wipe very carefully over the little lens surface 3) The drive-mechanism of the Laser may also be cause; the only thing you can do on the field; the little lens ( see 2 ) normally should be near the end of a channel which you can recognize as the cut-out of the plastic . While reading a CD the lens moves thru this channel. You can try to push very softly this lens towards the nearest end of the channel. It often helps. 4) The Laser can be to its end of life; you can ask to change the opto-electrical mechanism, but I'm afraid it will cost you nearly as much as a new player; if you can buy a second hand might be even cheaper. Important for the future: - don't write with markers on discs; these texts release small quantities of fumes on laser-lenses - smokers pollute also with nicotine-fumes their lenses and discs Hope you can get nice music ASAP; let us know
Nov 01, 2006 | Sony Walkman D-EJ100 Personal CD Player
116 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
