Question about Philips Magnavox 51MP392H Rear Projection Television
Color out of line - Philips Magnavox 51MP392H Rear Projection Television
  • Philips Master
  • 3,459 Answers
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid color out of line - 65af323.jpg>
65acolor out of line - 69189a5.pnglass=
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Jun 02, 2011
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Tip
How To Reset Your Mobile Phone
You can return your phone to its original state, as it was when it left the factory. This is also called a hard reset. You might want to do this if you are giving your phone to a friend or relative and you want to remove all your data first, or if your phone has a persistent problem that is not solved by powering off the phone and then powering it on again.
A factory reset is a drastic measure. It permanently erases all your personal data and customized settings, and also removes any programs you have installed. Make sure that you have backed up the information and files you want to keep.
As different phone models have its own reset procedure, view complete list here.
on Jul 09, 2011 | Cell Phones
Tip
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
REQUIREMENTS:
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. lifetimer.pm file: Download Here
PROCEDURE:
1. Download and Extract the lifetimer.pm file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted lifetimer.pm file on your PC.
11. After the lifetimer.pm file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
Caution:
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
I am printing pictures and they have a white line running through them, what can i do
Does the white line appear in all colors? Or is it limited to just one color? Try printing some full pages of each color (use a gray scale to save on toner, 50% shade should do). If the line appears in only one color, then replace that toner cartridge. If all three colors, then replace the drum.
Nov 25, 2014 | Konica Minolta Magicolor 1600W Printer
Printer output has shadows, blurring, streaks, lines, poor color
Seem like blocked hole(s) on the color print head...
Most likely if there is a deep clean option then do it (may need a few times to unblock a hole or never).
Also get the printer physically cleaned up if you can see dusts inside (vrtical lines on color bars).
Mar 20, 2009 | HP DeskJet 9800 InkJet Printer
Tip
How to setup your EPSON FAX
1. Connect the supplied phone cord with one end to a phone jack and the other end to the LINE port of the unit. Make sure that the phone jack has a dial tone.
Note: Nowadays a lot of people are using a VOIP Service, keep in mind that the FAX was invented to work on an analog phone system (yeah the regular phone) and this new phone system might result in FAX transmission failures.
2. Default FAX settings works fine. The only time you need to configure it is if you have a phone or an answering machine connected to the unit.
3. To test if you can receive fax, go to http://www.faxzero.com (a free fax service) and send yourself a fax message.
4. To test if you can send fax, a friend's fax number is recommended.
on Nov 06, 2008 | Epson Stylus Multifunction Printer/...
Horizontal lines in pictures
If you are using original cartridges then there should not be a problem. The horizontal lines come from the cartridge. Can you pinpoint if it is a color or black line that is missing? My guess is that during the alignment procedure, you are asked to choose a number or letter that corresponds to picture of a the lines that show the best alignment. If you did this correctly, may I ask how many pictures you printed before seeing that line. Is it on the first print or 10th printing? Cuz if it is on the 5th or more full color picture, then the problem is that you you really have the wrong printer. The F380 capacity for printing full color pictures is miniscule. 1 ml per color. So usually after the 3rd color picture, the ink starts to run out. Let me know if this helps.
Apr 23, 2008 | HP DeskJet F380 All-In-One Printer
Color print lines
try to replace with colour catridge bye
Sep 24, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Philips Magnavox 51MP392H Rear Projection Television Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
