Question about CSi Speco PBM-30 2-Channel Amplifier
I am using the amp. in an office application to have sound in multiple rooms. I use XM radio thru a radio to the amp. It has worked fine, but I am now unable to get volume thru the amp. That is I can faintly hear the sound. I am also getting alot of "buzz" with the sound. HELP?
    Top Expert:
  • CSi Speco Master
  • 74,243 Answers
Hello
You may have connected your XM with amp by aux input connection of the amp. Just unplug the connection and switch ON your amp only. If you hear this Buzz sound even the XM disconnected, surely your amplifiers' output section has damaged. Advance the volume of the amp, in this condition, and if the Buzz sound increase with volume, the amplifiers' tonal stage has got damaged. If you feel the amp is silent and the fault occurs when XM is connected, XM's audio output has damaged. If you gets only Buzz sound from XM, retune your XM and check whether it helps you. If it does not help, check your XM subscription details. If it is ok, and still XM didn't accept, the XM recevers' tuner section has got damaged, and it is irreparable. OK.
Posted on May 24, 2011
Xm radio wont work on toyota fj
hummmmm sounds like maybe you aren't paying for the service anymore .
Mar 11, 2015 | XM Radio Car Audio & Video
MANUAL FOR XM SKYBOX
Unit is very straightforward to operate. Hold down O/1 button for power. Use the "mode" pusbutton to cycle thru AM/FM/CD/AUX/XM. Treble & Bass settings are made by turning the 'tuning' knob.
For radio and satellite presets, hold in the numbered pushbutton until it beeps, and then it's set. You should be able to hear previews on XM channel 1,and that will help you with antenna setup. I highly suggest using the remote XM antenna. The built-in XM antenna need to be put 'propped-up' outslde, otherwise you have to use the external antenna. Use AC power as it eats batteries, or use rechargeable D batteries. Let me know if you have any more quesions. okay?
Dec 02, 2010 | XM Radio Audio Players & Recorders
My xm plays extremely loud thru my car stereo.no matter what i set the volume at.it is either off when volume is set to zero or loud at any other setting.changing the output level on the xm receiver does...
Are you playing it directly thru your FM antenna connection, or using the RCA jacks? You have to set the FM modulator level. It is also possible that you have a new FM radio with a type of ALC that will raise the lever regardless, but your regular car radio volume control should work. do not wire this directly to a power amp, as you won't have the control that you need. Good luck, let me know more.
Apr 01, 2010 | Terk XM Commander Satellite Radio Receiver
I have XM radio in my chevy malibu. Worked fine
I believe when the antenna loses power it does not show it on the screen sounds like there might be a break in the antenna wire or simply came out of socket in the rear of the radio.
Nov 03, 2009 | XM Radio (XMP6000)
No sound from radio
check to see if the left and right channels r working i dont meen turning dial left and right you hear sound out of lft and rt also ballance is centred
Aug 01, 2009 | 2005 Chrysler Pacifica
Bluetooth XM not meshing
does xm adapter have a pass thru port on it as in mine is sirius and i have radio changer output pluged up to the sirius unit then from sir changer output i have the bt100 plugged up and mine works great
Jan 06, 2009 | Kenwood KCA-BT100 Wireless Headset
I can't get my audiovox XCS9 XM Radio to work in my home
Check to see if youre cable is plugged into the line out jack. If that is not the problem you may have a defective cable or home adapter
Aug 23, 2008 | Audiovox XCS9 XM Radio Receiver
Xm radio
How do you use fm radio signal to access speakers, in lieu of cassett adapter?
Jul 22, 2008 | XM Radio (XMP6000)
XM Loading Problem for Volkswagen
I had the same issue. I called XM multiple time to have the signal resent. I told them I was receiving the preview channels and nothing else. I asked them multiple times if it could be hardware issue and they said no. I took it to the dealer and they ran a test ($98) and determined that the unit had failed. They didn't charge me for the $800 unit, but they did charge me $300 for the installation. Its working fine now.
May 26, 2008 | XM Radio Dual XMP7000 Auto In-Dash CD...
CSi Speco PBM-30 2-Channel Amplifier Logo
37 people viewed this question
Top CSi Speco Audio Players & Recorders Experts
ELECTREPAIR USA
ELECTREPAIR USA
 Grubhead
Grubhead
Are you a CSi Speco Audio Player and Recorder Expert? Answer questions, earn points and help others
