Question about Maytag MBR2562HES Stainless Steel Bottom Freezer Refrigerator
The freezer is on the bottom of the fridge...and the bottom part of the freezer is forming a block of ice..just over 1 yr ago that i purchased the fridge. i tried moving things in the fridge forward so there is room at the back of fridge for ventilation. removed the ice and the next day there wasn't any more ice but the following day there was more ice accumulating on bottom of freezer..not sure why ice is forming on the bottom of the freezer..any help would be really appreciated.
  • 3 Answers
There is normally a "thing" that controls the auto defrost I had a freezer that started so it this out of the blue. Some how that "thing" got unplugged. It was in the freezer behind a panel in the back by the light.
Posted on May 29, 2017
SOURCE: Bottom of freezer has water dripping into it
We had a similar problem. It ended up being a frozen pea that fell down into the defrost drain and was blocking the water from draining out each time the freezer defrosted.
Posted on Aug 23, 2008
bobicehouse
  • 1524 Answers
SOURCE: MZD2768GE Maytag S/S Refreg/Freezer freezer side coils iced up.
Yes to both questions.
Posted on May 04, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Maytag Plus MSD2556AEW - frozen puddle on freezer floor
Here I am going to give you a lot of information. Because of the leaking your defrost condensate drain is most likely the reason. All on the page below may not be for your situation and some refrigerators do this over a period of time and the the water has no were to go but the freezer during defrost. Click on link below, Thanks, Sea Breeze
HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
Posted on Aug 17, 2009
Testimonial: "Thanks Sea Breeze! The photos do show a bit of a different arrangement than what is on the back of my fridge but I'll try what you suggested."
SOURCE: Ice accumulation on the bottom of the freezer
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 06, 2010
I have the same problem. After openeing the back panel from inside, I noticed a big ice in the drain. I removed it but pouring hot water spills the water out of the freezer and on the floor. Should I continue doing this until the drain opens up? If so, where does the water deposits? Is there a bowl or something that I need to empty out? Here is the picture of inside the back panel:
Posted on Jun 07, 2010
What is wrong when the icemaker leaks into the inside of the fridge
ok unplug frig open freezer door empty ice let freezer door stay open for a few hours ice has formed where the ice cube water comes into it. ice built up and water sprays every where but where it should
Aug 19, 2014 | Refrigerators
Amana freezer forms ice on the bottom. We have taken it apart, cleared ice from coils and drain, turned down freezer temp, but it still happens. Fridge works fine. Any other ideas?
When you see that ice forms on the bottom of your freezer it is most likely means that the drain hose of the fridge is blocked.
You will need to take the panel inside the freezer off, clear all the ice and pour hot water into the drain hole until you hear the water coming out at the beck where the compressor is located.
The next step would be running a 1/4" hose thru that hole.
Good luck.
www.QuickFixAppliances.ca
Oct 07, 2013 | Amana ARB8057CSR Bottom Freezer...
Frost is building up in bottom freezer. Appliance is running nonstop. I believe that the freezer drawer has been shut completely. Foods in refrigerator section are fine; foods in freezer section are...
Frost can build up for multiple reasons. Most common is the start os an iceblock. Other reasons can include condensation from door being left open or opening too much. It can also happen from backsplash from the inlet tube for the ice maker. If the fridge is running non stop. It sounds like the ice block is forming and the temps are not getting to the program temps. If at factory setting the freezer should be at or around 0 degrees and fridge should be between 42 and 48 degrees. Has the fridge shutdown at all to go into defrost? The defrost timer may have went out and is causing an iceblock. If there is an ice block always change bimetal/ defrost thermostat.
If you need any further assistacne please feel free to comment me.
Jul 27, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Ice forming on the back of side by side 17 yr old fridge
You have a bad defrost heater . To access , you will have to remove the inside rear freezer panel . The heater is located at the bottom of the coils . Take your model number when ordering the part so you get the correct part .
May 02, 2010 | GE Refrigerators
Water leaking from top to bottom
Refrigerators typically have vents for COLD freezer air to travel to the refrigerator side. Make sure you do not have these blocked with frozen foods, or ice. A good defrost of the freezer may be in order. (I just went through this one week ago).
If the cold air does not travel down to the fridge to keep it above dewpoint, moisture begins to form quickly.
May 19, 2009 | Refrigerators
Ice on bottom of the freezer
Your drain is blocked causing the ice in the bottom of the freezer.
The drain is located about 7 inches up from the bottom rear of the freezer.
Just below the back freezer panel.
Turn the fridge OFF.
Remove the bottom bins.
Take a hair dryer and thaw the ice in the drain.
Pour 1/4 cup of bleach in the drain line.
Problem solved.
Feb 24, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
My Bosch frostfree fridge freezer keeps icing up!
My Bosch Frost Free Fridge Freezer did the same thing - Ice forming in the bottom of the freezer area after a few days.
It was caused by a blocked drain pipe - When the freezer does the de-frosting cycle, the melted ice drips into a tray and tehn runs into a dish on top of teh compressor, through a pipe.
If this pipe gets blocked, the de frosted ice overflows from the tray and overflows into the bottom of the freezer and then re-freezes !
To fix, pull the freezer away form the wall, locate the pipe that runs to the dish on top of the compressor and blow through it - This should clear it. Alternatively, from inside the freezer compartment, pull off the cover at the back, but the clips holding it on will probably break off, as mine did ! You can sort of push the cover back on and re-fit the food draws.
Feb 23, 2009 | Freezers
Bosch KGU40124 water leaking from freezer
remove freezer back panel and you will see a tray at the bottom with a drain hole in the middle and it is this which is blocked. if blocked with ice, clear with some hot water and make sure drain is free and water flows away
Nov 05, 2008 | Bosch KGU40124 Bottom Freezer Refrigerator
Top Freezer working, Bottom Fridg not.
ice block has formed in the air exchange from the freezer to fridge. Turn off and thaw out, afterwards, check to see if the fan motor is running unobstructed. If problem persists, replace fan motor with new
Aug 10, 2008 | Kenmore 64802 Top Freezer Refrigerator
Frigidaire FRT18HB5DW2 fridge not cooling
Sounds like an air flow problem to the lower unit. Take the sheetmetal or plastic rear cover off the freezer back wall and make sure the coils are frosted up good and even but NOT a block of ice inches thick (air needs to circulate and a blocked coil won't let air move over it efficiently). Make sure the fan is running to move the air around. In the fridge area make sure the air dampers are letting the cold air from the freezer down to the fridge compartment. Depending on what you find will determine the next steps so let us know.
Dec 27, 2006 | Roper RS22AQXKQ Side by Side Refrigerator
Maytag MBR2562HES Stainless Steel Bottom Freezer Refrigerator Logo
51 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
