Question about Magellan GPS
My magellan 700 works intermittently. It works if I unplug and replug several times but then just shuts off at will.
  • deedikeman Aug 15, 2008
    I just tried to plug it in to get info off of the GPS re: software and it no longer comes on at all.
    I plugged it into the power supply in the car and it won't come on. I'm not sure what other kind of power supply would work/there is.
    Master:
  • 521 Answers
Battery drained check it and replace if necessary.or any loose wire connection.also check that.thanks
Posted on Aug 15, 2008
    Genius:
  • 1,142 Answers
You need to update the firmware and that should take care of the unit.
  • 594 Answers
Here is the link to your product. i could not find anything about it shutting off at will. but you can ask someone there. i would do it for you except i do not have the product so i would not be able to get the information they needed fast enouph.
https://www.magellangps.com/support/
i hope this helps.
please do not forget to rate and comment about your experiance today.
  • Cameron Viseth
    Cameron Viseth Aug 15, 2008
    you will need to copy and paste this into your browser.
  • 6,487 Answers
You can try to update the sofware of it and that should fix the problem...
Good luck........
  • Mark Gil
    Mark Gil Aug 15, 2008
    Try to plug it to a power supply and check if it will power on, but not there's a possibility that the unit is dead already that may need repair or replacement...
  • Mark Gil
    Can you plug it to a power suplpy where do you usualy plug it just to check if it will power on? because if still didn't power on that there's really a problem with the unit...
Dryer beeps intermittently when not operating
YOU NEED A NEW ELECTRONIC CONTROL BOARD. I HAVE SEEN THIS MANY TIMES.
Apr 24, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Intermittantly freezes on playback. Toshiba rs-tx20 dvr
shut down tv/dig box/dvd. unplug and then leave a little (cuppa time)
replug .then start up dig box then tv then dvd.sounds like in need of "reboot"
Sep 01, 2009 | Toshiba RS-TX20 DVD Recorder
Magellan RoadMate 700 GPS does not work properly
It seems that Magellan is not good with the power connectors on their units, I believe the problem is with the power adapter plugged into the cradle. Sorry I have no information about a repair center. Usually for an absorbent amount of money, Magellan will repair.
Dec 23, 2008 | Magellan RoadMate 700 GPS Receiver
My Mgellan 700 was working fine for many years.
ok56,
Thanks for using Fixya 1st of all.
This problem has surfaced MANY times. It has been solved by numerous solutions. Without replacing the circuit board behind the keypad or the LCD I do NOT know a way to solve this. There never was a definite solution that remedies this. Possibly unplugging/replugging the ribbon cable from the LCD. Sorry I couldn't be of more assistance. Let me know if anything changes.
-Daniel
Nov 15, 2008 | Magellan RoadMate 700 GPS Receiver
Downloading new version 6 to my roadmate 700-760 gps
I had a very similar problem downloading the new version for my roadmate 700 as well. I chose to shut system down .I then unplugged everything. I reinstalled the dvd into my computer.I powered up the roadmate700 and hit the enter button and the screen came up to pick user I hit user one. I plugged the USB calble in and started the download again and it worked out for me just fine. I hope this works for you also. Good Luck
Dec 21, 2007 | Magellan RoadMate 700 GPS Receiver
Screen Freezes
register your unit on the magellan website and there is a firmware update and it will solve your problem
Dec 18, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan GPS Roadmate 760
Are you willing to part with it, I may be able to use it for parts denisdsouza@hotmail.com
Aug 05, 2007 | Magellan RoadMate 700 GPS Receiver
Magellan Roadmate 700
Yes, get a new car connector. -Daniel
Apr 23, 2007 | Magellan RoadMate 700 GPS Receiver
Frozen screen when turned on
Kevin, Hmm... it worked fine the first two times you ran it, then all of a sudden it freezes at the user screen?? I'm not sure if your able to do this, but at the user menu, try pressing the (-)zoom out key and the repeat button a the same time. -If it does bring up the "secret" menu, try clearing user data. -If you have a program that allows you to update the software, version 4.32 I'm guessing (or 5.14) then at that "secret" menu select NAND Flash Format and re-load the software. If you can't access the "secret" menu and it locks up hard at the user menu w/out any responsiveness, I would suspect the hard drive is either bad or has corrupt data. I'm not sure if you can order just the hard drive from magellan/thales/tomtom/shaw but if you can then just replace the hard drive, nand flash format (above) and re-install your software via usb. Additionally, not that it helps your problem, but atleast you would know the pwr and keypad work if this works, press Enter, Cancel and power button at the same time, as this SHOULD power off your unit. Let me know if any new symptoms/problems come up or if you need further instructions. -Daniel
Aug 31, 2006 | Magellan RoadMate 700 GPS Receiver
GPS Logo
26 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
