Question about Zanussi Washing Machines
Hi I've got a Zanussi Aquacyle ZWF1632W 6 kg Product no. 914521110-02. I am trying to take the front filter out to clean it. There is a screw thread, but it doesn't want to come out. Should this come out?
    Brigadier General:
  • 6,277 Answers
Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 24, 2011
Zanussi zwf1220w
Pressure system fault probably
Jun 17, 2013 | Washing Machines
Do i connect zanussi aquacyle 1300 to hot or cold water
Unless this model has the hot water inlet you could connect the inlet only to the cold water line , otherewise it will be indicated at the inlet hose end.
Jul 02, 2012 | Zanussi Washing Machines
Zanussi FLE1216w Repair Manual
Hi, my zanussi fle1216w is skipping the fabric softener stage of the cycle. I've cleaned the dispensing drawer and the surrounding areas, even put on a boil wash in case somethihg was gunge up or visits the Zanussi Owners Manual.
Mar 22, 2012 | Washing Machines
I have a Zanussi 1200 fj 1254 when I turn on the machine and it starts to fill with water...water starts to pour out of the fluff filter mechanism never mind how tight we try to do it up ... any ideas ??
I suspect there is either limescale in the thread of the filter plug OR behind the filter itself and this is stopping the plug from being screwed home completely. Remove the plug, pull out the filter, clean filter compartment all round, especially at the back AND ensure the plug thread is completely free of limescale ;-0)
John C
Sep 09, 2011 | Zanussi FJ1254W Front Load Washer
We have a 4 year old dishwasher.It is not washing as good as it should.The machine seems to rinsing the dishes etc in soiled water.I've checked the syphon and it doesn't appear to be blocked.I...
Hi wesalado,
Please follow my Tip below on some hints on how to keep your Dishwasher in tip-top shape:
DISHWASHER NOT CLEANING PROPERLY ANYMORE...
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 08, 2011 | Zanussi Dishwashers
My Dyson pet is overheating and shutting off autimatically. cleaned filter what else?
Sorry to hear you're having difficulties with your DC14 Animal. Like most Dyson cleaners, your DC14 is equipped with a safety device which shuts off the cleaner if it starts to overheat. If you've already washed the filter, it may be overheating due to a blockage. The easiest way to check for and remove any blockages is to follow the steps shown in our online guide:
http://www.dyson.com/support/help.asp?article=626&product=DC14-ANIMAL_US
Although you've already cleaned the filter, you may find it helpful to take a look at the video linked below to ensure you're doing it correctly. The filter should be washed in cold water without any detergent, at least once every 3-6 months. Always ensure it's totally dry before replacing it - this may take up to 12 hours.
http://www.dyson.com/support/help.asp?article=1461&product=DC14-ANIMAL_US
By clearing any obstructions and washing the filter, you should be able to resolve your issue without further assistance. However, if you've followed these steps and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). One of our experts will be happy to run through some troubleshooting over the phone with you and recommend the best course of action.
Kind regards,
Jack
Dyson Online Customer Support
Aug 29, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Zanussi WASHING MACHINE zwf1632w 914516380 fault code E3
I am sorry Steve, I cannot answer your question as I am not well versed in Zanussi machines...Check out Heatman...he will probably be able to help you with this problem
Jun 14, 2011 | Compaq (153515-001) Touch Pad
My Zanussi Jetsystem Timeline washer/dryer starts its wash cycle, but when it comes to draining, it wont drain and flashes E20.
Have you taken the filter out at the front of the washer and cleaned it. Mine wouldn't drain but once I did that it worked ok.
Mar 04, 2011 | Zanussi ZWD1680W Front Load Washer / Dryer
Washer won`t rinse or spin model zanussi zwf1632w
Lid switch might be broken or transmission might be jammed.
http://www.pdxappliance.com
Feb 27, 2010 | Washing Machines
Washing Machines Logo
65 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
