Question about Odyssey Superspot Followspot W/Tripod (Enx) System
Our school has an Odyssey Superspot DMX , serial # 051SSD0073. It will no longer change colors consistently. It remains on yellow. Every once in a while it will work. I had our maintenence man check it out. He seems to think the circuit card is 'fried". Can it be replaced? Any suggestions?
What is the backing?
The Backing is the see through paper on which the labels are stuck to. It can have a light yellow or white color. While the printer prints, the labels move through the label sensor, usually green in color. The gaps between the labels triggers the sensor to indicate where the printer should start to print.
Hope this Helps. (",)
Aug 05, 2014 | Datamax DMX-M-4206 Thermal Barcode Label...
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Dec 15, 2013 | Sanyo DP26648-R 26 in. LCD TV
Operator does not put out a DMX waveform. The display indicates previously programmed scenes and chases are running. All the buttons and slides appear to respond. The unit is 6 months old. Are there...
I assume you have checked the serial digital waveform from the unit with an OSCILLOSCOPE which is the only way you can look at the DMX waveform. You will have a hard time syncronizing to the waveform. What voltage levels does the wave swing between? If you don't have an oscilloscope, then you have not REALLY looked at the waveform. In that case, USE a known good fixture CLOSE to this controller using a DIFFERENT cable to see if a single fixture works close to the unit. If it does, SUSPECT that your cabling has a break or short someplace. Also check if your daisy chain DMX cable MIGHT require a terminator resistor at the end... Read up on DMX termination.
Jul 08, 2011 | Elation Dmx-operator Dmx Controller
I am using 3 Chauvet colorstrips. They are hooked up perfectly to my DMX controller via master/slave. There are no problems with the DMX controller. The Chauvet colorstrips are flickering simultaneously...
Check if you may need to use a terminating resistor on the DMX chain. Sometimes digital reflections on the cable can cause random behavior.
Search "DMX termination" for explanation.
Also MAKE SURE you set the program mode to 021 (RGB).
It sounds like you might be in one of the automatic modes or sound triggered.
Mar 08, 2011 | Chauvet 6x Chauvet Colorstrip Color Strip...
How do i link more than one together?
Send power to all and link them all with a daisy chain of DMX cables output to input. Set all to the same DMX address on the switches. Use DMX cable to your controller. If you don't have a controller, set the first one as master to an auto mode or sound trigger.
Mar 07, 2011 | American DJ P36 Led Dmx Pinspot With Rgb...
Service recommendations for 200K miles
yes timing belt is a must then a 10,000mile service old school style ,you know back brake drums off ,oil can and grease where needed ,bulbs cleaned spare wheel carrier oiled and greased ,car jack oiled .ect ect
Nov 25, 2009 | 1997 Honda Odyssey
Datamax I4212 printer is dropping characters on large prints jobs from Easylabel. Any idea why?
If you are using serial port (COM1), problably your cable doesn't have flow control. You need a cable that use RTS,CTS and DSR. If you are using paralell port, make a change to serial port.
Nov 19, 2009 | Datamax DMX-I-4212 Label Printer
Color problem MAG Innovision 14" monitor
1. try to connect to another computer . if it is fairly good then it must be your computer is having a problem.may be your video card problem.
Mar 21, 2008 | Mag Innovision lt456s 14" Flat Panel LCD...
Top Odyssey Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Odyssey Audio Player and Recorder Expert? Answer questions, earn points and help others
