Question about Brother MFC 7840W Printer
AFTER REPLACING THE PRINTER CARTRIDGE I CANNOT GET THE MESSAGE ON THE SCREEN THAT SAYS " REPLACE CARTRIDGE SOON" TO GO AWAY. I HAVE TAKEN THE CARTRIDGE OUT AND REINSERTED IT AND HAVE TURNED THE POWER OFF AND ON.
Smooth_Gecko
  • 125 Answers
SOURCE: error message "no cartridge" won't go away on my brother mfc 420cn printer
There is good reasons they don't let you run it out. One, it will dry out and block the printer head. Two, a soon as the head runs dry, it is wrecked anyway. Either way, you would be up for another big bill. Try leaving it turned on while you replace the cartridge, when you close the cover it has to ask you if you changed "whatever colour" cartridge?. You must say yes here to reset ink counter. Sometimes it takes a few goes. Refilling can be a hit and miss affair untill you get a lot of practise! Who needs that. Refilled cartridges are available cheap. Buy a set and just change them one at a time as it complains about them. To cut down on usage, shut the printer down properly at night. If you just unplug it, it cannot cap the cartridges and your ink will dip out.
Posted on Sep 01, 2007
sir fixalot
  • 146 Answers
SOURCE: MFC-9420 Replace OPC Belt message stays on after replacing belt
As far as the OPC belt - don't replace it until you start seeing ghosts and image defects! Reset it by:
Press 1 and 7 at the same time
Press 1 to reset the life counter.
Posted on Jan 03, 2008
SOURCE: Printer ghosting(?) after replacing toner cartridge/drum assembly
If you have tried a new drum unit (DR-2025) without success, you will most likely find that the ghosting is caused by a worn roller in the fuser unit.
A brother service centre would be able to replace the roller or the entire fuser for you, but it may be expensive. Compare prices on a new replacement machine - brother MFC-7340.
Posted on Mar 12, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: is the "change drum soon" message instructing to
This indicator is for the drum unit, not the toner cartridge. The drum unit is the assermbly that the toner cartridge is inserted into when being replaced. The drum unit is replaced about every 18,000 pages so after about 5 to 10 toners have been replaced.
Here is a picture of the drum unit.
Posted on Oct 28, 2010
  • 492 Answers
SOURCE: printer message says may need to replace drum
The drum is a metal drum that takes an electrostatic charge to attract the toner particles. Sometimes the drum can be cleaned. Taking it apart isn't easy. Sorry I don't have a better answer for you.
Posted on Mar 21, 2011
HP PSC 2355 print cartridge not supported?
If this is not a factory new cartridge then that may be the reason it is giving this error.
Apr 17, 2017 | HP PSC 2355 All-In-One InkJet Printer
I have a fax in memory how can I retrieve it
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing. You are advised to replace the cartridge/s, *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink cartridge/s. After the new cartridge/s is installed, close the printer cover and press OK button to let printer print the fax stored in the memory.
* Make sure not to navigate away from the "fax sent to memory" message. You will lose the fax-in-memory data once you turn off the printer or navigate away from the message.
Oct 31, 2011 | Lexmark X6570 InkJet Printer
How do I print faxes in the memory of Lexmark X6650 all-in-one-printer ? Is there a "tools" item in the setup menu ?
Sep 15, 2011 | Lexmark C533DN InkJet Printer
I am unable to retrieve fax from memory, on the Fax Setup menu no reference to faxes in memory. I have a Lexmark 6650. When the fax wa sent it said "printing" but nothing came out
Aug 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Replaced the yellow ink cartridge with a new one and message still appears on screen that the yellow cartridge needs replacing. Appears that the printer does not "see" this new cartridge. I...
This sounds like the chip on the cartridge is defective. Try a different cartridridge. Take the failing cartridge back to the vendor for a replacement or refund.
Your description for corrective actions taken are in-line with accepted procedures.
Let me know if you have any other questions. Thanks.
Jan 18, 2011 | HP Officejet 6500 Wireless All-in-One...
I keep getting message: "Remove and check ink
If you have already checked it by taking out and inserting it back then try this
Do it only if you have connected the printer by USB
1. Unplug the power cord
2. Press and # and 6 at the same time
3. While holding them plugin the power cord, you will see a message
SEMI FULL RESET on the screen
Release the buttons and let the Printer do what ever its doing
Jan 02, 2011 | HP OfficeJet 7310 All-In-One InkJet...
HP Color Laser Jet CP2025. Replace Supplies message on screen and can't get it off. Put in a new print cartridge. Message still won't go away. Please advise how I can get a User Manual for this...
HP Color LaserJet CP2025 - "Replace Supplies" message.
black cartridge is blinking. Printer won't print and message will not go away. Any suggestions?
Nov 09, 2010 | HP Office Equipment & Supplies
Wrong cartridge
I have the multipass mp700 and have just experienced the same message ..... wrong cartridge. After reading the manual, from the disc, it means that there's something wrong with the print head, most likely needs cleaning, but it won't clean because the printer is sending a malfunction message. I will be trying to clean the head and if that doesn't fix it then I'll buy a new print head. Good luck with the problem.
Aug 15, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Code:P error message: Pad saturated.. ink leaked..replace cartridge
Hi!!
Chances are the printer needs maintenance, you can actually send it to a repair center to replace the inkpads for your printer, try this link for information and you can download as well the utility from this site after registering:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
Your printer has a one year warranty if its still within the warranty call epson if not try this site www.epson.com/loyalty and try the passcode minute or market and register. Hope this help. pls dont forget to rate solution. Thanks!!
Apr 19, 2008 | Epson PictureMate (C11C556001) InkJet...
Brother MFC 7840W Printer Logo
237 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
