Question about EDGE Tech Corp Edge 500GB DISKGO 2.5in. BACKUP ULTRA PORTABLE USB 2.0 HARD DRIVE
External harddrive not recognized by my computer. it worked fine for a week and then all of a sudden stopped being recognized by the computer. Do you have any idea why this would be. It is a windows vista computer. i dont know why. do you know if there is driver software i can download?
    Sniper:
  • 113 Answers
Try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files.
http://www.asoftech.com/adr/
Posted on Jan 22, 2013
    Scholar:
  • 30 Answers
If it shows up in 'My Computer' as a drive letter(like E: drive) but you just can't access it,I would first try to recover the data on it with a data recovery program to avoid losing them.
I have succeed with Tenorshare Data Recovery. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash and drive 'not recognized' issue.
You can get it here: http://www.any-data-recovery.com/index.htm
If the hard drive can't be detected,you can try this way.Put the hdd in a zip-lock bag and put it in the freezer overnight. Then while it's still cold plug it into the computer and you may be able to view it in 'my computer'. And run the recovery program to recover your data on it.
If it fails, you will have to go to a recovery office but let's hope not because it will cost you a lot of money and whether they can recover the data or not is not guarantee.
Good Luck!
This article will help.
How To Recover Lost Data From Crashed Hard Drive?
Posted on May 26, 2011
My laptop stop recognizing my external harddrive
chances are its no good , external HDDs in plastic cases don't last very long , its the constant plugging in and unplugging plus any wretching
will cause it to break , I myslef have 3 of them that no longer work
ranging from those reasons .
Feb 23, 2013 | Antec Computers & Internet
WD 500G HDD suddenly un-readable; changed name to local disk, says I need to format in order to use it. I have tons of important stuff on there.
Could you confirm if the problem with the drive not being recognized is a problem with the USB cable? I have a 250GB passport and it worked fine with my XP. Once I decided to reformat it to NTFS and tried to do so by plugging into my new windows7 laptop the problems started.
Aug 21, 2011 | Western Digital My Passport Essential...
My sata external usb western digital 320 gb drive only shows up as an unknown USB device. Is there any way to get my computer to recognize it. I have a laptop using windows xp. Ive tried unplugging...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11­CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jun 25, 2010 | Western Digital 320GB MyBook External USB...
External HDD no longer recognized by new win7 PC
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
Why won't my computer recognize my removable device
then check.
May 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
External hard drive is not being recognized by any computer
then check.
Thanks for using FixYa.
Apr 27, 2010 | Western Digital Passport 320GB External...
Toshiba external Hard drive not working
I suggest to connect the harddrive straight to the computer as a slave disk, coz i think the casing power has been damaged. make sure u set its jumper as slave, the harddrive in the machine which contaoins windows should be the master.
Mar 11, 2008 | Computers & Internet
Can't find my harddrive
hey, i seem to be having a similar problem. i'm sorry i dont have any answers for you, but if you've found any answers please email me at peanutzz916@gmail.com
Jan 15, 2008 | Computers & Internet
Acomdata external harddrive gone blank.
dont copy any data from or too the disk then use recover software. like Recover My Files, and if you copy any data to that disk it will damage the data you want.
Jan 06, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
EDGE Tech Corp Edge 500GB DISKGO 2.5in. BACKUP ULTRA PORTABLE USB 2.0 HARD DRIVE Logo
264 people viewed this question
Top EDGE Tech Corp Computers & Internet Experts
David Payne
David Payne
Are you an EDGE Tech Corp Computer and Internet Expert? Answer questions, earn points and help others
