My machine is displaying a code F07 and wont spin is this worth getting it fixed or buy a new machine!
    Brigadier General:
  • 6,277 Answers
Sorry but you have not told us the make and model to be able to decode your 'F07' ;-0) So- guess time- I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 24, 2011
Whirlpool awm 8143 doesn't stop at the end of the spin cycle. Instead it clicks for a while when the timer displays 1 minute then displays F07 then goes back to wash cycle. While googling I found something...
F07 - Motor Control Unit (MCU) Error - Disconnect power and unplug unit. Check wire harness connections between drive motor and Motor Control Unit (MCU), and between MCU and the Central Control Unit (CCU). Reconnect power and plug unit in.
Check the MCU by looking for operations of the drive motor, and check drive motor for powered rotations. Replace failed component.
Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 12, 2010 | Whirlpool AWM8123 Front Load Washer
Wont spin
worth repairing, can likely do yourself. check the lid switch, it is probably your problem. comes complete with wires that plug in. easy fix.
Nov 08, 2009 | Kenmore Washing Machines
F07 error message
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F07-AWM 9000
The F07 indicates a Motor Control Unit (MCU) Error.
  1. Disconnect mains power and unplug unit.
  2. Check wire harness connections between the Drive Motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  3. Check the MCU
  4. Check the Drive Motor
  5. Check the Wire Harness
  6. Reconnect power and plug unit in.
  7. Check the MCU operation by looking for movement of the drive motor, and check drive motor for fully powered rotation.
  8. Replace failed component. Note: If this failure occurs during high-speed spin, the door will be unlocked after three minutes.
Select PAUSE/CANCEL twice to cancel the cycle.
Select DRAIN/SPIN if there is excessive water in the washer.
Re select cycle and select HOLD TO START.
Oct 26, 2009 | Whirlpool AWM9000 Front Load Washer
My washer wont spin on spin cycle what can i do to fix it
Hmm.. you'd probably have to get a replacement.
It would be worth the wait then just buying a new one for like £/$500, if anyone has a better solution. Say it out LOUD! :D
Sep 03, 2009 | Maytag Washing Machines
F07 occurs at end of first rinse cycle
Mar 26, 2009 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
My dvd player wont work
Not worth fixing. Just buy a reliable brand that doesn't have that problem or a cheap machine for $20-$40 and get a new one every two yrs or so.
Oct 15, 2008 | Televison & Video
Drum on washer wont spin
It's not worth fixing if it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
The belt is gone and or snapped off or the transmission is shot! And it's not worth replacing an old transmission.
If it's 10 years old or more buy a new one
and save your money ,fixing it is a waste!
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Jul 28, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
