Question about Brother Office Equipment & Supplies
How do I refill a brother 1060 self inking stamp? Thanks
2 Suggested Answers
djuksoni
  • 103 Answers
SOURCE: How do I refill my
You need to take off upper seal from lower (see picture)
inside you will see two round holes on each side.
use only Brother ink and do not put to much ink.
BR
Posted on Feb 08, 2011
Trying to re-ink red dates on red & blue stamp. Have tried disassembling and red dates are now failing to make any impression at all while blue received continued to print.
It depends on the type of stamper. There are many kinds of self-inking stampers. The most common one has a slide-out "stamp-pad" tray (it'll just look a thick black line until you remove it). For these, you use your hand to press the stamp just slightly (just barely lift it from the pad) and then push the tray out the side (it doesn't matter which direction, just press against the black line from one side and it'll pop out the other side). Once you have removed it, you can then put refill ink on the portion that has dried out. Wait for it to absorb (if it's very dry repeat the process one or two times) then press the stamper again and slide the tray back in, being careful to make sure you have it going the correct way or you'll reverse the colors. Stamp on a piece of throw-away paper about 10 times to make sure it is working properly and has enough ink.
Aug 03, 2015 | Cameras
How do I refill my Brother 1850 stamp?
BR
Feb 08, 2011 | Office Equipment & Supplies
Hi,I have a brother printer DCP7200 Lazer I refill...
there is no special toner, check the connector that connect the magnetic roller to the charger and try another bottle of toner if the problem persist change the cartridge
May 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
Lexmark Prnter won't recognise color when cartridge refilled.
Hi there
Lexmark and Brother printers, dont have any thing I know of to reset the inks when you refill them your-self sorry.
Pineworks
Mar 07, 2010 | Lexmark X5470 All-In-One InkJet Printer
How to refill Brother LC51M ink cartridges?
how do i refill brother innobella ink cartridge
Dec 12, 2009 | Brother Office Equipment & Supplies
Unable o clean
HTML clipboardHi If your brother printer has been left unused for some time it is probably clogged? And the inbuilt cleaning facility does not help then you will probably need to buy a Magic Inkjet Flush Print Head Cleaning Kit.
Which you can find on Ebay.
http://tinyurl.com/yfx2y5k
Although it is possible to take the Brother printers apart, it is too difficult for most people.
To view what´s inside a Brother Printer click on next line...
Click again to enlarge photo.
http://magicinkjetflush.com/images/Unclog_Refill_Brother_Printers.jpg
Therefore, what we suggest is to make cleaning cartridges using the Dr.EpSUN Refill Tool...
Then use them to flush the print head (usually at the end of long tubes near to the back of the Brother printer)
*NEVER TOUCH THE WHITE star shaped PIN... under ink cartridges... because once pessed in... it cannot be used !
Also in most cases a single cleaning cartridge for black and 1 for colour is all you will need.
If you only have FULL INKS and need to make a cleaning cartridge use Dr.EpSUN Refill Tool to empty ink cart...
Save the ink in a clean glass jar or similar make cleaning cartridge then once unclogged simply use Dr.EpSUN Refill Tool
to refill with your saved ink.
How to make Brother Cleaning Cartridges
If you wish to see photos? You can also follow the procedure for Epson C80 in the Magic Inkjet Flush Manual.
Using FREE Dr.EpSUN Refill Tool.
To refill Brother inks... or if printer has been left unused and you need to unclog print head? (To make a cleaning cartridges *Fill empties with Magic Inkjet Flush instead of Ink / Then print rectangles using Magic Inkjet to FLUSH print heads once prints appear without white lines simply replace with inks and continue printing rectangles untill all Magic has been flushed out of print head.)
How to refill Empties...
1. Secure empty Brother ink cartridge UPSIDE DOWN in a vice or similar.
2. ONLY HALF fill Dr.EpSUN Refill Tool with warm Magic Inkjet Flush (or correct color Ink if refilling with ink)
3. Then Holding Dr.EpSUN Refill Tool upright... cover metal tip with a tissue and expell any trapped air until ink appears.
4. Insert metal tip into circular ink outlet hole of upturned cartridge... until black rubber makes a GOOD seal.
Holding both securely...
5. Do NOT TRY TO FILL Instead. PULL UP on the plunger of Dr.EpSUN REFILL TOOL.
6. Air will bubble up through the Magic/ink whilst escaping from cartridge creating a vacum.
7. Now... Simply allow plunger to retract and the Magic/ink will automatically refill the cartridge for you.
8. STOP filling before the Dr.EpSUN Refill Tool is empty otherwise air will entering.
9. Repeat until ink cartridge is full.
How to FLUSH a BROTHER print head.
10. Place filled cartridge into printer and you are ready to print.
Use print head cleaning to prime which will also fill the ink tubes... then....
11. Print rectangles of the problem colour(s) using test sheets (see below) to prime ink.
As found in the manual, here are the print test sheets for printing rectangles depending on colour(s) with problem.
Just choose... Yellow, Magenta, Grey Tones etc...
PRINT TEST SHEETS FOR USE WITH MAGIC INKJET FLUSH
http://magicinkjetflush.com/Ebay/Print_Test_Black.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Color.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Cyan.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Yellow.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Magenta.jpg
http://magicinkjetflush.com/Ebay/Print_Test_Grey_Tones.jpg
Once prints appear to be normal simply replace the Magic Inkjet Flush with ink cartridges and continue printing rectangles untill flushed.
Hope it helps. If you need any further help Click Here then choose "Ask a Question"
Thanks
John P Bradley Tinteiros (Ebay)
Nov 23, 2009 | Brother DCP 115C All-In-One InkJet Printer
How do i refill a brother lc51m ink cartridge?
although i dont recommend it, you will need to get some type of syringe and inject the liquid into it.
just a warning, we fix a lot of brothers, the majority of them are because of refilled ink.
thanks
Apr 17, 2009 | Office Equipment & Supplies
Hello i have a handstamp which has ink inside already, do you know if I can refill those handstamp ? thanks Tj
Check a local hobby store and they should have stamp ink refill kits. I recommend Hobby Lobby or even Wal-Mart.
Dec 29, 2008 | Office Equipment & Supplies
Refilling ink cartridges
NVER EVER USE REFILLS ON BROTHER MACHINES, THE PRINT HEAD WILL GO BAD, I AM A SERVICE CENTER FOR BROTHER
Dec 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC5840 CN Print heads
Stuts,
I guess you have used generic ink carts.
You should buy an original brother ink cart.
When done so make sure all other carts are at full level:
Press menu then start b/k copy then fourtimes arrow up (tel.index). Machine will be in maintenance mode. press 7 then 6 then 4 then start b/k copy. Machine will refresh ink within tubes and print head and do some power cleaning. when finished press 7 then 6 then 3 then start bk copy to run an extra power purge.
Leave maintenance by pressing 9 then 9.
Do run a quality test print.
If you re lucky the ph will work again.
THERE IS NO WAY TO CLEAN THE PH OUTSIDE EXCEPT BY Power Purge (7-6-3) within maintnenace mode.
If you like to save money refill ORIGINAL Carts by drilling a 2mm hole into the top (O of brother brandname) . You can leave the hole open to refill the cart next time directly without taking it out of the printer.
Mix some 3ml 85%-glycerin alc (drugstore) with 3ml of destilled water and 5 ml of DYE(!) ink and refill the c/y/m cart.
For bk mix 1 ml glycerin alc with 4ml dest. water and 15 ml bk DYE ink (shake well before refill).
This is -nearly- the exacte mixture of original brother ink.
Mar 02, 2008 | Brother MFC-5840CN All-In-One InkJet...
3,014 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
