Question about E-Machines eMachines Desktop PC
Bigfixit An icon appeared informing me of 25 issues that need attention..when I click on the idividual listings I can't get them to drop down so they can resolved
  • Joshua Murchison
    Joshua Murchison May 11, 2010
    Where did they appear on your screen?
    Novelist:
    Scholar:
  • 141 Answers
Have you ran your antivirus? Do you have a program installed that uses this icon? Is the icon located on your task bar of running programs? Sorry for all the questions but these are things we would need to know to have an idea of your problem.
These kind of "attention issues" are usually Viruses or a software update. Have you ever seen this icon info before? It's likely a virus and if your not sure what something is or something strange or new pops up, first rule; don't click on it. That's how viruses execute themselves into your system.
Try right clicking on the icon & see if you have properties. From there follow the path on the general tab/location/and delete. Under description on the general tab will also give you a name of the program. Do a search and see if it finds anything. If there are different names write them down doing a search and deleting each one. This is how viruses can work.
If you feel it's a legit program go to start/run/type msconfig/startup tab/ look for suspisios programs and uncheck them. If your not sure what they are look each up on internet.
Posted on Aug 17, 2008
I want to reduce size of screen contents so that i can read the entire screen
Click start control panel display desktop you can select a different desktop from the drop down list or a browse button where you can select different pictures this may vary depending on your operating system also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal , larger or custom settings
Always click APPLY after making any changes windows 7 Open Personalization by clicking the Start button, clicking Control Panel, clicking Appearance and Personalization, and then clicking Personalization. Click Window Color and Appearance. Under Window Color and Appearance, click the color you want, and then click OK. Note If you see the Appearance Settings dialog box instead of the Window Color and Appearance window, the theme might not be set to Windows Vista, the color scheme might not be set to Windows Aero, or the computer might not meet the minimum hardware requirements for running Windows Aero. For more information, see Troubleshoot problems with Windows Aero. Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar This will add to your screen toolbar File Edit View Favorites Tools and Help select the View from the drop down list will be a Zoom with percentages % and text s largest to smallest and Full screen option Hope this helps.
Jan 08, 2013 | Computers & Internet
The display under icons is too small to read on any window.
Steps for changing desktop icon Font Size or Type in Windows XP
1. Right Click Desktop + Choose "Properties"
2. In the Properties Window click on the "Appearance Tab" at the top.
3. In the Appearance Window click on the button called "Advanced"
4. In the Advanced Window choose "Item:" from the drop down list and choose "Icon" and you can choose desired Icon font size and Type.
May 23, 2011 | Computers & Internet
Describe how I use wifi on my acer notebook
Click on the "Start" tab on the main desktop screen of your Acer and a list of options will appear in a drop-down menu.
Select "Connect To" from the list of options in the menu.
Select "Show All Connections" from the list of options that appear. A window will open with a list of icons.
Use your mouse to right-click on the "Wireless Connection Icon" and select "Enable" from the list of options. Wireless capability will then be turned on.
hope this helps :)
May 19, 2011 | Acer eMachines 350-2074 Netbook
Hello, when i connect the transcend 500 gb hard drive in my computer, it does not show. Its not read. Although when i click on the safe remove it appears to be connected. when i browsed for solutions...
Click "start" find and click on "control panel". In your list(icons) find "device manager"> right click on and open, click continue. click on the box wit + next to "Human Interface Devices". you will see a drop down and, you should see your device. Right click on it and you should see disable in the list. If you see "enable" ckick on that. Right click on it again and click on the properties tab. You should see "this device is working properly". If you dont see device in there look under, "IDE ATA?ATPI controllers. Right click on each item in the list and you should see "disable". If you see "enable" in any one of these, click enable, then go back to Human Interface Devices.
Mar 27, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
How to reduce the display,so big icons on destop
set the resolution to 1024x768,right click the graphics settings icon (bottom of desktop)or follow these one: Steps for changing desktop icon size.
1. Right Click Desktop and Choose "Properties"
4. In the Advanced Appearance Window choose "Item:"
from the drop down list and choose "Icon" and you can choose desired Icon size.
By default many users will see 32 x 32 pixels but this can be changed to whatever you want.
Feb 18, 2011 | IBM Computers & Internet
How to reduce icon on my desktop?
4. In the Advanced Appearance Window choose "Item:" from the drop down list and choose "Icon" and you can choose desired Icon size. By default many users will see 32 x 32 pixels but this can be changed to whatever you want.
Feb 16, 2011 | Microsoft Windows XP Home Edition
Change font sze of incoming mail on aol
To make Windows Mail or Outlook Express use larger or different fonts for message lists and other interface elements:
  • Select Control Panel from the Windows Start menu.
  • In Windows Vista:
    • Make sure Control Panel Home is highlighted.
    • Click Customize colors under Appearance and Personalization.
    • Follow the Open classic appearance properties for more color options link.
  • In Windows XP:
    • Go to Appearance and Themes if available.
    • Click or double-click Display.
    • Go to the Appearance tab.
    • Click Advanced.
  • Select Icon from the Item: drop-down menu.
  • Choose the desired Font:, Size: and attributes.
  • Click OK.
  • The Icon font is used for the list of folders and messages as well as toolbar icon text in Windows Mail or Outlook Express.
  • Click OK.
  • Jul 10, 2010 | Acer Computers & Internet
    Need to fax docs w/ a Dell 942 all-in-one print-fax-copy-scan.
    To install and configure the Microsoft® Fax software:Click the Start button.
    Click the Control Panel icon.
    Double-click the Add or Remove Programs icon.
    Click the Add/Remove Windows Components icon on the left side of the Add or Remove Programs window.
    When the Windows Components Wizard window appears, click to place a check in the box next to the Fax Services listing.
    Click the Next button.
    When the Files Needed window appears, insert the Windows® XP CD into the CD-ROM drive.
    From the Copy files from: drop-down button, select the drive-letter that represents your CD-ROM drive.
    Click the OK button. to automatically open and close several installation windows.
    When the Installation Complete window appears, click the Finish button.
    Close the Add or Remove Programs window.
    Click the Start button, point to All Programs, point to Accessories, point to Communications, and then point to Fax.
    Click Fax Console.
    When the Welcome to Fax Configuration window appears, click the Next button.
    Enter any appropriate information in the fields provided.
    Select your data/fax modem from the drop-down button located below the Please select the fax device listing.
    Click the Manual answer button or Automatically answer after (specify number of rings) button.
    Click to select the Enable Receive listing.
     Note:
      By selecting the Enable Receive check box, you can receive faxes. However, selecting this option may cause the computer modem to answer all incoming phone calls in which you may not receive voice mail.
    Enter your TSID (Transmitting Subscriber Identification) information in the field provided.
    Enter the CSID (Called Subscriber Identification) information in the field provided.
    When the Routing Options screen appears, click to select the Print it on check box if you want each received fax to be automatically printed. If selected, use the drop-down menu to the right of this field to select the Dell AIO Printer to print the received fax. Your printer must be on and connected to your computer in order to automatically print faxes.
    To create an archive copy of each fax, click to select the Store a copy in a folder check box.
    Click the Browse button to select the desired archive location.
    Click the Next button to display the Configuration Summary list.
    Confirm your configuration settings are correct, and then click the Finish button.
    You are now ready to send or receive faxes.
    http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&dn=1091795
    Nov 14, 2009 | Office Equipment & Supplies
    Problem detecting wireless network laptop on windows xp no problem on other laptop windows vista
    Ok if your wireless card appears to be installed and working but all you get is an empty list of networks every time you search for available networks then chances are the windows wireless service is not running.. to fix this try the following:
    "Right click" on "my computer" icon and select "manage" from the drop down menu
    Then when the management console appears click "services and applications" on the left pane
    Then in the right pane "double click" the word "services" to show the list of services running on your computer.
    Then scroll down to the bottom of the list and usually about the third from the bottom you will see a service called "wireless zero Config"
    You need to make sure it says "started" in the "status" column if it does not then "right click" on it and select "start" from the drop down menu
    If the service says started and you are still getting an empty list then let me know and i will help you with the next step in solving it but usually 9 times out of 10 that is the issue
    I hope this info helps
    Dec 11, 2008 | Computers & Internet
    Using new Satallite P200-1EE, webcam is not connected message with Yahoo Messenger
    I'm using a Toshiba satellite notebook A200, which I faced the same problem like you saying my built- in webcam cannot operate after I clicked on the drop down list from the windows live messenger to have a webcam conversation. Another program is running the webcam at startup. That program is called Camera Assistant Software which is the conflicting software. Therefore I closed this software and I'm able to use my webcam again in my webcam conversation in windows live messenger. I hope this information will help you.Good Luck!
    Dec 22, 2007 | Toshiba Satellite A135-S2276 Notebook
    E-Machines eMachines Desktop PC Logo
    37 people viewed this question
    Top E-Machines Computers & Internet Experts
    Alun Cox
    Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
