Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a craftsman lt2000 42" lawn tractor , the cable for the blade to engage is not working how do i fix it
rockitman187
  • 2559 Answers
SOURCE: loud screech noise from deck area
This can be due to a belt slipping or a bad spindle bearing.
And on the difficulty scale,10 being extremely difficult, The belt would be a 1 or 2 and the spindle about 6 or 7 (because the deck usually needs removed for this job)
Posted on Apr 04, 2009
jdlipscomb41
  • 157 Answers
SOURCE: I have a Craftsman LT2000 tractor and I've had a
the pulley that the disingage spring is hooked to sounds like its freezing up it may need some oil put on it to make it slide easier
Posted on Oct 26, 2009
  • 49 Answers
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Posted on Feb 05, 2009
  • 376 Answers
SOURCE: gear of starter motor won't engage in flywheel to run the tractor
Look under 'My Profile' (Longhorn294 in the top right corner of this page)on page 5 at this post and solution. "craftsman riding mower starter will spin but not engage". Dwain
Posted on Jun 08, 2009
wadembly
  • 513 Answers
SOURCE: 42 inch Craftsman blades won't engage
is the belt spinning & smoking when blades are engaged or the belt won't spin if the belt spins but blades wont go then there is something stuck under the deck or the bearings are gone out do to not being greased
Posted on Jun 14, 2009
Managemylife com
check that the cable isnt unhooked
May 01, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 20hp lawn tractor blades won't engage
check to make sure your cable is in tact its called a pto clutch cable about 20 buck on ebay it may be broke inside
Sep 26, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Blade engagement lever won't disengage
If this is a manual engagment system all the lever does is to pull a jockey wheel into the back of the belt to tention it thus starting the blades to turn, so either the cable is jammed that pulls the jockey wheel in, or the jockey wheel arm is seized and needs freeing off to allow the jockey to to move to the relaxed position.
Jun 23, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
My craftsman 18.0 42" lawn
First check to make sure you can turn each blade by hand, with the mower off. If neither blade spindle is frozen remove the deck and make sure all the pulleys move freely and function like they should. The cable should have been operating a spring loaded pulley arm that applied tension to the deck belt to make the blades function. Some times build up with block that from moving or rust will make it stick.
May 26, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Lever won't engage blades
check to see if a belt came off, it would go from bottom engine pully to deck lever pully then around blade pullys on deck. the pully under neth has to tighten belt to run blades the pully is ether solid to lever or has a cable that moves it make sure cable did not break hope this helps
Jul 18, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need a blade engagement cable diagram for a 2002 craftsman lt1000
as far as i know, there is no diagram available for the cable replacement. it is covered briefly in the owner's manual, but the best way to do it is to study carefully how the old one is routed, and replace a step at a time
Aug 06, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Won't engage blades to cut lawn
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
May 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
388 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
