Question about Frigidaire Gallery GLHS38EGSB Side by Side Refrigerator
Water condensation in side the fridge and the cooling dail knob stuck at 1
  • 2 more comments
  • chief_agoro May 25, 2011
    there are two knobs on the fridge as shown above, one appear to be stationary and the other variable, Is this how it surpose to work ?
    i was able to removed the knobs alwright but one appear stationary and the other variable, the statioary one has apulley attached to it whirl the variable one has a dail capability,is this how it surpose to work?
    Are you still there
    the knobs arrangement are different one has a stationary pulley set at the coldest and the other a variable dial is this how it should work
  • 4,323 Answers
Hi
You mean you are unable to move the dial and its stuck, in this case you would need to disassemble the dial and check. If the dial still doesn't move then you would need to replace it. Please check this video for knob adjustment---
Hope this helps... Please post back if you need more information.
Daniel
Posted on May 24, 2011
  • Daniel Scott
    Daniel Scott May 25, 2011
    As shown in the video both knobs should work, replace the knob which is stationary.
  • Daniel Scott
    Yes whether it is a dial capability knob or pulley knob they should move. Please post back if you need more information.
How do I unstick the temperature control knob in my freezer? It will not budge. My freezer is over freezing and my refrigerator is not cooling properly.
It is possible that water or the moisture in your freezer has frozen the knob so it feels stuck, so the couple of ways you can fix it is, 1 unplug the freezer, let it defrost and when it warm the knob should loosen up. 2 if you dont want to do the first cuz of food and whatnot what i would do is get a wrench that can fit the knob, put a wash cloth over the knob so dont scratch it all up and grab it with the wrench and try to twist it that way. And 3 take that part of the fridge apart, take off the covers or see if you can open up that area and try to take the knob completely off, and if its like every other knob ive ever seen, once you get the plastic knob off there will be a metal pin that has a flat side that lines up with the plastic knob, take pliers or wrench and try to spin that little pin
Oct 01, 2016 | Refrigerators
Temperature inside refrigerator side isn't very cold
water on floor usually is due to moister condensation? due to bad door seals, or clogged evaporator drain plug in fridge. may also want to check ut defrost timer to make sure its not stuck in defrost mode? do u hear the compressor and or fan operating? Lastly check ur air flow control ( knob and air vent) to see if its not to far closed thus not allowing air from freezer into fridge?
Mar 12, 2015 | Refrigerators
Our fridge is making a loud humming noise ..when you turn the cooling knob to #1 setting it stops but then starts againa few minutes after you turn it back to 4
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 17, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
The freezer is working but the fridge side is broken. It's a side to side fridge. How do I fix it?
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 15, 2010 | Sub-Zero 695/O Side by Side Refrigerator
Refrigerator is not cooling, what do i need to check
1 move away from wall
2check that nothing is bloking the condenser
3 check and set the temparature setting knob to about 0 degrees
Jun 14, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
Our refrigerator is not as cool as it should be and seems to be getting warmer
In side by sides if the fridge side not working correctly it means that the air vent from the freezing unit has stuck in the closed position which causes the fridge to not be any where near as cool as it should be and if it is too cold then the vent is stuck in the open position. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up, which can be caused by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. Best call a service engineer asap.
Oct 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
My fridge is 1 year old and freezer is freezing but fridge dont work
Sep 29, 2009 | Whirlpool GS6NBEXR Side by Side...
Water filter needed changing for awhile,not got round to it,now the fridge temp is dislaying - and i am not able to change it.also the vacation mode has come on...will this mean it needs repairing and will...
In side by sides if the fridge side not working correctly it means that the air vent from the freezing unit has stuck in the closed position which causes the fridge to not be any where near as cool as it should be and if it is too cold then the vent is stuck in the open position. The vent is controlled by a small sync motor and either the motor has become faulty, the control module is faulty or the vent is iced up, which can be caused by putting too many hot items in the fridge so the steam condenses and freezes the vent in position and then the motor cannot open or close it causing it and / or the control module to become faulty. Other times it is just old age that causes the motor and / or the control module to fail. Yes your food will go off so Best call a service engineer asap.
The water filter is independent of the fridge / freezer cooling so will not affect it. If you have not changed it recently (usually every 6 to 9 months) then it may will prevent water flow to the water dispenser and ice maker and if you leave it without changing it for too long then it can build up harmful bacteria dn give you bad stomach upsets etc.
Aug 22, 2009 | Whirlpool GS6NBEXR Side by Side...
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Ge refrigerator gtsz01cncww
sounds like a plugged up condenser coil that is underneith the unit. take a shop vac and a long brush and clean it throughly.
Jan 08, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Frigidaire Gallery GLHS38EGSB Side by Side Refrigerator Logo
47 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
