Had an f6 faliure display then cycle stoped now it wont spin help.is it worth fixing or just buy a new one
    Brigadier General:
  • 6,277 Answers
Unfortunately you have not told us the make and model ;-0( So it's guess time!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 24, 2011
I have an f6 code and the machine will not operate once it comes up
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
May 19, 2015 | Washing Machines
Loud noise when on spin cycle. Kenmore front loader. Cloths still sopping wet
This is a common problem on this machine Your rear bearing is bad and requires outer drum and bearing kit.not worth fixing buy a new machine.hope this helps.please rate my response :)
Dec 09, 2009 | Washing Machines
Wont spin
worth repairing, can likely do yourself. check the lid switch, it is probably your problem. comes complete with wires that plug in. easy fix.
Nov 08, 2009 | Kenmore Washing Machines
My washer wont spin on spin cycle what can i do to fix it
Hmm.. you'd probably have to get a replacement.
It would be worth the wait then just buying a new one for like £/$500, if anyone has a better solution. Say it out LOUD! :D
Sep 03, 2009 | Maytag Washing Machines
Won't spin in final spin cycle.
transmission shot if it does everything else but spin,not worth fixing for the price of a transmission plus labor,just junk it and buy a kenmore,whirlpool top load-mike
Apr 28, 2009 | Washing Machines
Washer won't agitate or spin
The transmission is dead!
It's not worth fixing!
If it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
1998????????????
Not worth the money to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Try You should call service.:
A&E Factory Service
1-800-905-9505
Nation wide / 7days/24 hours
Good work
Please give me a "Solution Solved Rating", in this site!
Thank You
Neil
Aug 01, 2008 | Frigidaire FEX831CS Top Load Stacked...
Drum on washer wont spin
It's not worth fixing if it's 10 years old or more, better off replacing it with a newer machine which will be much more efficient!
The belt is gone and or snapped off or the transmission is shot! And it's not worth replacing an old transmission.
If it's 10 years old or more buy a new one
and save your money ,fixing it is a waste!
A&E Factory Service
1-800-905-9505
Good work
Thank You
Neil
Jul 28, 2008 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool top load washer 7.5 kg
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 24, 2007 | Whirlpool LSR9434PT Top Load Washer
Microwave repair
my kenmore 665 69682992 2000 model was running fine until it stoped while i was defrosting and the display appeared f6 and continues to run, what should i do.
Mike hammoud
8465 berwyn 48127
dearborn heights Mi
313 2829272
Jul 04, 2007 | Kenmore 63792 Microwave Oven
Cloths remained wet after spin cycle
This is a direct drive washer and the trans is not hard to replace. You want to make sure it is the trans giving you the problem. The trans is covered for 5 years under warranty parts only. Other problems could be a worn spin tube, brake or clutch. Did the washer loose its nuetral drain? If your washer is over 8 years old, maybe it's time for a new one. Otherwise, check out the link for the trans. http://www.repairclinic.com/0080.asp Catriver..post back.
Feb 27, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Open Questions:
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
