Question about GE 29369GE1 Corded Phone
How do I adjust the ringer volume of a GE 29369? The incoming ringer is too loud. Can't find the answer in the manual user guide. Thanks N.T
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • GE Master
  • 102,366 Answers
Set the RINGER volume switch located at the back of the base to the desired loudness.
OFF - Telephone will not ring.
LO - Sound will be lowest.
HI - Sound will be loudest.
The above is from the third column of the first page of the manual at
http://www.home-electronics.net/USER-GUIDES/29369_DOM_ES_CD_IB.pdf
Posted on Aug 19, 2011
I have a Vtech answering machine, MI6896, I need to lower the volume of the ringer without changing the volume of outgoing and incoming message.
With the handset in idle mode, press MENU then use up/down-arrow to select "RINGER VOLUME." Use up/down-arrow to change the ringer volume. See full details on page 30 of the manual.
Jul 29, 2012 | Vtech Lands Phones
Can't hear ringer on my dect 6.0 answering machine
Since you declined to specify the model of your GE DECT 6.0 answering machine, I can only suggest that you select it here to download a copy of the manual.
Feb 07, 2012 | GE Lands Phones
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
Make the ringer louder I cant hear the phone ringing
Hello. From the User Guide:
To adjust the Ring and Beep Volume from the control panel
1. Press Setup.
2. Press 4, and then press 4 again.
This selects Basic Fax Setup and then selects Ring and Beep Volume.
3. Press > to select one of the options: Soft, Loud, or Off.
4. Press OK.
To adjust the Phone Line Monitor Volume from the control panel
1. Press Setup.
2. Press 4, and then press 5.
This selects Basic Fax Setup and then selects Phone Line Monitor Volume.
3. Press > to select one of the options: Medium, High, or Low.
4. Press OK.
For your reference, here is a link to the user guide:
http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf
Thanks for using Fixya.
Sep 29, 2009 | HP Officejet 4355 All-In-One InkJet...
Panafax UF-880 - volume of phone ringer
1- incoming volume press the down arrow till you want the desired level
2-outgoing volume. press monitor you will hear a dial tone. press down arrow till desired level and press monitor again your done
Dec 04, 2008 | Panasonic Panafax UF-880 Plain Paper Laser...
Lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Nov 11, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Need manual for GE big button cid speakerphone #29369
The manual is at:
http://www.home-electronics.net/ge/pc/IB/29369GE1_IB.pdf
Feb 17, 2008 | Big Button GE 29369GE1 Speakerphone
How is ringer volume adjusted?
the ringer is too loud and the beeps from pressing the buttons are too loud.
Dec 30, 2007 | GE 25932 Cordless Phone
Programing
Here are some suggestions Volume You may adjust the ringer, speaker, handset and headset volumes independently with the VOLUME ^ and VOLUME v buttons. Your telephone comes with predetermined settings which can be adjusted to individual taste. You will hear an error tone when the maximum or minimum volume level is reached. During volume adjustment, a ?dashed line? icon shows in the display. Adjusting the Ringer Volume Press the VOLUME ^ or v button while in on-hook mode. And/or 1 Selecting a Ringer Tone You may select the ringer tone for each line independently. You may choose to turn the ringer off or select one of the four available ringer tones for each line. 1. Press STORE. The red indicator blinks indicating unit is in Store Mode. 2. Use the number pad to select a ringer tone 0 through 4 (selecting 0 turns the ringer off). 3. Press STORE and then press the desired line button. NOTE: The line indicators continue to flash for incoming calls even with the ringer disabled. You may not select the same ringer tone for both lines. Checking the Ringer Settings Check the setting or each ringer (on, off) by pressing STORE, followed by LINE 1 or LINE 2 button when the phone is on the hook. The ringer setting of the selected line will be shown in the display. If there are any further questions or comments please post here. Please rate this solution through fix-it. Thank you.
Jun 23, 2007 | GE 29485GE2 Three - Line Speakerphone w/...
GE 29369GE1 Corded Phone Logo
160 people viewed this question
Top GE Lands Phones Experts
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
