Question about Office Depot Ativa DQ60M Shredder
Overheated ativa shredder. How long does it take the machine to cool down on average? Our machine is 2 + years old. T-MC 1000. Thanks for your help.
  • 343 Answers
Small Shredders like these are not continuous duty machines.Meaning they are use for very very short time intervals. If it's "heating" up right away, the motor may be going bad. Shouldn't take 15 minutes to cool down after a short use period.
Here's a suggestion: Just before you run paper thru it next time, squirt some oil all the way across the cutting blades. Then run the paper. (Oh, and make sure you have some shredded paper in the basket to catch and absorb the excess oil) Good luck.
Posted on May 24, 2011
My ativa 12 x-cut paper shredder runs for 1/2 sheet then stops. how would you identify problem and fix it
The sheet detector may be malfunctioning. Your shredder may have to be cleaned to restore proper operation. Mine gets clogged periodically and has to have the bin removed so the entire shredder can be turned upside down to perform dental hygiene on the teeth. Paper shreds even get jammed in the spaces between the teeth. Flossing doesn't help!
Mar 07, 2015 | Shredder Office Equipment & Supplies
I placed less than 12 sheets of paper in the ativa 1250 shredder. it's reading overload. can you help?
The problem seems to be the plastic gears and/or bearing supports. Unless it is in warranty, it's going to cost you more to repair than replace, and even then Ativa's customer service is not the best and neither are their shredders: I suggest you look at http://www.complaintsboard.com/complaints/ativa-paper-shredder-c31646.html?page=2
Jun 29, 2014 | Office Depot Ativa DQ60M Shredder
My Ativa HD Pro 1800 will not power on
First check the power point is still working - plug in another appliance, like a table lamp. If OK check the fuse in the shredder cable plug.
The commonest reason for a shredder stopping is a paper jam, or running the shredder for too long. By 'too long', many shredders will cut-out after 5 minutes continuous working, and the sensor may take 15 minutes to cool down! Read the manual.
It maybe that the shredder cutters are jammed. Unplug from mains, and lift off top and place upside down. Use a small screwdriver and/or long nosed pliers to poke at any compressed paper wrapped around the blades - can take a while.
It may be that the sensors are dirty - use a cotton bud dipped in rubbing alcohol to clean the sensor light(s) and heads
Give a quick spray to cutters with WD40 Replace - turn on - and run in reverse.
May 21, 2014 | Ativa HDM PRO 8000 8-Sheet Micro-Cut...
No power to shredder, no reset button, reverse will not solve
The motor may have overheated and failed, especially if the shredder was operated at its rated capacity or operated continuously for long periods of time. The specs for these devices tend to be exaggerated.
Apr 22, 2014 | Ativa Hd1600 16-sheet Cross-cut Shredder
No power. Seems to be overloaded
Check the Power Ensure that the shredder top is firmly placed in the shredder basket if the unit will not operate. If the top is not in place the feeder will not work and accept any paper. Make sure it is firmly plugged into the wall outlet and that the outlet is active. Rest the Shredder Let the shredder cool down if the shredder has been running continuously for a long time. It may have overheated and needs to be left in the off position for at least 30 minutes to reset. Verify the basket is empty or not too full as that will cause the shredder to deactivate. Clear Paper Jam Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from the shredder feeder. If there is no progress then unplug the shredder and remove the shredder top from the bin. Turn it upside down and use tweezers to free any paper that is blocking the gear. Auto Mode Not Working Select the "Auto" option and feed paper into the center of the feeder tray if the shredder is only working in reverse mode. The sensor is located in the middle of the feeder tray and could be blocked by jammed paper. Use an index card to firmly unblock any paper that could be blocking the sensor.
Oct 25, 2013 | Office Depot Ativa DSD160D Shredder
I have an Ativa MD 460 shredder, it is misaligned with paper. Can you help?
ativa md460 misaligned Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Find solutions to your ativa md460 misaligned question. Get free help, tips ... I have an Ativa MD 460c paper shredder that reads misalignment. What do I do?
Just purchased ativa MD 460C and it will not work. misaligned
www.fixya.com/support/t9496803-just_purchased_ativa_md_460c
Jun 16, 2011 - Look for a curve in the lip on the back of the shredder and align it with the ... I have an Ativa MD 460c paper shredder that reads misalignment.
Ativa MD460 paper shredder: misalignment light is on - Fixya
www.fixya.com/.../t7580117-ativa_md460_paper_shredder_misalignme...
Jan 1, 2011 - I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had ...
Office Depot Ativa DQ60M Shredder Misaligned - Questions ...
www.fixya.com > ... > Office Depot Ativa DQ60M Shredder
just purchased ativa MD 460C and it will not work. misaligned is highlighted. can u help... I have an Ativa MD 460c paper shredder that reads misalignment.
Jun 07, 2011 | Office Depot Office Equipment & Supplies
I have a Ativa MD 1000 that I just bought. It ran for a few minutes the first time I used it an then stopped. I turned it off and unplugged it in case it had overheated. The temperature light did not come on. I wait for over 30 minutes and tried using it again. I was able to shred a couple of sheets of paper and it stopped again. The next morning I couldn't get it to work at all. The green ready light is on but the shredder will not start. I can't tell if anything is stuck in it. How do I getting running?
Sep 08, 2010 | Fellowes DM8C Cross-Cut Shredder
Need Ativa X1800 Shredder Parts
Hey check out this link they service all types of shredders hopefully they should be able to service yours.
http://www.factory-express.com/blog/2005/10/paper-shredder-parts.html
Jul 03, 2009 | Office Depot Ativa DQ60M Shredder
Won't Turn on
Yes...these small shredders are only meant for light use....5 minutes ON..10 mins OFF to let it cool down, thats the nature of a $60 or $70 shredder.
Commercial shredders start at $250 and go up. But you dont have to wait for them to cool down.
Common sense still says you must buy the right machine for the job...even if you only use it 2 times a year..it depends on the amount of paper you shred..not the number of times you use it.
Anyway...if it won't turn on at all its most likely the pcb inside....contact Royal for parts and pricing at 1-800-524-0799.
Jun 06, 2009 | Royal AG10X Shredder
I had paper jam in the Ativa Dq60M shredder but now doesn't work
it might be over heated. Just wait until it cools down and try it again
May 03, 2009 | Office Depot Ativa DQ60M Shredder
Office Depot Ativa  DQ60M Shredder Logo
798 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Jim Keysor
Anthony Karuku
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
