Question about XTR695 Radar Detector
On the side of display screen I have an N on the left side and H on the right side . Can u explain why those ate on now and of it's a problem? Thanks!
    Sergeant:
  • Whistler Expert
  • 347 Answers
The N indicates North as the 695 has a built-in Compass and the H indicated Highway mode. Look at the bottom of the unit for the sticker explaining the calibration procedure to activate the compass.
Posted on May 24, 2011
Split screen left side magnified right side regular how to quit?
Which version of OSX are you running?
Check in System Preferences under the Apple menu, then click on Accessibility and un-check the Zoom feature.
Also check Displays in System Preferences as well.
Oct 17, 2012 | Apple iMac Desktop
On my asus Eee Pc 1201HAB the display shifted to the left so the left side is partially cut off, how do i fix it?
1) Looking at the User Manual right now, and do not see a Hot Key on the Keyboard, that shifts the display.
[ Hot Key is also known as Special Key. The F1 through F12 keys at the top of the keyboard, and also for your model, colored keys on the keyboard ]
It could be the Screen Resolution is messed up. Not set at the correct settings.
Right-click on an empty area of your desktop screen.
At the bottom of the drop down list, click on Properties.
In the Display Properties window click on the Settings tab.
The screen pixel resolution should be set at 1366 X 768,
http://www.screentekinc.com/Asus_EEE_PC_1201HAB--12.1-inch--1366x768-wxga_hd-laptop-lcd-screen.shtml
In the middle of the Display Properties window, you see the blue subheading - Screen resolution
Right under this small subheading is a Slider.
The Pointed 'arrow' with the green tip, and top, slides back, and forth on the 'line'.
It should state 1366 X 768.
If it does not;
A) Left-click on that green tipped Slider. Hold the left mouse button down. Move your mouse, and move the Slider. (Drag)
Move it to the Left to Decrease the screen resolution, or to the Right to Increase the screen resolution.
Can't set it to 1366 X 768? Post back in a Comment.
ALSO, the Color Quality should be set to -
Highest (32 bit)
If not click on the blue down arrow to the right of this box.
In the list left-click on Highest (32 bit)
Now go below to the right, and click on Apply.
After go below to the Left, and click on OK.
Still no joy?
Believe the problem is hardware related.
Could be something as simple (?) as a bad Video Cable.
(Goes from the motherboard, up under the left Hinge, and then up into the Display Assembly)
Could be the screen Inverter.
However the Eee PC 1201HAB is supposed to use an LCD panel, that has qa series of LED's for backlighting.
Newer backlighting that uses a series of LED's for the Backlight, doesn't require a screen Inverter.
There were some LED backlit LCD screen, that DID use a screen Inverter. Mostly the older models of laptops.
This is what makes me think your LCD screen's Backlight, (And LED), may use a screen Inverter,
http://www.batterystyle.com/asus-eee-pc-1201hab-screen-p-168219.html
Scroll down,
"5. Disconnect the power cable and video cable from the Asus EEE PC 1201HAB Lcd panel. The power cable connects the screen's power source, the lcd inverter, to the backlight lamp attached to a side of the panel."
Probably just a generic form, and didn't take in consideration that the Eee PC 1201HAB netbook, uses a series of LED's, as a Backlight.
May not have a screen Inverter.
To explain;
Primer:
An LCD screen cannot produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/NA_Optical/Systems/BehindTheScenes/Optics101/
(Click on the window with the computer monitor in it )
It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
[ LED = Light Emitting Diode.
CCFL stands for Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
{Average thickness of a CCFL bulb is 2mm. That is a a little larger than 1/16th of an Inch.
The average length is almost as long, as the LCD screen is in height]
A screen Inverter is used to CONVERT the power from the laptop, for the LCD screen, and Backlight.
Do not see any listings for an Asus Eee PC 1201HAB netbook, for a screen Inverter. Believe the LCD screen uses LED's for a Backlight, and does NOT use a screen Inverter.
Which means if the problem is in the Display Assembly, the LCD screen itself will need to be replaced.
The LED backlighting is built-in.
[Hmmmm, I see a trend going on here that I do not care for, and just woke up to it. Have to replace the entire LCD screen, and cannot just replace the Backlight, or screen Inverter? Sounds like Ka-ching $$$$$ for somebody!
A screen Inverter usually averages from $20 to $40+.
A Backlight ( CCFL) usually ranges from $10 to $15.
An average LCD screen can range from $80 to $300+.]
How to know if the problem is in the Display Assembly?
Use a VGA monitor, and connect it to your laptop.
A) Laptop OFF, monitor OFF. Connect a VGA monitor's cable to the VGA port on the laptop.
(Left side rear. This is an example of a VGA Cable, and VGA connector { Port on a computer },
http://en.wikipedia.org/wiki/VGA_connector )
You can use an older CRT type of VGA monitor (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable attached.
B) Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should automatically show, on the external VGA monitor.
IF not;
There are at least three display options:
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Press the Fn key down, and hold it down. At the same time tap once on the F8 key.
The F8 key is the Display Toggle-Over key.
(Give it a few seconds. Sometimes it doesn't happen right away)
Still no?
Hold the Fn key down again, and tap once more on the F8 key.
Is the display off to one side on the external VGA monitor?
Regards,
joecoolvette
Jul 02, 2012 | Acer Computers & Internet
I have a Akai pdp5016 tv and only half of the screen appears(left). What could be causing this.
Check and replace T'Con board. Before replacing it, check the flat cable connection that connect the display panel to T'Con board. If you do not know anything about electronics, you can't do this work. It is a semi-skilled work.
Jun 13, 2012 | Akai Televison & Video
Brighter display on the left side of monitor than the other side
Sounds like the lcd screen might be going bad. There are no display settings that can modify parts of the screen. It's all or nothing as far as settings go. Have you tried hooking up an external monitor to see if it displays correctly? If it shows correctly on an external monitor the problem is definitely with the lcd screen. If they both show the same image of brightness on the left side, then your video card in the laptop might be going bad.
Apr 18, 2012 | Computers & Internet
How do i turn my screen back the right way
How to Rotate a Computer Screen 90 Degrees
Perhaps you built your own monitor, and the screen is displaying at the wrong angle now that it's all set up. Maybe you installed a new graphics card or driver, and it appears something has gone horribly wrong. It's possible you're just being creative, and think it would be cool to lay your monitor on its side and still be able to use the computer. Or, most likely, your cat or kids pressed some mysterious key combination which rotated your screen for you, and you can't get it back. Don't worry; getting your screen to rotate 90 degrees is easier than you think.
1 Identify in which direction your screen needs to be rotated. There are four shortcut key combinations, and each will rotate your screen so that the top of the screen is at the top, bottom, left or right side of your monitor; you need to know which combination to choose. Say you are you trying to correct a mistake, and put the top of your screen back where it belongs--at the top of the monitor. Or you are trying to rotate your screen because you are using your monitor differently than most people do, and want the top of the screen to be at the left or right side of the monitor, or even upside-down.
2 Hold down "Ctrl + Alt" and the "up" arrow key if you want to return the top of your screen to the top of the monitor. "Ctrl + Alt + Left Arrow" will rotate your screen so that the top of the display is on the left side of your monitor, and using the Right Arrow will put it at the right side. The Down Arrow will turn your screen upside down if your monitor is right side up. Make sure you hold all three keys down long enough; the screen may go back for a moment as the screen is rotated.
3 Open your "Control Panel" if nothing is happening, and see if there is an option to "Enable Screen Rotation" under your Display options. If not, you may not be able to rotate your screen. This is especially common with older computers, as they have older graphics cards or integrated video If you have a newer computer, you may need to have the graphics drivers updated in order for the shortcut to work.
Tips & Warnings
If pets or children accidentally rotated your screen, consider finding a way to better protect your keyboard not just from accidental keystrokes, but from pet hair and kids' spills. A keyboard cover might be in order.
Dec 02, 2011 | Toshiba Satellite C655-S5068 Notebook
My screen is on sideways and i cant put it back the right way
Tips & Warnings
Dec 02, 2011 | Computers & Internet
How do I fix the clock
Push the main control knob (right side of the unit) either up or down, until the Kenwood's display screen shows "Clk Adj." Press the center of the control knob for about a second to enter the clock-setting mode.
  • 2 Push the main control knob either up or down to set the Kenwood's hour display. Stop when the correct hour shows on the screen.
  • 3 Push the main control knob to either the right or left to adjust the minute display. Stop when the correct hour shows on the screen.
  • 4 Press the "Menu" button located in the bottom-left corner to save the changes you made to the clock. This returns you to the main menu
  • Oct 19, 2011 | Kenwood Car Audio & Video
    Can i connect two monitors to a nvidia geforce 315 card so as too use two monitors
    hi,
    yes the 315 desktop card does have multi monitor support. you may however need an adapter for one monitor as it only has one dvi ,one hdmi and one vga.
    so you can hook up any 2 as a combination but they have different plug configurations to do this
    GL
    hope this helps
    Don't forget to vote for me
    Thank You
    Jammer
    Sep 16, 2011 | Computers & Internet
    Front brakes problem
    DO THE ROTORS HAVE A LEFT AND RIGHT SIDE? POSSIBLY INSTALLED BACKWARDS? ASK THE PARTS STAORE ABOUT LEFT & RIGHT SIDE ROTORS & DO HAWK PADS CLASH WITH ATE ROTORS? POSSIBLE DEFECTIVE PADS?
    Jan 13, 2009 | 2004 Honda Odyssey
    Insignia flat screen
    I have the same problem with my insignia.
    The screen was all "pixel-ated" .
    Sometimes the picture would be clear and then it would go all fuzzy.
    One day in frustration I kinda smacked it. Guess what? ... the picture cleared up.
    Since then about once a week I kinda have to smack the right or left side jst to the left or right of the screen.
    Good luck.
    Feb 04, 2008 | Televison & Video
    XTR695 Radar Detector Logo
    53 people viewed this question
    Top Whistler Vehicle Parts & Accessories Experts
    John Nolan
    Greg Cann
    Greg Cann
    Are you a Whistler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
