Question about Viking Refrigerators
I have a Viking 42"
  • 90 Answers
SOURCE: maytag mzd2766gew icemaker
Sounds like you have a bad motor module on the icemaker. Part # is W10122536
Posted on Jan 05, 2008
SOURCE: kenmore bottom freezer refrigerator
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
Posted on Jan 26, 2008
  • 958 Answers
SOURCE: no water is going onto the ice maker (Maytag Model # MZD2766gew)
the water solenoid valve is normally triggered by the ice maker itself. as it turn to harvest the ice, it should trigger the water solenoid valve to start another cycle of ice making. its either a wire harness problem that's why power is not getting to the valve or the triggering switch of the ice maker not sending power to the solenoid. i hope i was able to help you guys...
Posted on Feb 18, 2008
  • 25 Answers
SOURCE: no ice
put your finger into the mold of the icemaker or get a mirror and see if there is any water in it, if not, pour 5 oz. of water into the mold and wait approx. 2 hours, if ice dumps out then you have a water supply problem. the fill tube line entering the the mold could be iced up, if it is then your water valve maybe leaking and freezing up. also the water valve may not be opening up and may need to be replaced if it still doesn't dump out the water you poured in the you will have a problem with the icemaker itself
Posted on May 08, 2009
  • 18 Answers
SOURCE: Viking fridge water and ice not working
Yes....a totaly clogged filter COULD cause the problem, but the water solenoid may be the culprit. I'd call a service company to look at it.
Posted on May 29, 2009
How do I remove a Viking side by side refrigerator from the wall cabinet it is in?
There are adjustable wheels on front. Jack up front enough to grab the frame and pull out slowly. Be careful if you have water line for ice maker.
Dec 03, 2014 | Viking 42 in Built In Professional...
I have a Vuim180ss1 viking Ice maker. Its not getting voltage to the water valve. When water is poured into the tank it recirculates and freezes but not getting new water. I didnt see a float or a wir
This is a earlier marvel built unit. Co voltage to valve then look at the control . Ck your serial break. Cheaper to call marvel for part as Viking and marvel parted ways in 2010. Current units built by Scotsman . Viking range just purchased u line and that will be down the road for UC built products . Fyi
Nov 19, 2014 | Viking Refrigerators
Ice maker spout starts to freeze up (6years old Viking side by side), is there a solution?
low water pressure or faulty valve
low water pressure the valves do not seal proper and slow drips freeze up in tube
are you on well/?
last time fridge filter was changed?
if all good faulty water valve
Mar 28, 2017 | Viking 48 in Built In Professional...
Still leaks
it is condensate from the auto defrost bin/drain pipe,locate and clean with clorine bleach(stops nasties growing....)
Jun 02, 2010 | Viking 42 in Built In Professional...
Viking side by side makes very little ice
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Apr 09, 2010 | Viking VCSB423 Side by Side Refrigerator
May 27, 2009 | Refrigerators
No ice
May 07, 2009 | Viking 42 in Built In Professional...
Ice frozen together
you can adjust the amount of water by popping the front white cover off the icemaker and adjusting a screw . depending on the model the screw will be a flat head on the side of the icemaker or a phillips screw on the front of the icemaker.
Aug 17, 2008 | Viking VCSB423 Side by Side Refrigerator
Refrigerators Logo
Top Viking Refrigerators Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
