Question about Brother Office Equipment & Supplies
Can I still get ribbon cassette for Brother Dopt Matrix Printer M-1209?
  • 30 Answers
These are the cheapest ones I could find online
http://www.neximaging.com/Productlist.asp?id=20717
Posted on May 24, 2011
How to install cartridge ribbon on epson printer
Take a ribbon 10-15mrts ,open the cassette with twizer ,take the old one out.
Now ,put new one in such a way (That ribbon is there between the two gears) now rotate the gears & check that ribbon doesn't stuck anywhere.
Feb 16, 2011 | Epson LX-300+II Matrix Printer
Hi I work in a restaurant and we have a Epson TM-U220A Model M188A printer. The last few days the printer has not been printing on the White receipt paper. We've tried replacing the ink and it doesn't do...
If this is the thermal head model, you will need to have the print head replaced. These were also sold under the Dell label, so finding a used replacement printer may be more economical. If it takes ribbons, you will need:
Ribbons
This printer needs a ribbon cassette to print receipts.
EPSON ribbon cassette, ERC-38 (B) (Life: 3,000,000 characters / Color: Black) EPSON ribbon cassette, ERC-38 (P) (Life: 4,000,000 characters / Color: Purple) EPSON ribbon cassette, ERC-38 (B/R) (Life: 1,500,000 characters / Color: Black)
(Life: 750,000 characters / Color: Red)
You can order replacement parts here: http://www.umd.com.au/itd/products/spareparts_epson.html
Thanks
Jan 08, 2011 | Epson TM-U220 Matrix Printer
Printing quality is very poor
The print quality of dat matrix printers depends upon the printer ribbon. If the ribbon is old or worn out then the print will be very light. In this case replace the ribbon.
Dot matrix printers are very old technology and I suggest you get a Inkjet printer or a laser printer.
Dot matrix printers cannot match the print quality of Inkjet and laser printers.
Jun 04, 2010 | Office Equipment & Supplies
How do i change the tape on it?
This machine uses the Brother TZ tape, which is available in a variety of colors and three widths (1/4" (6mm), 3/8" (9mm) and 1/2" (12mm)). A TZ tape is supplied with this machine.
1 Press in on the rough area at the top end of the machine and fold open the back cover. Should be the exact process as loading batteries.
2 If a tape cassette is already installed, remove it by pulling it
straight up.
3 If the ink ribbon in the other tape cassette is loose, use your finger to wind the toothed wheel in the direction of the arrow on the cassette until there is no slack in the ribbon. Also, make sure that the end of the tape feeds under the tape guides. Note: If you are using a new tape cassette provided with a stopper, be sure to remove the stopper.
4 Insert the tape cassette firmly into the compartment, making sure that the entire back of the cassette contacts the bottom of the compartment. Note: When inserting a tape cassette, make sure that the inner ribbon does not catch on the corner of the metal guide.
5 Securely close the back cover, making sure that it snaps into place.
6 Feed the tape by holding down CODE and pressing PRINT once, and then push in the tape cutter lever to cut the tape.
You can also get a copy of the user's guide here.
Thank you for using FixYa! Don't forget to rate our service.
Feb 10, 2010 | Brother P-Touch 1180 Label Printer
I want to take off the old Ribon and put a new one i don't know how to do it
Lift the front cover take hold of the cassette at each end and pull upwards.
Before you do take note of the path that the ribbon takes across the print head (Make a sketch)
Take out and shipping strips on the new ribbon and pull some of the ribbon out of the cassette
Lay the cassette onto the printer and feed the ribbon back onto the head as per your sketch.
There is a small knob or turnkey on one end of the ribbon wind that slowly so that the ribbon is drawn back into the cassette until there is little or no slack
Place the cassette down onto the two spindles and press into place use the winder to tension the ribbon
A pair of powder free surgical gloves are recommended
Nov 05, 2009 | Epson LQ-2090 Matrix Printer
How can I get printer ribbons for this Brother ML 100 typewriter? Can you give me the code #?
The Brother ML100 uses the BRT 1030. There are several supplies available like the lift off tape, the daisy wheel and of course the printing cassette.
check it out:
Brother ML100 Typewriter Supplies
Good luck and if you need anything you can always call or email.
Duane ONeil
www.FJAproducts.com
800-982-9989
bc.cbi?cbdid=423141670777502444&wdid=1041068402873934082 8 to 5 (pst) Mon-Fri
Sep 15, 2009 | Brother ML-100 Typewriter
What is a ribbon for a electronic typewriter?
A printer ribbon is an inked strip of tissue or other material necessary for any typewritter to print.
In the case of your machine, this ribbon comes inside a cartidge or cassette that looks like those in the image in this link:
http://209.85.229.132/search?q=cache:xpfM5sM-mZwJ:www.databazaar.com/Inkjet_Cartridge/Catalog/SX4000_5167.html+brother+sx-4000+ink+ribbon&cd=1&hl=pt-PT&ct=clnk&gl=pt
To learn more about your machine, you can download de User Manual from here:
http://www.manualnguide.com/manual-get/11878/
Jul 29, 2009 | Brother SX-4000 Typewriter
Ink
hi fushi
puchase a new ribbon cassette (widely available on the internet)when it arrives, lift the printer cover,remove the old cassette (just lifts out ) pay particular attention to where the little piece of exposed ribbon slots into. locate the small exposed piece of ribbon on the new cassette into the slot carefully then click the cassette over the drive cogs (just like playing an old topload video cassette)
Sep 04, 2008 | Epson LX-300 Matrix Printer
Brother SX-4000 Typewriter - problem w/ ribbon
Make sure ribbon you have if for the typewriter you have. take ribbon off machine and type characters, you should see the small ribbon (black) part that turns the ribbon move. If not you have a problem in the printer carrier itself...
May 22, 2008 | Brother Office Equipment & Supplies
32 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
