Question about Sanyo DS24425 24" TV
I received a free second-hand Sanyo television (model #DS24425). When I got it home, however, and attempted to attach the cable to it, I realized the part where I'd make the connection was missing. Is that something that I can purchase and attach myself? Or would I need to take it to a repairman.
    Top Expert:
  • Sanyo Master
  • 75,581 Answers
Hello
You are discussing about the antenna socket of your Sanyo TV. Sanyo has two types of fittings to this. The first type is the socket is screwed to the back cover of the set and a shield wire will go to the tuner of the set from it. The second type is, the in socket of the tuner itself [look like a steel metal box inside] will be projected out through a hole at the bac cover.
If your TVs connection is the first type, you can purchase a ne antenna socket and can be fitted on the same place and rewire it as it was. If it is the second type, tuner as a unit should be replaced. You have to desolder the present tuner out from the set and buy a new one and solder it to the same place. The number of the tuner is very important when buying it, and it will be printed on its cover itsef. OK>
Posted on May 24, 2011
Sanyo DS24425 turns on an then shuts roght off
Check plugs going to the lcd panel from the inverter board. Check ribbon cables going to the inverter board.
Nov 15, 2011 | Sanyo DS24425 24" TV
I hooked up an antenna but I don't get a signal...do I need a box for my DS24425?
vzalutka,
Your model TV was built with a analog receiver. Last year in June there was a change over to digital broadcasting which left your TV unable to view over-the -air signals without a digital decoder. You will need to purchase a box. I included two site to visit for more information.
http://www.dtv.gov/
http://www.walmart.com/ip/AccessHD-Digital-Analog-Converter-Box-1080D/14869369
-Chris
Sep 11, 2010 | Sanyo DS24425 24" TV
Need the code for One For All remote URC-3220 to use on a Sanyo TV Model DS24425
go on line to look for a manual youll be sure to get it they have even older model remote manuals on line for free
Oct 25, 2009 | Sanyo DS24425 24" TV
Have lost the instuction guide to setting up the tv
Click HERE to download instruction manual copy of Sanyo DS24425 TV
Thanks.
Sep 18, 2009 | Sanyo DS24425 24" TV
Digital Cable?
look in ur manula or call the componey that made it or get a hd box
Jul 20, 2009 | Sanyo DS24425 24" TV
Sanyo DS24425 TV Has No Picture and Very Faint Audio
DONT BUY SANYO ELECTRONICS THEY ARE JUNK
Jan 09, 2008 | Sanyo DS24425 24" TV
Need converter box
Not if you have cable TV, satellite TV, or FIOS. If so, a converter won't do anything for you. Not needed.
If, however, you only use a regular TV antenna or rabbit ears, you will need a converter box as this model TV only has an NTSC analog tuner built in.
Jan 04, 2008 | Sanyo DS24425 24" TV
Sanyo DS24425 24" TV has great sound and no picture(black screen)
if tv have black screen,increse screen control to see vert ic is defective,and if screen is white with lots of line acrose ,you can find open resister,on pic tube board,or in main board near transformer.
May 20, 2007 | Sanyo DS24425 24" TV
Sanyo DS24425 Intermittent Discoloration
It seems like this problem would have to be with the picture tube itself, although I have never run into this symptom in over 30 years of servicing TV's. If the CRT is still in warranty I would get it checked out. Otherwise it probably not be worth repairing. If you end up replacing the set, check out the Toshiba 24" model. I have had good luck with that model in the past.
Feb 11, 2007 | Sanyo DS24425 24" TV
Sanyo DS24425 24" TV Logo
48 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
