Question about Canon Office Equipment & Supplies
Hi i have an error code 038005002F2F which is the head management sensor is there a quick fix for this
Engine management light on my Chrysler 300crd code P1208 how can I fix this problem thanks 2006 3ltr diesel...
Code mean cylinder head temperature sensor circuit Low. Don't know where sensor is. Replace sensor
Apr 19, 2016 | Cars & Trucks
Lg front load wm conversation moto type le error pls
Hi Jilu, The link below is a list of error codes for your washing machine..... CHEERS..
LG Washing Machine Error Code = LE
LG Washer Error = Drive Motor Locked Error
CHECK / REPAIR / FIX = Check the wire harness connections on the motor and the hall sensor (tachometer). Repair any wiring issues. If the wiring connections check good then check for damaged motor components. Replace if needed. If motor is good the replace the hall sensor.
LG Washing Machine Error Codes Washer Fault Codes
Apr 03, 2016 | LG Washing Machines
Blomberg DWT34240 error code IF. What does that mean?
Hi, same dishwasher here, same error code. Did you or anyone find out more about this?
Thanks!!
Jan 04, 2012 | Blomberg DWT34200 DWT34210 DWT34220...
I have a Canon IPF 700. After i clean the print head it showed error code 03800500-2F2F .what is the problem and how to fix it?
The head management sensor detected an ink discharge error.
A sensor sensitivity error was detected during head management sensor position adjustment.
Possible solution is to reinstall your old print head or replace print head with new one.
Aug 08, 2011 | Office Equipment & Supplies
I have a Canon ipf 700 and am getting a code: 03800500-2F2F hardware error. Could someone please help me. Thank you.
03800500-2F2F Head management sensor error
The head management sensor detected an ink discharge error. A sensor sensitivity error was detected during head management sensor position adjustment.
Print head, head management sensor, or main controller PCB
1) Start by replacing the print head.
2) Visual check for any foreign substances around the head management sensor.
3) Replace the head management sensor.
4) If continuity of the cable between the head management sensor and the main controller PCB is abnormal, replace the cable.
5) Replace the main controller PCB.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 05, 2010 | Office Equipment & Supplies
Ipf 8000 error code 003800500-2f-2f
there is no enough ink in the head managment sensor.
Go to menu, test print, nozzle check, check the grids 12 pair of grids.
Check if there are any brocken grids.
After that you have to perform head cleaning B twice or more.
If the problem still remains then replace print head.
also perform firmware update to the latest version though the official canon site
Mar 31, 2010 | Canon imagePROGRAF iPF8000 Printer
Hi, i have a canon ir 2800 machine,with the error code E000002-0000 when turned on. please help
This code is a fuser error code. First try and clear the error in service mode - this may help you for a long or short time depending upon the severity and cause of the problem. There may have been a jam in the fuser affecting the temperature. Press the head key (the head shape key with an asterick inside) the the number '2' and '8' at the same time, then the head key again quickly. Then press 'FUNCTION' then 'CLEAR' from the next screen - and then press 'ERROR' then 'OK'. Now, switch the machine off for 10 seconds and then back on. If your problem is not so serious then the error will be gone with perhaps only a jam remaining. If not, then you will require a new fixing film unit.
Jan 02, 2010 | Office Equipment & Supplies
81 people viewed this question
old marine
old marine
