Question about Panasonic Lumix DMC-TZ3 Digital Camera
Will not select menu
When the camera is turned on, message comes up "The zoom will now return to the same position when turned off" Lens does so and then little else can be done. You can select flash function and timer function but menu, display, func, zoom, and activation button will not operate. Is there a system reset on the camera?
Go to SETUP menu (Page 20 in my instruction book) and set ZOOM RESUME to OFF. Then it will open up at widest setting all the time.
Posted on Aug 26, 2008
SOURCE:
THE ZOOM WHEN USED GOES OUT AND THEN RETURNS AUTOMATICALLY TO NORMAL
Could it be you mean the lens barrel comes out, but I can't use the camera? Or does the lens barrel directly go back to the "in" position. If so, check the battery, or even better charge the battery. Then check if the lens, on its way out, is not blocked by anything. Because the slightest obstruction, will cause the lens to retract. The camera does this to avoid extra damage to the barrel and or the mechanics behind it.
May 25, 2014 | Ricoh Caplio R6 Digital Camera
Why does the focusing ring on the efs 55-250mm not retract all the way when you turn the camera off
I doesn't return to it's closed position when the camera is turned off. You have to do it manually . Turn the zoom ring to the 55 position then turn the front focus ring fully to the left.
Apr 27, 2014 | Canon Ef-s 55-250mm F/4.0-5.6 Is Telephoto...
DSC W80 Error Message - Zoom and Picture Doesn't work
There is something blocking the sensors for the lens position. This can something as small as a piece of sand. The motors and gears that move the lens are very small and delicate. You can send it in for repairs to www.unitedcamera.com
Nov 24, 2013 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Camera wont focus or stay on
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
May 25, 2009 | Olympus FE-340 Digital Camera
AV flashing in LCD of camera whn zoom attached
I found on some lenses you need to go into the menu , select settings and change av appurature setting to 2 instead of 1 .
Feb 20, 2009 | Pentax *ist DL Digital Camera
Kodak V610, Lower lens not working
I had the same problem. The lower lens wasnt working, but if i zoomed enough the screen would turn back on.. Heres what worked for me.. go into menu, select setup menu, then select digital zoom. and select "off" . now the botton lens should work. take a picture, and then go back into digital zoom menu and select on, and all the zoom views should work!
Oct 07, 2008 | Kodak EasyShare V610 Digital Camera
I have a lumix DMC-F27 camera it will no longer zoom. No I not in movie mode.
Do you mean DMC-FZ7?
I own one. Assuming that the camera is working normally, then I know two settings that will cause the zoom to be fixed.
Suggestion No. 1:
If the zoom is fixed at the wide end:
1. Turn the mode dial to "P". Now turn on the camera.
2. Press "MENU SET".
3. Press the up arrow button.
4. Now, a menu item named "CONVERSION" should be highlighted. Press the right arrow button.
5. A sub-menu screen should now pop up, select and set "OFF".
Suggestion No. 2:
If the zoom is fixed at the telephoto end:
1. Follow Suggestion No.1.
Suggestion No. 3:
If none of the above solve the problem, then the lens might have been knocked slightly out of position.
~If the camera has been dropped.
~If the camera has been thumped or banged.
~If while zooming, the lens was obstructed.
The zoom motor also could have died, it costs about $50.00 U.S. at Panasonic.com.
My best advice would be to contact panasonic customer service.
Jul 19, 2008 | Cameras
Olympus 8080 C 8080 wide zoom
It may have jumped a tooth, something like a car timing chain. The Zoom in this camera is a barrel that has 3 cams that rides inside another barrel that has "tracks" for the cams. The motor rotates the the outer barrel via gear teeth, forcing the inner barrel to extend or retract. There is a tab on the gear teeth that might index the position of the zoom lens. If this tab is in the wrong position, if the gear jumped a few teeth, the camera may not know where the zoom lens is in relation to the inner focusing lens, and cause the "zoom error" If that is the case, I can help you get it back into position. This is a theory, but does explain the tab on the gear and the constant zooming.
May 27, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Lens
Dear Florida Mom,
Can you please give more details of this problem. If you have problem in zooming, it is selectable in menu of camera. Please go in to camera menu and finde D-Zoom, and change it to higher position.
May 02, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
Lens Error Message
Hi there
I had the same problem a year after I bought my camera. I returned it to Nikon and they fixed it and returned it. The problem reoccurred 3 times and each times Nikon repaired it free of charge. Then after a year it went again and, when I returned it to Nikon they sent me a new camera. Within a couple of months the new camera had the same problem. I have since resolved it with new batteries! The original coolpix rechargeable batteries do not seem to recharge properly so when I put ordinary AA batteries in it suddenly worked. Good luck.
Mar 31, 2008 | Nikon Coolpix 7600 Digital Camera
Panasonic Lumix DMC-TZ3 Digital Camera Logo
203 people viewed this question
Top Panasonic Cameras Experts
Ekse
skyblue007
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
