Clothes in Washer soaking wet, full of soap with error 4
    Brigadier General:
  • 6,277 Answers
Unfortunately you have not told us the make and model to be able to decode your 'error 4' ;-0( So- guess time! I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 24, 2011
Soap water flows through the outlet pipe while soaking
are you referring to the drain pipe from the washer ? if so your drain pipe is mounted to low , it should be mounted so the elbow is above the level for a full load in your washing macine
Jan 10, 2012 | Whirlpool Washing Machines
My dryer is making my clothes soaking wet every time I put clothes in. How do I turn the warer off on the steam mode (I guess)
Same problem here....I have had my brand new Whirlpool Duet Steam front load washer for a whole 4 days... It has worked perfectly until now. I checked on the clothes because it seemed like they just kept going and going... they were soaking wet!! When I took the clothes out the dryer had a huge puddle of water in it..Can anyone offer any help?
Sep 30, 2010 | Whirlpool Duet Steam WFW9700V Front Load...
Clothes are soaking wet after washer is done
maybe your clutch is slipping not getting full spin speed,,,,or could be a problem with your basket drive assy
Feb 21, 2010 | Whirlpool LSB6200KQ Top Load Washer
Clothes are soaking wet at end of wash
Try to repeat the whole wash cycle using no soap. See if that doesn't help. If not, drain and spin... if all else fails utter prayers to St. jude.
Jan 28, 2010 | General Electric WBVH5200J Front Load...
It stops and gives a F 09 error code. The soap is still in the clothes and they are wet, not soaked. Thanks
"F9" is an Overflow Condition error. The following lnk explains how to troubleshoot:
http://www.fixya.com/support/r805532-f09_error_whirlpool_duet_kenmore_elite
Before assuming you have a problem, unplug the washer for AT LEAST 30 minutes. This will reset the Central Control Unit (CCU) which is the main computer of your washer. Sometimes this is all that is required to correct momentary glitches in the program operation. If the error code reappears, following a CCU reset, then you have a legitimate problem.
If you have questions, or require addtional assistance, please let me know. I hope this helps.
Jul 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
CLOTHES STILL WET AFTER SPIN CYCLE
Dear dgloss1856, Sun 4-12-2009 1:14PM EST USA
Washers will shut down automatically without completing the spin cycle for two reasons.
1) Too many clothes in the washer at once (overloading with clothes) !
2) Too much soap in the washer when washing!
When this happens you should restart the machine in the spin cycle or if you can't start in spin run a full cycle without adding soap.
If this doesn't solve the problem you may need to clean the timer or control circuits depending on your machine by cleaning with electronic spray cleaner (available at Radio Shack) by spraying the timer or control circuits as instructed on the can of electronic cleaner.
cd1ee64.jpgLet me know if I can be of further assistance!
Apr 12, 2009 | Washing Machines
My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Mar 13, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
