Question about Microsoft Metrologic MS3780 Fusion Barcode Scanner
Blue light on but amber light not coming on scanner beeps but doesn't scan metrologic ms3780
bluegreenash
  • 661 Answers
SOURCE: Double beeping
Usually Barcode devices come with a code book to program them, This is usually contained in the user manual, and will be several pages of barcodes, using these barcodes you can set the options of your handheld device, including what types of barcodes it can read and other options like output formats and seperator characters, you should also be able to change whether it beeps or not,
Posted on Jul 26, 2007
SOURCE: Metrologic Keyboard Wedge Barcode Scanner (MS5145)
I found a solution. The scanners needed to be reset to default. (via the manual) Thx anyway. Didn't know they could be configured for use without a kboard... That definately bit me once.
Posted on Aug 23, 2007
SOURCE: Metrologic USB Voyager scanner
refer your scanner manual and scan the default barcode printed ,then scan the use interface barcode printed properly
Posted on Feb 02, 2008
mevanforu
SOURCE: replaced battery - do I need to re-boot?
No you have to configure blutooth Adress, it's located on the bottem side of the scaner , scan that barcode and try to read, if it fall, get the user configuration gueid and enabel KBW OR USB ( first Chek Your communication method) if it's KBW trun to page 56 and scan Load keyboard Wedge Defaults , if it's usb trun to page 68 and scan enabel usb interface. if agein fall, scan the recall deafult and do the above steps.
mevan
MARC
Posted on Sep 25, 2008
jackcity
  • 34 Answers
SOURCE: Trying to use Casio PCR-T2100 cash register & Metrologic scanner.
for the scanner, u need to program it to suit Casio Cash Register, eg: baud rate, parity , data bit & so on...other wise, the Cash Register cannot receive the signal from the scanner.
After program the scanner , please perform "flag clear" to the cash register.
Posted on Sep 13, 2009
Metrologic ms9535 4 beeps - whilst fully charged on cradle - still scans ok but nothing in manual to say what the problem is. Any ideas?
The battery can be found for around $35. Just search Metrologic ms9535 battery, or the battery part number itself, 46-46870.
Sep 23, 2011 | Metrologic Instruments MS9535 VoyagerBT...
I have an MS4980 VuQuest barcode scanner. How do I program so that it scans continuously, for a high speed application?
using MetroSet2,select "Scanability Mode" under Misc section.New configuration manual with Honeywell logo doesn't come with this configuration barcode,only those old manual with Metrologic logo has it.
Dec 13, 2010 | Honeywell MS4980 VuQuest FixedIndustrial...
Scanner lights and beeps but nothing comes up on register
Thank you for contacting Fixya.com.
Please check this bellow link to troubleshoot your problem related to your issue:-
http://www.barcode-manufacturer.com/barcode_scanner/trouble_shooting.html
Please get back to us if you have any further query.
Have a nice day.
Nov 17, 2010 | Microsoft Metrologic MS3780 Fusion Barcode...
MS3780 Fusion Scanner and Fillz Inventory Program
contact your dealer...you should have had a manual with it that you have to scan barcodes to set-up your scanner. The most import issue is setting the "host" so the scanner understands what it is talking to. If you have no luck with your dealer, Metrologic can be contacted directly at their tech support line...888-633-3762
Good luck
Jun 23, 2009 | Microsoft Metrologic MS3780 Fusion Barcode...
METROLOGIC BARCODE READER WAS WORKING NOW NOT WORKING
USB CABLE PLUG IS DAMAGED. HOW DO I REPLACE IT OR FIX IT. ITS VITAL TO OUR BAR CODES. CHARLES FRAZIER TEXAS FARM BUREAU 254-751-2580 THANKS
Apr 18, 2009 | Microsoft Metrologic MS3780 Fusion Barcode...
Scanner makes the right nosie and the ligth come on when scanning but does read the barcode
What type of cable are you using to connect to a host?
You will need to configure the scanner for that type of connection, for example, usb, keyboard wedge, serial etc.
If you have purchased it new, you should have the configuration barcodes on the instruction manual, otherwise you wil be able to download the full manual from metrologic website.
Mar 26, 2009 | Microsoft Metrologic MS3780 Fusion Barcode...
Scanner won't scan red ribbon
metrologic ms3780 scanner only scans a few times then stops..when you remove it from the base and reinstall it it works afew times then stops again?
Jan 02, 2009 | Eclipse Metrologic MS5145 Barcode Scanner
Voyager 5929 doesn't work with Vista
The problem isn't your scanner or Vista, it's your adapter. Power requirements and speed of data require special adapters. One I always recommend is Scan Technology's part # STI-PS2-USB. I've tested it with all Metrologic scanners and it hasn't failed yet.
Dec 30, 2008 | Metrologic Instruments Voyager MS9520...
Ms9520
try to reset a bar code ,from the manual
Jan 24, 2008 | Metrologic Instruments METROLOGIC VOYAGER...
Microsoft Metrologic MS3780 Fusion Barcode Scanner Logo
43 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
