My Fellowes T7CM shredder just stopped working. Is there a reset button or do I need to remove the top?
SOURCE: Fellowes Powershred 220C shredder.
i am not a service engineer of paper shreder
Posted on May 02, 2008
leroyal
  • 2120 Answers
SOURCE: fellowes shredder will not work
Check the front door switch and the BIN FULL switch actuator.
Posted on Oct 22, 2008
t_vinson57
  • 58 Answers
SOURCE: T7CM Fellowes shredder -- internal parts
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
SOURCE: Fellows T7CM Shredder
Make sure you remove all five screws--there's one hidden under the sticker on the underside of the shredding unit.
Posted on Mar 16, 2010
owescrow
  • 24 Answers
SOURCE: i INSERTED A THICK OBJECT
I did that in my shredder and had to use the backwards option for a long time...forwards then backwards and pulling out the material little by little. It is a slow process...you can sometimes pry it a little but make sure you don't insert anything while shredder is operating. I always unplugged mine when trying to tug the stuck paper out of it. You don't want to take any chances. Good luck!
Posted on May 04, 2011
How to reset sensor for fellowes P57Cs
Which kind of sensors? The auto start sensors? If the shredder non stop working you can try clean it. You must open cover, replace cutting module and clean sensors. If this doesnt work after it, you must remove sensors.
Oct 11, 2014 | Fellowes Office Equipment & Supplies
How do I stop shredder from spitting documents in and out?
Try cleaning the cutters well. This will require you UNPLUGGING the shredder. Turning it (the top feeding-cutting) part upside down and removing ALL paper and if you see paper clips or staples-REMOVE THEM! You will need to start the motor several times to move the cutting blades around for a complete cycle to make sure you have removed all debris from the cutting blades.
If this does not work you may have an electrical problem you will not be able to solve. Look for your shredder number in the link provided below and download.
Fellowes Shredder Manuals
Sep 12, 2014 | Fellowes Powershred SB-87Cs Shredder
Hi my shedder PS -60 has the red light on but nothing is jammed - can you help?
I don't have your shredder, but check to see if the top part where the shredder mechanism is closes completely over the trash can. If it is not lining up, it may have a shut off switch. I had put a plastic bag inside mine to catch the bits, and it bunched up at the part where that connection needs to be clear and it stopped. When I smoothed that area, or removed that bad, it worked again. GOOD LUCK!
Jul 24, 2014 | Fellowes Powershred PS-60 Shredder
Mar 13, 2010 | Fellowes Office Equipment & Supplies
Fellowes C220 Shredder Jam
First unplug shredder. You can remove the top and start removing paper. It can be quite time consuming. I can't remember if this model uses plastic paper strippers or not. If it does, they may have broken when the shredder jammed. They strip the paper from the cutters.
Jul 07, 2009 | Fellowes PS70-2CD Shredder
Overly loud shredding; stops prematurely
I have taken many shredders apart and found them so clogged up with shreds of paper and too much oil will turn into paper mud.Be bold and take the top off and clean it out. Unplug the power source and when removing the top , be careful because their will be a short cable connecting the top to the circuit board. Easy to damage.
May 12, 2009 | Fellowes S701CM Shredder
Good luck, Tom
Jan 31, 2009 | Fellowes 3011001 Shredder
Short run time and redlight, stops running Fellowes DM15C
There are two sensors (look like little light bulbs) on the top part of the shredder at either end of the blades. If you pull out the drawer and turn the shredder upside down you will see them. They get dirty telling the machine that it is full and needs to be emptied. Clean the sensors off with an alcohol wipe. If cleaning them does not work you need to replace the sensors.
Aug 25, 2008 | Fellowes DM15C Shredder
My shredder stopped working
I hear about this all the time where I work, unfortunately the motor got overheated and is dead. If the shredder is still under warranty you may want to contact Fellowes and see if there is anything they can do.
Aug 26, 2007 | Office Equipment & Supplies
121 people viewed this question
k24674
