Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Lights off I have a whirlpool conquest side by side. The lights don't turn on unless I manually flick the door lever. Any thoughts. Joe
  • Anonymous Aug 25, 2008
    Dear, Whirlpool, the light on the right compart ment is off I cannot get it where it is locating. Can you tell me where it is located?
    Thanks
  • 594 Answers
Your switch could be sticking. or your bulb may be loose not allowing it to get a good connection i would check the bulb to make sure it is fully screwed in and than clean the switch area with a damp cloth.
Posted on Aug 15, 2008
I have a Whirlpool Gold Conquest refrigerator model number GS6SHEXML00. It is working properly except when I open the fridge door, the light doesn't turn on. The freezer light turns on correctly. I...
George Andraws, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (George Andraws), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 17, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
Freezer issues with Conquest
freezer is supposed to defrost? need more info..
if you need a part try www.appliancepartssolutions.com
Jan 16, 2010 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Water Filter
most whirlpools have the filter located in the bottom kickplate, right below the freezer door. turn counter-clockwise and toward you to remove. if it has never been removed before, they are hard to get out the first time.
Jul 24, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker will not dispense the ice
When you press the lever to dispense the ice, there are multiple switches being activated. Chances are, the one that moves the motor to turn out the ice is bad. Or that motor itself is bad.
Mar 13, 2009 | Whirlpool GS6SHAXLB / GS6SHAXLL /...
Ice machine makes ice but doesn't dispense when the lever is pres
I would check for an electric "flap" that opens & closes when ice lever is depressed. My GE has one and it has been fouled before causing the ice to be stuck inside the door. Hope this helps!
Mar 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
GS6SHEXMLoo side by side ice dispenser not working
On advice from the tech I removed acess door. It was covered by frozen moisture.
I removed the motor it was full of water. I verified 120 volts at plug to motor from control
by depressing the door switch and ice dispenser lever at same time. The motor ohms out
but because of amount of water removed from it I am going to replace it and see what happens.
Aug 05, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Filter for the water dispenser
LOOK AT THE TOE PLATE BELOW THE DOORS. THERE SHOULD BE A ROUND DIAL UNDER THE FREEZER DOOR.
TURN IT COUNTER CLOCKWISE ONE QUARTER TURN AND PULL IT OUT. THE DIAL THAT LOOKS LIKE PART OF THE TOE PLATE WILL SLIDE OFF THE END OF THE FILTER. YOU CAN FIND A NEW FILTER AT MOST HOME IMPROVEMENT CENTERS OR YOUR LOCAL WHIRLPOOL DEALER.
Apr 03, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
168 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
