Question about Intex Above Ground Easy Set Pool 15'X42"
How do you keep the skimmer from popping out of the water? I have the air ring fully inflated and the hanger at its tightest setting. It works fine for about 30 minutes than pops out. Last year i tied a bag of rocks to it but my wife won't let me do that again.
5 Suggested Answers
  • 990 Answers
SOURCE: set up in the same spot as last year but this time
If your bottom is streched out well It should fill quite even. I would continue to fill and see.
Posted on May 01, 2010
SOURCE: Top Inflatable Ring on Intex Pool Leaks
Soapy water never worked for me... Pour kids bubbles into a bowl and use a paint brush to spread the bubbles on the top ring. If there is a hole you'll see it begin to blow a bubble where the hole is.  patch with vinyl repair kit.
Posted on May 31, 2010
macdirk
  • 116 Answers
SOURCE: WWas working just fine then hooked up vaccum and
Depending on how much you vacuumed, your filter may just need to be cleaned. The filter on these units are not very big, so they can get dirty fast. Make sure it is cleaned out. Make sure skimmer basket is not clogged up, and make sure none of the flexible hoses are crimped. Also make sure there isn't anything stuck in the impeller. A stick, twig, or piece of toy, etc, can get stuck and cause low flow. Check for leaks between the suction side of the pump and the pool skimmer. One more think you might want to check is for leaks on the suction side while equipment is off. a leak here will let air into system and effect flow.
Posted on Sep 24, 2010
  • 297 Answers
SOURCE: WE ADDED FOUR 40 LB
Start buy draining 20% of your water and adding fresh.
Filter normal for about 12 hours.
Now test your salt PPM
You can get a salt test kit at any pool supply
you want your salt ppm to be as close to 3000 as possible
any lower than 2700 and you will not produce enough sanitizer and over 3500 can produce high salt code, just taste bad, and ruin your cells in the unit
As for not working, yes the unit will not function properly with any code that comes up
Posted on Jun 16, 2011
Sand filter not filtering! It's been 4 weeks of
Air enters from the front of the pump, usually it is just the lid o-ring (over the pump basket) that needs to be lubed or replaced.
Sand filters do not filter fine particles very well. When vacuuming it is best to set the backwash valve to the "waste" setting. This allows the debris to bypass the filter and go directly to waste. Mind that you are removing water from the pool while on that setting.
Jul 07, 2013 | Pool & Spa
I have a krystal clear 635T filter pump that we got last year with an easy-set above ground pool. We just set the pool up for this year and are having trouble with keeping the filter under the water. ...
There is still air in the hose.....get all of the air out by holding it under the water completely or by filling the hose with a garden hose...
heatman101
Jun 28, 2011 | Sport & Outdoor - Others
I clean the filter cartrige and replaced it .then i turned on pool pump and then went to skimmer and added my d.e about 6lbs just like it calls for.then the oulet lines in the pool started to release all...
First number two. Your filter is just full of water and without air in the system it will look like their is no water moving through filter. As the filter get's dirty it will be harder to move water and start to cavatate so you will be able to see the air and so the water.
When you opened the filter to clean it you probably didn't get it sealed when you put it back together Try cleaning and lubing the "O" ring or replacing it. Also check the inner support ring if you have one and be sure it is in place. Check the tank when running for water leaks to see where air is getting back in when off. If you can't see any you may just need to run for a while and let some DE get into leak and seal it, if it is small enough.
Oct 03, 2010 | Hayward Pool & Spa
How do I vaccum the pool? I dont know if I turn the Veriflow to out and then where do I hook in the hose?..Its my girlfriends pool and she just expects me to know. Thanks
Oh then you DO need help. To vacuum you don't need to change the valve setting on the filter, but if there is a valve on the intake selecting main drain/skimmer you can select skimmer only, but I usually only do this after I have the hose primed. . You attach the hose to the skimmer inlet. Usually there will be a round plate attched to the hose that fits into the skimmer ( you may have to remove the basket) If you don't have that round plate on the hose, then you can insert the hose driectly into the bottom of the skimmer. Before you attach the hose, connect it to the skimmer head on the pole. Submerge the head and hose. Allow to settle to bottom. Put all the hose into the pool. Take the other end and hold over the discharge back into the pool to fill the hose with water (prime) until air bubbles stop coming from vacuum head. Then hold your hand over the hose (to keep from loosing prime) and quickly attach to skimmer. You may hear some air, and the pump may stop pumping fully mommentairly untill it is pumping full water again. Now you can select the valve to divert all the flow from the skimmer
Aug 13, 2010 | Hayward SAND FILTER, PRO SERIES
I have a Jacuzzi AO Smith 1.0hp pump for an inground pool - my husband turned off everything to clean the basket in the pump and now we cannot get it going again. We filled up the pump to prime it, put the...
Ok I assume the pump is running? Check the lid again to be sure the "O" ring gasket is in place. If it leaks, it will draw in air, and won't flow full flow. Also check the lid for cracks. If you have seperate valves on your skimmer and main drain, I ususally close the skimmer valve and open the main drain valve fully. Once the pump is pumping full, I usually open the skimer fully, and only open the main drain about 40%. Another tip would be to close these valves on the suction side when you clean the basket,and do it rather quickly, and you won't have as much trouble loosing your prime.
Jul 07, 2010 | Jacuzzi Pool & Spa
Vacuum
ok, if u connect the vacuum plate to the skimmer then u need to submerge the hose all the way or the way i do is use the water from the return ( where the clean water returns to your pool and put the hose up against it to where the hose is filled with water and it will sink a little bit, This gets all the air out so it will be easier for the vacuum to get suction. Once u get the water in the hose by either submerging it or using the return water then connect the vacuum plate and then put it on the skimmer...it should start suction right away but if it doesnt that means u didnt fill the hose up all the way or u may need to just giggle the hose a lil to get it to start the suction....I hope this helps, let me know
Thanks and God bless
Jun 23, 2010 | Intex Easy Set Pool 15x36
How do you "manually" bleed the air bags in a 96 Lincoln Cont. ?
Shut off pump switch located in drivers side panel door in trunk. Jack up car at frame and support with jack stands. This will make sure the car does not come down on you when you release the air.
Pop retaining off of solenoid valve located at top of airbag and turn valve to first stop till air starts releasing
Sep 07, 2009 | 1986 Lincoln Continental
I have new pentair 1 hp pump that was intalled by
to open the basket the pump needs to be off. all drains and the skimmer needs to be shut. otherwise all the water from the pool will leak out... now when you have done all of that. there should be a ring around the lid you take a hold of that and twist. it can be alittle stiff at first.. When you get that ring off the lid will pop off. now water will come out of it becuase it's just what's in the pump and in the line. once the water is out you can take the basket out and clean it. Now very important. when you put the lid and the locking ring back on open the skimmer and the drains to get water back into the pump. If the pump is not filling up go ahead and automatically put water in there until it's full. once the pump is full you can turn back on the pump and everything should work fine. if you have any other questions please let me know.
Aug 19, 2009 | Pentair IntelliFlo VS-3050 & VS+SVRS...
When setting the pump to pull only from the skimmer on my in-ground pool, it doesn't **** enough water to keep the the suction pump full of water. I have to set it on main drain or ''skimmer & main...
There may be a partial blockage in the skimmer plumbing. If you lift out the basket, you may be able to see something there. If not, try a hose and flushing the lines.
Make sure the wear door is functioning properly also.
If this is not the issue, make sure that you have all the valves open so there is no restriction of flow.
Jul 10, 2009 | Pentair Bermuda Vinyl/Fiberglass Pool...
My pool pump won't prime
If the pump is above the pool water level the it is unlikly that the tank will fill completely with valves open (which is ok).Most pumps are self priming and will pick up a prime with water level below suction inlet on strainer. Try starting on main drain again and slowly open skimmer line. Did you remove water from skimmer line and winterize(if in cold weather climate)during closing?.I know this sounds stupid, but make sure water level in pool is well into skimmer. If air situation remains after scspriggs' and these thoughts then prepare for a pressure test on skimmer line to determine location of leakage.
Apr 21, 2009 | Hayward 3/4hp Super Pump Inground Pool...
Intex Above Ground Easy Set Pool 15'X42" Logo
50 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Colin Stickland
Colin Stickland
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
