Question about Marantz Audio Players & Recorders
The teeth on the orange wheel have broken on my arantz 42 can I get a replacement?
  • codeteal May 24, 2011
    How old is your system? If it's less than 3 years you qualify for warranty, meaning a new system
    Top Expert:
  • Marantz Master
  • 74,496 Answers
Hello
Normally all wheels can be bought from electronic spare part shops. you have to go with the damaged wheel as a sample with you to buy a new one, because they will have a lot of types to sell, and we have to choose the right one for our device. OK.
Posted on May 24, 2011
1988 chevy pick up 5.7 some times when I turn the key it wont start I have to turn the fly wheel a inch or so for it to start any I dear what it might be
There are teeth on the fly wheel and you may have broken one or more teeth. You may have to replace the fly wheel. When you turn the fly wheel by hand you make the good teeth so the starter will work.
Jun 14, 2017 | Cars & Trucks
Why does steering slip turning left?
broken teeth on the steering gear (attached to the steering rod) or the steering plate (the one that turns the wheels) follow the steering rod from the steering wheel down to the frame, if it goes THRU the frame look underneath the lawnmower and youll see which one is messed up, just replace the one that has the broken/worn down teeth, hope this helps
Jun 02, 2015 | John Deere Garden
Under the pull cord cover the teeth are broken of the wheel and its not catching
if fly wheel teeth broken replace it teeth on cover broken replace it
Sep 08, 2013 | Garden
I have a Poulan 18 HP 42" deck; battery would not charge so replaced it with new. Now starter gear will not engage with teeth on flywheel, sits just below engagement level and just spins. Suggestion
Most starters will have a bendix shaft, once the motor starts to rotate the gear follows the bendix thread up into the fly wheel ring gear, so there is either not enough charge in the battary, or the bendix on the starter motor is bad, or the gear itself is bad, or the battary is wired up the wrong way.
Feb 10, 2013 | Poulan 42 In Deck 165 HP 6 Speed Manual...
Flywheel
The most commun problem is the starter selenoid 2.-the starter in most auto parts they check free and when you remove the starter check the flaywheel teeths turn the fly wheel with big screewdriver on the starter area and check all flyweel teeths condition if you have any broken teeths replace the flyweel
Jul 22, 2012 | 2000 Ford Explorer
Machine keeps going around in circles jet at back is going straight back?
Few different things can cause this. Wheel bearings can be bad, tires worn, teeth on gears inside wheels stripped or broken, or the teeth on drive shaft worn or broken. Low pressure or clogged line can also cause to run sparatic, but not necessarily in circles. Most likely problem is with bearings, or wheels. Check these closely for problems. Most pool stores with check it and replace parts (that you purchase) for free.
Sep 21, 2010 | Polaris 380 In Ground Pool Cleaner
The steering wheel on my toro lawn tractor is loose - teeth won't engage. It doesn't look like the teeth are broken - can I loosen the plate on the tractor that is attached to the wheels and adjust to fit...
no; you'll need a new steering shaft and a steric gear.( i just did this on mine) this will be your best result.as they wear @ the same time both need to be replaced.hope this helps
Jul 27, 2009 | Garden
Broken teeth on drive gear wheels Taros paper shredder Taros 31.8
New gears are $88.50 plus freight. You won't find any used gears because these usually break first. I can help.
Jan 19, 2009 | Intimus 385 se Shredder
Ge timer on washer is broken
If it no longer clicks, the timer assembly will need to be replaced. If just the knob broke off, the timer should be good.
Mar 16, 2008 | GE WDSR2080D Top Load Washer
76 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
