Question about Miele W2240 Front Load Washer
Miele washing machine wont drain
Pump is ok and filter clean but machine still wont drain
  • 734 Answers
Hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
Rinses light flashing fast and wont drain drum and finish wash
Try checking the filter for a blockage or pump being jammed with a button , disconnect drain hose at sink hold a few feet off ground over a bucket should pump/ flow quite freely if not then check filter and pump. good luck
Oct 13, 2014 | Miele Novotronic Premier 500 Front Load...
Miele washing machine wont spin or drain
clean your filter first then check there is nothing in the pump area
Jan 22, 2014 | Miele Washing Machines
Miele Touchtronic w1203 , the intake and drain fault indicator lights are both flashing at the same time
Seems that the inlet valve or water flow is low , check the inlet flow or check for clogged filter.
Also check the lint filter and the cache filter. remove and clean drain pump. This must solve the issue.
Jan 17, 2013 | Miele Washing Machines
Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
Miele novitronic w830. Drain wont work. I've cleaned the outlet of dirt and the wheel inside the outlet is spinning freely. Reggadles, red light comes up.
Have you tried checking the drain spigot under the sink where the waste hose connects as it can be blocked at this end?
Try draining the unit into a bucket instead of the sink this will eliminate the washing machine as being the problem if it works ok.
is the drain pump actually turning? select drain or drain spin and have the fluff filter (outlet) removed so you can see if it is turning. if it isn't turning there maybe a broken wire to the drain pump causing it not to turn or the drain pump is jammed with something although you mentioned you could spin it freely.
hope this helps
Jun 01, 2010 | Miele Novotronic Premier 500 Front Load...
Check drain keeps flashing and machine wont drain even though drain is not blocked. I have removed and cleaned out debris in the drain filter but the problem persists.
You need to check fault is not upstream from the filter/ is it the pump? thats jammed due to sock or coin also check hoses leading to the filter are clear..
Nov 17, 2009 | Miele W865 Front Load Washer
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
The washing machine wont start
This indicates either a faulty inlet valve, afaulty pump or a blocked filter Regards Engineer
Jul 28, 2007 | Miele W2240 Front Load Washer
Miele W2240 Front Load Washer Logo
3,572 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
