Question about Victor 1200-3 Calculator
I have a Victor 1200-3 Calculator and the screen only displays 4 digits but anything past the 4th digit doesn't appear on the screen. it appears but very faded. Can I get a replacement screen?
2 Suggested Answers
SOURCE: Victor 1560-4 calculator
http://www.victortech.com/accessories.asp
109640-01 (Arm Set) for $5.00
Posted on Mar 06, 2009
The camera took great pictures then all of a sudden the screen appears as a purple haze -- and the pictures come out as just a purple blurry haze. Adjusting brightness doesn't work. Yet, the shutt
If the LCD displays correctly on previous photos then the problem is more than likely a CCD or associated ribbon connector failure due to moisture/condensation or age/misuse. Good luck with finding a replacement part!
May 31, 2012 | Panasonic Lumix DMC-TZ3 Digital Camera
I have a Samsung Digital camera was working fine. I just turned it on and their is a black smudge on the display screen. It wasn't dropped or anything just appeared out of no where. It doesn't
Hi
As you say the camera is only a month old it should be under warranty, better advised to take it to the authorized service center. By the way if the smudge is on the LCD then I feel that the LCD is damaged due to pressure or force at that particular spot.
Regards.
Javeed
Jan 30, 2012 | Samsung Cameras
Paper won't feed in Victor 1460-3. Calculator works fine otherwise.
There appears to be something in the way as the paper bunches up when I start to feed it through.
Is there some way of taking the back off this calculator?
Aug 17, 2011 | Victor 1460-3 Calculator
How do you set the date on a Victor 1560-6 Calculator. I held down the date button on the unit and the number is flashing. I entered 08232010 for Aug 23rd, 2010 and I am not sure of the sequence to lock...
Immediately after entering the year part of the date, the display should revert back to a blinking first digit (in this case, the 0 to the left of the 8) while retianing all the following digits just entered. Simply press the Time/Date key again to lock in that date and stop the blinking. The same process applies for the time.
To clear the display of the time/date when using the calculator to actually compute something, press the C or CE button. This will result in a 0 appearing on the display. The unit is now ready for data entry.
Aug 24, 2010 | Victor 1560-6 Calculator
Cannot set date and time
Below are the steps to assist you in
setting the Date and Time on your calculator.
NOTE: The "Time Set", "AM/PM", "12/24" and "Format" associated keys are
on the faceplate above the respective key. Position the calculator so
that you can look directly over the keypad to see the notations.
Setting the date:
1. Press the CALENDAR/CLOCK Key. The default date will appear.
2. Hold the TIME SET key down for 3 seconds or until you see the first
digit begin to blink in the display.
3. Input the correct date.
4. Firmly press and release the TIME SET key. The first digit should
stop blinking and the date is then set.
Setting the time:
1. Press the CALENDAR/CLOCK key. The default time will appear.
NOTE: The seconds will disappear.
3. Input the correct time. If you need to adjust to AM or PM, press
the AM/PM accordingly.
stop blinking and the time is then set. The seconds will again be
displayed.
Follow by pressing the CLEAR key to return to the calculator mode. To
return to either the TIME or DATE, press the CALENDAR/CLOCK key to
toggle between them.
Jan 29, 2010 | Canon P23-DHIII Calculator
How do you set the date and clock?
Setting the date:
Setting the time:
displayed.
Jan 25, 2010 | Canon MP49D Calculator
SETTING THE DATE
Setting the date:
Setting the time:
displayed.
Jan 22, 2010 | Victor 1210-3A Calculator
Canon P200 DHIII calculator needs to be changed the date. Can you tell me how?
Setting the date:
Setting the time:
displayed.
Jan 22, 2010 | Canon P200-DHIII Calculator
Cant change the date
Setting the date:
Setting the time:
displayed.
Jan 17, 2010 | Canon LS-100TS Calculator
Changing the date.
Setting the date:
Setting the time:
displayed.
Jan 15, 2010 | Casio DR-T120 Calculator
Victor 1200-3 Calculator Logo
Top Victor Office Equipment & Supplies Experts
Greg Cann
Greg Cann
k24674
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
