Question about Altec Lansing Multimedia Computer Speakers
I need power supply lead for fx3021 speaker system.. And the jacks to go from pc to speakers? Wondered if they are generic or specific to altec?
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
SOURCE: Device Manual Altec Lansing 251 computer speakers
go to link below
www.eoneonline.co.nz/shop/CP/Speakers/Altec+Lansing/S2012.html
Posted on May 13, 2008
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
SOURCE: Compaq Presario v2000 ALTEC LANSING speakers not working
There is not driver problem. I can hear sound using headphones and no yellow exclamation next to the "Sounds, Video and Game Controllers".
Posted on Sep 24, 2008
SOURCE: Altec Lansing ada745
I work for a charity that had one of these donated today and as I was looking for a new sub for my cinema system I purchased it. I have no other speakers with it and no way of switching or varying the volume. I opened up the back of the sub and slid the board partly out exposing the PCB.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3734.jpg[/IMG]
You'll see 3 solder connections behind the scre in an "L" configuration. One of them is common, one volume and one power on. As I don't need volume, I'm happy with it being on full as my cinema system will vary the input, I joined all 3 together giving power on and full volume. It is working great now.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3737.jpg[/IMG]
For you guys with volume controls, I would suggest shorting out the two rightmost pins in the "L" and I recon this will power it up and try varying your volume control. I recon it'll work just great.
Good luck
Posted on Jan 22, 2009
My speakers will not power on
Are they powered from the USB cable, or from a separate DC jack? If it's a USB cable try using another. if still not working, try them on another computer. If they still don't work after that, they're faulty.
If they're powered from a DC jack, try another power adaptor.
Aug 24, 2014 | Altec Lansing Avs200w 2-piece Multimedia...
9 pin diagram altec lansing
can anyone help me with the Altec Lansing VS4121 2.1 Channel i need the wiring diagram of 9 pin cable i broke it. please mail me the layout at maurya.mohit07@gmail.com
May 20, 2012 | Altec Lansing VS4121 2.1 Channel Powered...
I am trying to hookup my AL subwoofer to my existing comp system.Inserting a wire jack into one of the comp spkrs and subwoofer shuts the sound off.?? It is a FMC0034326 Altec Lansings Subwoofer.Thanks.
You can't just do that. Your sound card needs to have a specific jack just for subwoofers. If you plug it into the speakers, the computer recognizes the subwoofer as a pair of headphones and routes all sound through it. Remember, a subwoofer is not a normal speaker. It only allows a frequency of extremely low sounds (a.k.a. BASS) and won't play anything that you would need a tweeter for.
Jun 11, 2009 | Altec Lansing Multimedia Computer Speakers
I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
May 02, 2009 | Altec Lansing AVS 300 Computer Speakers
Is it possible to connect my Altec ACS48 speaker system to my TV?
If your TV has audio output jacks, then yes, you can connect your speaker system to the TV. Run a stereo RCA cable from those output jacks to the audio input jack on the Altec system, using whatever adapter required. You will probably need to convert from RCA jacks to a 1/8-inch stereo plug for the speaker input. Or you can pick up a cable from Radio Shack that has the RCA plugs on one end and the stereo plug on the other, and omit the adapter.
If the TV doesn't have audio output jacks, there isn't any easy way to hook up the Altec.
Please take a moment to rate this solution if it has helped you. Thanks for asking here!
Mar 04, 2009 | Audio Players & Recorders
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any...
lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Oct 17, 2008 | Altec Lansing AVS 500 Computer Speakers
Vs3251
You may be out of luck. Apparently, Altec is no longer supporting this product (2002) and the user's manual provides no specifications for the power supply. You can try asking them at 1-800-ALTEC-88 (1-800-258-3288) or Email: csupport@alteclansing.com
The manual is at http://audio.manualsonline.com/manuals/mfg/altec_lansing_technologies/xa3051.html
Mar 08, 2008 | Altec Lansing Multimedia Computer Speakers
90 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Umali
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
