Question about HP Computers & Internet
I shut down my computer to reboot it and when I went to turn it back on it would not go back on. Everything seems fine all the plugs are ok and the green power light is on.
  • 3 more comments
  • virginiamary Aug 15, 2008
    When I shut down my computer I did it from the on/off button not the start menu.
    model# Presario sr2039x
    serial# cnx639027m
    No that doesn't work
    All these suggestions are good but I'm thinking that there's something wrong with the computer because for a while it's been slow to download my homepage and sometimes it didn't even respond so I end up shutting it down to reboot.
    freeze I guess
    Master:
  • 623 Answers
F2 safe mode
Posted on Aug 15, 2008
    Genius:
  • 2,028 Answers
What was the reason for the reboot, software change, install, hardware change, update, error, freeze, what exactly?
    Master:
  • 521 Answers
Back power cord is loose just press that firmly. and try it in another socket (the main outle) it will work.some times the est card in side becomes cold because of moisture and the screen takes time to appear.
  • HP Master
  • 6,487 Answers
Try to open your tower and check if all cables are still connected fine and also to unplug/replug the video card adn check the conenction of the monitor to your video card..
Hope that helps........
  • Mark Gil
    Mark Gil Aug 15, 2008
    By the way do you hear any beeps when you boot the computer up? because it can help us to diagnose the problem...
  • Mark Gil
    Mark Gil Aug 16, 2008
    If the computer is always freezing this can be a problem with one of the hardware components of the computer like the hard drive, memory or processor , if you can trun it off for a about an hour then try to boot it up again and listen for any beeping sound when you reboot it ,that will help us in diagnosing the problem...
    Genius:
  • 1,142 Answers
All you need to do is take off the power cable from the back of the computer leave it unplugged then try to push and hold down the power button for 60 seconds without connecting the power cable, then release the button reconnect the cable and it will definately turn on and boot to normal windows.
  • 594 Answers
Make sure that the video cord in the back on the computer is still connected completly. if so than i will need your series and model of the computer to help you further.
  • Cameron Viseth
    Cameron Viseth Aug 15, 2008
    ok unplug the machine than while unplugged unplug everything from the machine except the mouse keyboard and monitor.
    than while still unplugged press and hold the power button for 5 seconds. after this is done plug the computer back in and try to turn the computer on again.
  • 185 Answers
U may be selected the standby mode in the shutdown option,press the power button it will power on quickly andthen shutdown properly.if u want to restart then select the RESTART option while shutdown.
SOURCE:
Hp pavillion dv9815 won't start. it just reboots over and over. shutting down each time.
take out the battery, then take out the memory. Put one of the two memory modules back in, and turn it on. If everything looks ok, shut down and put the other one back and try again...if everything is ok...then ok. If it doesn't work after the first one, let me know...
Jun 11, 2012 | HP Computers & Internet
About 2-3 weeks ago mouse went couldn't use, then the key board went out about a week ago. Shut down the computer, turn comp. off from back then upluged. after check to make sure everything was still...
Impossible to diagnose remotely. You need to try things like switching the computer off at the mains for a few minutes. If I had the computer I would try a different PSU.
Oct 22, 2017 | Biostar M7VIZ Motherboard
My base unit keeps shutting off after about 8 minutes. Sometimes it comes on in a minutes and other times it must be reboot (unplugged.) Is it defective?
I just had the same issue - i've had them for about 18 months and they were working fine with my regular tv set - connected the red/white analog plugs to the back of the tv and then other 3.5mm end to back of base... but now, i just bought an LG hdtv and had to reverse that connection... 3.5mm to the tv and the analogs back to the base... worked ok for about 10 mins then the base shut off... seems that the volume setting on the hdtv wasnt up high enough to "register" with the base - base thought nothing was happening so it automatically shut off for "inactivity" - so, when plugged into tv, I turned the tv volume way up to 100.... seems to have worked - just need to be sure to turn the volume on the tv back down before removing the headphone jack!
May 11, 2010 | Sony MDR-RF970RK Headphones
Keyboard not working after being unplugged & used on another comp
Close down computer and reboot and pray. I mean to close down not reboot, not hibernate, not sleep.
Why? The electronic chips chatter before the operating system boots up. BIOS asks who is here? Any Keyboard, and other internal bits.
For readers... Cold rebooting fixes a multitude of problems with not working. OK, it does not fix everything, but it is a good first try
Sep 08, 2017 | Dell Computers & Internet
Machine shutsdown hard shortly after boot
OK, i experience this before, i think your situation is mostly like mine, and this problem may cause by the your laptop power adapter, please replace a new adapter and see how is the result. Hope this help.
YBC (/\)
Oct 07, 2009 | E-Machines 6809 Notebook
I have bought a new Lexmark x5650 Printer. The setup all went fine but everytime i boot my PC running Windows XP the screen just hangs. When you take the USB cable out of the Printer the PC carries on...
Issue: Computer will not boot with the device connected via USB to the PC
Solution: Disable USB Emulation (legacy support) in the computer BIOS
Turning off USB Emulation (legacy support) in the computer's BIOS
The following steps are for Dell computers. If this issue is occurring on another brand computer, the process of entering the computer's BIOS may be different. Additionally, the steps to make changes may differ as well. Refer to the computer's documentation to verify the appropriate steps to disable USB Emulation.
For Dell computers, perform the following steps:
While rebooting the computer, press the <F2> key to enter the System Setup (BIOS).
Press the Down Arrow <?!> key repeatedly until 'Integrated Devices' is highlighted.
Press <Enter> and another window appears.
Press the Down Arrow <?!> key repeatedly until 'USB Emulation' is highlighted.
Press the Plus <+> key to change the value to 'OFF'.
Press the <Esc> key to exit this window.
Press the <Esc> key again to exit the System Setup (BIOS).
When the message "Do You Want to Save Changes And Exit" appears, press the <Enter> key indicating Yes to save changes. The system will reboot.
Jul 21, 2009 | Lexmark X5650 All-in-One InkJet Printer
Start > turn off computer does not work on XP
Some process running in the background is not letting the system shut down. Use task manager to kill unnecessary processes before pressing turn off. If it shut downs then try to locate the process using taskmanager which is causing this problem.
Let me know if it helps.
Apr 13, 2008 | Acer Aspire 3610 Notebook
Computer shuts off when transferring tracks
There is a problem with a corrupt file. it seems as though it is playing tag between your computer and sansa. clean up the computer and erase everything from the sansa, restart/reboot everything then try it again. if the problem continutes then it may be the motherboard, but please note that the motherboard would not mess up your computer. if it is under warranty, send it back. Thanks,.....Connie
Jun 19, 2007 | SanDisk Sansa e260 MP3 Player
Receiver won't power on
My receiver was turned on and plugged into a surge protector along with my LCD TV. The power went out and everything shut down.
Dec 28, 2006 | Pioneer VSX-D514 Receiver
Open Questions:
Computers & Internet Logo
74 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
