Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Whirlpool Cabrio gives intermittent F 51 code.
  • Phil Wocellka Aug 16, 2008
    Thanks for the information. Working in the electronics industry, I know how finiky edge connectors can be. I used a small piece of emery cloth to dress up the circuit board on the RPS and the connector and things seem to be going well right now. I also performed the diagnostic checks that are in the manual and realize the control module will retain past faults but was wondering if when you performed the automatic checks if previous faults were eliminated during the checks. No dreaded F51 faults any more and the wifey is happy.
    Genius:
  • 1,028 Answers
Lean washer backward ..with torx wrench remove large bolt in center of flywheel (rotor) back bolt out until you are able to pull rotor off by hand remove 4 5/16 bolts holding stator(coils) to bottom of washer tub carefully lower stator to floor pulling wire retainers from bottom of tub makes it easier..small plug with brown wires carefully hold release clip back and pull plug on and off several times (10-12 should be enough ) reassemble unit and ck...during manufacture too much flux got on contact portion of sensor board and caused poor connection at plug..by pulling plug on and off the flux will be cleaned off(had 1 today)
Posted on Aug 16, 2008
  • oldfixer Aug 16, 2008
    not sure about deleting fault codes believe control retains last 4 but you can't delete ..may be in tech manual never really bothered to try
F 51 code
my hhot point washing machine door won't open and is displaying F5 and door block
Nov 20, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops and F 51 flashs
Hello, It is a rotor position sensor code. The control is no longer receiving a signal from the motor. It can be a failed sensor or control, but usually it is a bad connection where the wires plug on to the sensor.
Thanks
Jun 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Help
F then 51 flashes when there is a motor rotor position sensor (RPS) failure.
It can also be a defective control board false reporting an error which is common on these models.
Apr 27, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
F-51 code on kenmore elite oasis washer - how to prevent and or fix
Please see the following Whirlpool Cabrio installation and service manual, the Oasis is essentially the same washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
The F and 51 code relates to the motor rotor.
"F then 51 flashes when there is a motor rotor position sensor (RPS) failure. See TEST #3."
The "test #3 is a bit complicated but can be completed if you are reasonably comfortable with test equipment.
Oct 20, 2009 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Whirlpool Cabrio W10106470 has an F51 code. What
F51 error is a rotor position sensor error, two parts really need to be replaced. 1) the rotor sensor itself ($43) and 2) the control board ($197)
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washer is giving an F 51 Code
The "F51" error code is common problem with the Cabrio. This is an RPS sensor error. The sensor is mounted along the motor windings under the washer and detects the rotation spin speed. The sensors on these units can go bad, causing the error code, and it has been a frequent problem. I would recommend you contact Whirlpool first (due to the unit only being a year old) and see if there is a recall or upgrade on this part. I believe there is. The repair would then be covered by the manufacturer. If I give you the steps to access and/or replace the sensor at this point, you may be voiding any existing warranty you may still have. Some components carry a longer warranty than your normal one year limited warranty from the manufacturer. Something you may consider.
If you have further questions, please let me know. I hope this helps you in some way.
Jun 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio HE washing machine displays error code F51. What is it and hw to I fix it?
I work for an appliance repair company and I had a recent service call for the same exact situation on this washer. I also know that Rotary Position Sensor is linked to the F-51 error code. I have found that this is not always the case. On this paticular call the F-51 error code was caused by a piece of clothing (sock, wash cloth, etc.) being stuck or jammed between the internal basket and the outer tub. I removed the cloth and the washer ran fine, so give that a check first before you spend the money.
Jul 27, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
146 people viewed this question
Dan Webster
Dan Webster
Sal De
