Question about Dell E228WFP LCD Monitor
Flashing lines down the right hand side of my monitor
My monitor is displaying an area approximately 2 inches in width of flashing lines running down the entire monitor screen. What is causing this and how do I fix it?
    Scholar:
  • 133 Answers
It could be two things.
1. The graphics card is failing.
2. The monitor is exhibiting a defect.
If you have graphics card plugged into your computer, try disconnecting the card and hook your monitor into the built in video port and see if the issue goes away. If it does, then the video card may be failing. If you dont have a seperate video card, then the monitor might be having issues itself. Of course Onboard video can display this behavior too although I have not personally seen it.
Posted on Aug 16, 2008
SOURCE:
I have a vertigo black line on the right side of my monitor/ screen. It fades in and out with rainblow lines and then turns solid black. The width is about 2 inches wide.
HiIt sounds like a display failure.Best way to verify is to try connecting an external display. If that dispaly is good then your internal display needs to be replaced - not cheap I'm afraid.
Dec 07, 2010 | Apple iMac G4 Desktop
Horizonal lines
Unfortunately you can't.
This is what happens when you blow pixels on your monitor.
If it is still in warranty this will be covered.
If you are outside of your warranty then you will need a new monitor
Sep 26, 2009 | Acer AL1916W 19" LCD Monitor
Black strip down the right hand side on my viera plasma
Hello
black strip down the right side its about 2 inches wide there are also red and green flashing lights that is defective shorted capacitor at power inverter board section that was 300uf 200volts.
Angel
Thanks...
Aug 02, 2009 | Panasonic Viera TH-50PZ80U Plasma TV
Blank part on my monitor
This sounds like a claim. Give it back to your seller.
May 28, 2009 | Hannspree HANNS·G HC174DP 17 inch LCD...
Less H-width for higher resolutions
this is not the electronic problem, this monitor is made to support such (800x600) resolution.
Dec 17, 2008 | Compaq 7500 17" CRT Monitor
Veiwsonic VA2026w. Yellow tint down R/h of display.
Which OS are you running?
Try this, after staring your PC press CNTRL-ALT-Delete and go to the processe TAB. Check if you see EHTRAY.EXE running.If so kill it and see if the yellow line disappears. ehtray.exe is part Mediaplayer and runs on startup, sometimes causing strange things.
You can remove it from the registry safely but if youé not familiar with the registry don't do it because 1 error might mess up your PC.
Aug 08, 2008 | Gateway FPD2275W LCD Monitor
Monitor
Monitor sizes are measured on the diagonal from corner to corner.
A 17" LCD may have a screen width of 12 inches measured from side to side.
If you are measuring a old style CRT monitor (Cathode Ray tube) the visible screen area will be about an inch less as there is about 1/2 inch of plastic frame holding the CRT in the chassis. The manufacturer can advertise the actual size of the screen regardless of how much is actually visible to display information.
If you are talking about software not utilizing all the available screen area to display the image, that is an issue with the people writing the software code not keeping up with the changes in hardware.
In the past year or two, most displays have switched to the 16:9 and 16:10 wide aspect ratios while most web content is still written for the 4:3 old style aspect ratio. Eventually, software developers will catch up with cusrrent hardware.
Jul 25, 2008 | Gateway FPD2275W LCD Monitor
Looks like a crack in the display
such issues have occured in the Past, Please Check if the Crack appears in the BIOS mode.Safemode also Try another Monitor to find out if it is not the wall paper because if it is then the Crack will appear in the other Displa too...
Jul 17, 2008 | Computers & Internet
LCD monitor problem
what is the solution for this? my husband just turned his pc on when we got home and there are line blue lines running up n down in the black
Oct 11, 2007 | Computers & Internet
140XiIII left side print right side completely blank
Verify your LCD Display Print Width setting is set wider than your actual label width. The printer will only print to the width of the PRINT WIDTH setting. Also verify any driver or software settings as these override your printer settings.
Jun 30, 2007 | Zebra 140XiIII Plus Thermal Label Printer
Dell E228WFP LCD Monitor Logo
91 people viewed this question
Ekse
Clive
Clive
Alun Cox
