Question about HP Photosmart D5160 InkJet Printer
Message keeps saying "Cover is Open" and I get a red exclamation at top right corner of the printer. The cover, however, is NOT open and the printer is not responding. Help would be most appreciated. Thak you.
  • Ronald11 Oct 13, 2008
    I have the same problem and it's not just the cover not pushing down. No matter how hard I push on the cover or the little spot where a piece of the cover is meant to trigger a mechanism. As I look inside (with small telescoping mirror, I see that what's supposed to get pushed down seems to be missing it's indended target. Last time it did this I was able to jiggle that piece (under the cover, far left) and it worked, so I figured "no more problem," but here it is again and no amount of jiggling is doing the trick.
I have had this problem also and have found that instead of "dropping the cover hard" I can just give the "sensor area" on the left side of the cover a sharp rap with my finger and the light goes off.
Posted on Oct 21, 2008
After searching a great deal, tinkering, and reviewing HP support . . . I let the cover drop really hard (rather than just push down) and it re-set! It's working. #$%# amazing.
Posted on Oct 13, 2008
The cover is not all the way down. Mine does the same thing! Press it down all the way, or place a nice Amethyst Crystal specimen on it (like I do!). That fixes it.
Posted on Sep 04, 2008
Keeps saying cover is open/ please close the ADF cover
The message indicates that the printer door or the cover located on the top is not closed properly, so you need to re-open the door or the printer cover and close it accurately.
GuruAid.com
Mar 08, 2016 | Office Equipment & Supplies
Lexmark x6570 hinge is messed up so im getting cover open message
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to push it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover of the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Oct 05, 2011 | Lexmark X6570 InkJet Printer
Mess. saying cover open i cant seem to close the top down. the top cover seem to be off track or broken
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
Feb 05, 2011 | Lexmark X6570 InkJet Printer
Error message top cover open
When the printer is used often, and ink and dust accumulate inside, the detector switch will sometimes get stuck and won't be depressed by the cover correctly. Open the cover and look right next to the sticker. There is a small rectangular hole with the switch. Use a very thin tool like a small screwdriver or paperclip bent open to push the switch inside the hole to the back of the printer. Do NOT push it just down! You *must* move the switch away from you. Hold the switch in this position and close the cover. Carefully pull out your tool from the gap.
Jan 28, 2010 | HP DeskJet 5652 InkJet Printer
Printer keep saying cover is open and cant find
====.> continued from an earlier answer that seemed to close up too soon, before I finished typing my response.
... and the cover appears to the printer to be open. If you can clean this photo-ectric sensror, it will tell the printer that the cover is actually closed, as it should, and the printer will return to printing as it should do.
Clean all photoelectronic sensors, to ensure that they are all going to respond as they should, and your printer will then work fine.
-a.
Dec 06, 2009 | Dell Office Equipment & Supplies
I just changed my printer cartridges and I'm trying to print but I keep getting "door open" or "top cover open" message and nothing prints. My printer is a HP 5150
Open the cover.In right side you'll see the cover sensor.It's a plastic lever, which does down to the bottom of printer.The top side of this lever usually breaks.
Oct 13, 2009 | HP DeskJet 5150 InkJet Printer
HP Deskjet 5150 - top cover open
I had the same problem, and the cause turned out to be the cover switch not being fully pushed in. On the underside right edge of the top cover, there's a little triangular protrusion that pushes down a black rectangular button (the cover switch) when the cover is closed. The problem occurs because the flimsy top cover is made of plastic and flexes slightly when you close it. This means that sometimes, the right edge of the cover won't seat properly even though it appears as if the cover is closed all the way. When this happens, the triangular protrusion isn't fully pressing the switch down.
To test if this is this is happening, send a print job to the printer and wait for the "top cover is open" error message to appear. Next, open the top cover door and locate the cover switch. It's a little black button in a rectangular hole at the right edge of the doorway near the ink cartridges. Take a pen or a car key and use it to push the cover switch down. You can also use your fingertip to do this if it's skinny enough. If you keep the cover switch pressed down, the power button should start blinking to indicate a print job is coming through. If the print job actually starts printing, then you know the problem was the cover switch.
In my case, all I had to do the fix the problem was close the cover and make sure it was fully seated by firmly pressing down the right edge of the cover until I heard a plasticky "click" noise. After that, the problem went away.
Hope this helps.
Jul 23, 2008 | HP DeskJet 5150 InkJet Printer
Cover open Error message
I'd say maybe the switchs is broken and your machine reminds me of a lexmark fault. Look for the cover switch, under lid on base, at rear, small hole, find the switch that get's activated when openning and closing the top, maybe it is missing, or broken.
link to lexmark fault, that I think you will find your answer.
Feb 06, 2008 | Canon MultiPASS MP360 All-In-One InkJet...
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
HP Photosmart D5160 InkJet Printer Logo
407 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
