Question about Lexmark Computers & Internet
Printer has stopped working. - Lexmark Computers & Internet
  • 53 Answers
If the printer is no longer turning on, there is a power issue.
However if your printer is turned on and just unresponsive, try the following:
Go to > Start > Control Panel > Printers and Other Hardware > Printers and Faxes >
Make sure your printer has a little check over it. (set to default)
If that doesn't work, you can try uninstalling and reinstalling the printer driver for the machine.
(at the same time ensure your computer is virus free)
If all fails after the steps above, the machine is declared nonfunctional and went bad.
Hope this helps ya
Posted on May 24, 2011
Remove all windows updates
Updates from Microsoft generally do not cause printers to stop working.
What kind of printer is it?
Usually if you clear the printer from the device list (delete it) and reinstall the printer again, this is a quick way of getting things going. What changes have been made since the printer stopped working on your PC or with the printer?
Jan 03, 2016 | Microsoft Windows 7 Ultimate for PC
Canon Pixma MP160 stopped working, showing E 2 - paper is not jammed - Printer is NOT hooked up to a computer - only used for scan and print in farm shop (heated) - suggestions? It is an oldie but a...
First thing to try is pressing the "Stop/Reset" button. If that doesn't work, hold it down for more than 10 seconds and release. If that doesn't work try turning off the printer, unplug the power cord for more than 10 seconds then reconnect and turn the printer on again.
If the printer was connected to a computer, there might be more information provided about the source of the problem. Otherwise, a last resort would be to reset the printer. Follow this exactly:
  1. Turn off the printer (using "Power" button) but leave it plugged into the wall socket.
  2. Press and hold the "Stop/Reset" button (red circle in the triangle), and without releasing the "Stop/Reset" button, press and hold the "Power" button (indicator light shows green).
  3. While holding down the "Power" button, release the "Stop/Reset" button.
  4. Continue holding down the "Power" button, double click the "Reset" button and release the "Power" button.
  5. Click the "Stop/Reset" button four times
  6. Press the "Power" button to confirm and turn the printer off. Turn printer on again.
Feb 18, 2015 | Canon PIXMA MP160 All-In-One InkJet...
Why has PIXMA MX410 printer stopped working? Re-installed Canon PIXMA MX410 All-In-One Printer on hp pavilion 23 widow 8 x 64, system would only print but menu solutions would not. Then printer stoppe
Driver issue. Uninstall and reinstall driver for win 8 64 bit - should work if same worked before. Did you try a system restore to time when printer was working properly?
Sep 11, 2017 | Canon Office Equipment & Supplies
MY PRINTER STOP WORKING WHAT DO I DO?
What do you mean it stopped working? What happens when you try to print to it? Are there any messages?
Printer's don't just stop without giving you some indication as to what is happening.
May 31, 2012 | Lexmark Office Equipment & Supplies
My mp250 printer shows error p08, I can't use it in any way. I replaced the black ink tank with a new one and tried resetting the printer and it doesn't solve the problem.
Follow the instructions step by step
  1. Turn off printer, cable power still plug in,
  2. Press Stop/Reset button don't release
  3. Press Power Button don't release and than release Stop/Reset button
  4. Press Stop/Reset button 2X , wait until service mode to " 0 "
  5. Turn off printer, cable power still plug in
  6. Press Stop/Reset button don't release
  7. Press Power Button don't release and than release Stop/Reset button
  8. Press Stop/Reset button 4X , wait until service mode to " 1 "
  9. Turn off printer, and loose cable power, wait one minute.
  10. Connect cable power, turn on printer again, now this printer ready to use.
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Document stuck in que, can't delete, can't print i can delete the other ones after the first one, but the first one is stuck. tried to delete several times, won't allow it. tried to unplug printer, shut...
I'm not an expert, but this usually fixes my printer when this happens. Go to Start, Control Panel, Administrative Tools, and then Services. You will see a long list of items. Scroll down to Print Spooler. On the left hand side you will see buttons to Stop and Restart Services. Click on Stop and wait until it stops. Then click on Restart. Try to delete the item from the printer que again. If it doesn't work, do the same steps as above, but between the Stop & the Restart, try to delete it then. This works for me. Good luck!
Mar 04, 2010 | Dell A940 All-In-One InkJet Printer
Printer stopped working. pc sending job to
hhhmmm... maybe you have installed the drivers many times.. the printer shows more copies in the printer panel... you must delete those printers... because that will cause conflict ....
Feb 15, 2010 | Epson Stylus CX4800 All-In-One InkJet...
Both lamp on and the printer epson Tx101 stop working.
there is an existing issue w/ your printer that's why the light is not lid up ttry checking the error codes from the epson website
Apr 11, 2009 | Office Equipment & Supplies
Printer stopped working claiming the jobs have been 'stopped' and giving no explanation.
Hi Plug out the usb cable from the cpu. Try deleting the printers from the printers window(START, Printers and Faxes), uninstall the software. Power off the printer and unplug power adapter. After the printer has been deleted from the printer window, plug it back in and reconnect back to computer. Then try a new installation of the printer and software. The pending documents that have been stopped should now not be in the spooled documents.
May 02, 2007 | Epson Stylus DX4200 All-In-One InkJet...
Computers & Internet Logo
29 people viewed this question
Top Lexmark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Robert Monigold
Robert Monigold
micky dee
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
