Question about Braun Health & Beauty
Braun 5 503 not charging no lights no power - Braun Health & Beauty
Braun 5705 will not charge, no lights, or run from power cord. This just occurred as it functioned fine and charged a month ago.
If you've never changed the batteries, the old batteries have probably damaged the circuit board from corrosion or heat. If cord is good and the lights do not work, it probably can not be repaired as circuit boards are no longer available for your model number
Apr 15, 2017 | Braun Health & Beauty
Braun series 5 shaver won't turn on despite charging up and the lights work
The battery may not be any good, even though the lights go on they only require a tiny amount of power, the motor on the other hand requires a lot of power, and so it will not run. Pull the razor apart and test the motor with an external battery.
Nov 07, 2016 | Braun Health & Beauty
Reset light has appeared.What action is required ?
There is no Reset Light as far as I know and the manual seems to indicate the same. I have a series 5. The green light shines when you are using it. The red light flashes when the power in the battery is less than 20%. Put it on to charge and the light will flash green until it is fully charged and then the light will be solid green.
All of the manuals are here from Braun
http://www.service.braun.com/product/search.asp?rg=NA&c=US&l=GB&typ=ui&frmTyp=subgrp&sgrp=subgrp&grp=SH01%3C%7C%3ESH02%3C%7C%3ESH03%3C%7C%3ESH04%3C%7C%3ESH08%3C%7C%3E&s=&subgrp=Series+7%2C+9000+series+-+Pulsonic%2FProsonic%2CActive+P
This manual page is showing the light indicators.
http://www.manualslib.com/manual/20437/Braun-Series-7-720.html?page=8#manual
Braun SERIES 7 720 User Manual Page 8
Apr 01, 2016 | Braun Series 7 720 Electric Rechargeable...
Why have I got a red light on the bottom of my shaver when I am using it
It is common for many Braun shavers, that if the indicator light flashes red while the shaver is being used (switched on and running), it means the battery is low and needs to be charged soon.
Below is an example from a manual for a Braun model 7526 shaver. You can search that site for other manuals if this is not the correct one.
This model shaver has 3 indicator lights:
1) Green (Charging)
2) Red (Low battery)
3) Blue (Power cord attached and plugged into the wall)
Download the manual for the model 7526 here: http://www.manualslib.com/manual/20281/Braun-5301.html#manual
"The green charging light shows that the
shaver is being charged. When the rechargeable
battery is fully charged, the charging light
flashes or goes off.
If later on, the charging light comes on
again, this indicates that the shaver is
being recharged to maintain its full
capacity.
The red low-charge light flashes when the
battery capacity has dropped below 20%,
provided the shaver is switched on. The
remaining capacity will then be sufficient
for 2 to 3 shaves."
Nov 09, 2015 | Braun Health & Beauty
My Shaver will not charge or turn on
Model 7526 is not a new shaver. It was made about 8 years ago. If no lights illuminate when the power cord is attached, the circuit board is bad. Unfortunately, Braun no longer makes internal parts for this model
If you like this shaver model and want a similar one, you will find one at shaveroutlet.com. This model uses the same shaving head as the 7526
http://shaveroutlet.com/braun-series-1-195s-mens-cordless-shaver.html
Oct 27, 2014 | Braun Syncro 7526 Electric Shaver
When I charge my Braun it does not charge.But sometimes it charge. I do not know what to do
i have series 3 wet and dry braun shaver when it ison charge it only sends ared light to show on grip never it blue charge what is possibly wrong
Feb 23, 2011 | Braun 4775 Smart Control3 Razor Series 3...
I have a Braun razor, 8585. When I connect the stand to the power, the light indicating the level of fluid come one and is accurate. When I put the razor in the stand, the charge light flickers but no...
Try removing the cord from the clean/charge base and plug the cord directly into the bottom of the shaver. If it charges directly from the cord, it is a safe assumption that the clean/charge base is not working correctly.
This unit is not repairable as the problem is, almost certainly, a faulty circuit board. You will need to purchase a replacement.
You will find a replacement clean/charge base for model 8585 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
Sep 25, 2010 | Braun Health & Beauty
Braun 790cc Shaver battery not holding charge
the item has a 2 year warranty. if you have proof of purchase date, you should call Braun for warranty service. Phone number is in your owner manual
Jan 07, 2010 | Braun Health & Beauty
Braun 6520 is not charging after changing the battery board.
there may not be anything wrong with the batteries and circuit board at all. you may have a bad motor
Dec 27, 2009 | Braun Flex Integral 6520 Electric Shaver
The Charging cord's head that fits into the Shaver is broken. How get I get a replacement?
I have several new power charging cords for this model. If you want one Please let me know and will give you a good price.
Nov 13, 2009 | Braun 8585 Electric Shaver
Health & Beauty Logo
144 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
