Question about Coffee Makers & Espresso Machines
Our Keurig stopped working. The lights do not blink to tell us that the water is heating up. I have pulled out the plug, taken off the water container. Not sure what to do next.
  • 43,501 Answers
There is air in the lines and it is blocking the water flow...
Here is a tip that will help you getyour Keurig to prime...
Keurig CoffeeBrewer will not prime
heatman101
Posted on Sep 05, 2011
Why is the heated water not going through?
Is this a new or used Keurig? If new, get a replacement. If it is an older model, check the discharge hole where it empties into the K-cup for clogs.
Dec 11, 2017 | Keurig Coffee Makers & Espresso Machines
Blinking blue light on water reservoir won't stop blinking
Needle port is plugged. Clean with paperclip end and run it up 1/4 into the tank to clear the debris.
Apr 10, 2013 | Keurig B60 Coffee Maker
Lights blinking on kergu but want brew
Plugged upper tube to heat section. Clean Pg. 19 Manual
Dec 01, 2012 | Keurig B70 Coffee Maker
How do I dissassemble a b40 keurig coffee maker?
Pull plug, reset factory settings and Prime again.
Jan 15, 2012 | Keurig Elite B40 Coffee Maker
My Keurig B60 stopped working - I plug it in and nothing happens. Prior to this, it was leaking and lights were blinking
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
Sep 17, 2011 | Keurig B60 Coffee Maker
I have the Keuirg mini plus and i just opened it. It flashes red like it is heating and then just turns off. No brewing.
Same here. (I have the Mini Plus B31) Called Keurig and these are the steps they walked me through. Not sure which part actually fixed the problem, but it worked.
1. Turn off machine. Using a paperclip clean out the holes in the needles (3 in the top, one in the bottom of the k-cup holder).
2. If water is inside the heating core (assuming it is as nothing happened when you tried to brew), with the machine turned off, press and hold the brew button. After 5 seconds the pump will kick on and discharge the water. Make sure you have a cup in place to catch the water.
3. Dispose of that water.
4. Unplug the machine.
5. Wait 5 seconds.
6. Plug machine back in.
7. Turn on.
8. Run empty cycle without a k-cup and only use the minimum amount of water (6 oz).
9. Dispose of that water after it brews (hopefully).
If still nothing is happening, call Keurig.
10. Brew your coffee, tea, choco, etc.
Note: was told by Keurig rep that whenever you use hot chocolate, to run an empty rinse cycle afterwards before brewing another cup. This will help prevent any choco from going up inside the machine and possibily blocking the water flow.
Hope it works! Mine did after following these instructions. The rep also wanted me to measure the amount of water that came out afterwards. Not sure what the next step would be because my call got dropped, but the machine works. Sipping on a cup now...
Oct 16, 2010 | Keurig B60 Coffee Maker
Coffee Makers & Espresso Machines Logo
88 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
