My 65H14 projection TV decides when it wishes to project an image and when it does not. Used to be sporatic, but now is becoming annoying. First occurred JUST out of warranty and now is regular. Research on the web is calling it a "brown out," but of course Toshiba has no knowledge of these issues. Is there a way to trouble shoot prior to spending a lot of money to get it fixed?
    Problem Solver:
  • 17 Answers
One of the PC boards in there is called the Hyper board and it needs all the caps on it checked and replaced. I do believe the board is no longer available so get a tech to fix it cause its real easy to ruin that board.
Posted on Nov 18, 2008
  • 20 Answers
Hi i resolve one ,i change voltage regulator str-z4479 ,and ic q306 and bingo are ok hope this help .
Posted on Apr 06, 2009
SOURCE:
My toshiba 65 rear projection is blurry and has dual image
The fluid that is used to cool the face of the 3 tubes has become clouded and discolored. This fluid is serviceable. I wouldn't try it myself if you've never done it before. A TV shop can do the job.
Oct 09, 2014 | Toshiba 65H82 65" Rear Projection...
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Toshiba 65h14
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.Viewing it in "Mosaic" or "Sidebar" will make surf easy.
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Aug 09, 2014 | Toshiba 65HX81 65" Rear Projection...
Toshiba 65H14 is all green... Tint doesn't change it..
As TVs age, the rate at which the CRTs begin to decline in terms of light output increases. If you go into the customer menu and adjust the color setting to zero. ( no color) observe the image. Is it good gray scale? Or, is the image still green tinted? If so, its definitely a problem with the CRTs( picture tubes) You may need to just re-adjust the screen settings for the CRTs or it may be more serious, a CRT may be bad. Replacing the CRT is a job for an expert and will cost $500-700.
michtech
Feb 17, 2009 | Toshiba 61H70 61" Rear Projection...
On my Philis 51PW9303/17F projection TV, the colors are weak. Adjusting the color and tint have no effect on the color intensity or hue. I was given this set and it was worked on. THANKS Mike
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Dec 30, 2008 | Philips 51PW9303 51" Rear Projection...
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Hitachi 53UDX10B PICTURE DISTORTION
projection screens are prone to screen burn ,this is caused by the same image being displayed for a long time ie nick jr image in the corner,also check ther are no magnets close to the tv as this will cause distortion,ie speakers etc,hope this helps
Jun 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
HITACHI 51F59A PROJECTION COLOR TV
we have hitachi 51 inc projection tv model 51f59a for 2 yrs. we got problem adjusting the colors the screen is reddish. pls solve this .
Jan 08, 2008 | Hitachi Televison & Video
Can APAC be disabled?
Yes, Turn off the convergance option.
Oct 17, 2006 | Philips 55PW9363 55" Rear Projection...
Visual fault
Are you sure this is only while watching tv with the reciver?? Try watching a dvd or video. Sounds like a burn in line on a tube or lcd type projection set. Let us know please and a picture would help if possible?
May 22, 2006 | Toshiba DST-3100 DirecTV DTV Receiver
Televison & Video Logo
240 people viewed this question
Top Televison & Video Experts
Ekse
